  • Guests: 31
Banana Man (41)
TheAnomaly (13)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Tesla coil Emi considerations
genious 7
Fri Jan 21 2011, 04:14PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Thanks for commenting.
I think I'll head out for a small (Relatively) drsstc, good grounding and a line filter.
monokel
Mon Jan 24 2011, 11:16AM
monokel Registered Member #2981 Joined: Thu Jul 08 2010, 01:47PM
EastVoltResearch wrote ...
Also, the faraday cage will not do anything for magnetic field shielding.
This is not correct. Assume first - for simplicity - that there are no electromagnetic sources outside of
the faraday cage and that the cage is perfectly conducting (and consisting of plates, not a mesh). From the Maxwell field theory you can see that a time-varying magnetic field could only exist outside the cage if there was also a time-varying electrical field. But due to the cage there is no time-varying electrical field and thus no time-varying magnetic field.
Of course in practice the cage is not perfectly conducting. Low-frequency magnetic fields could exist outside
of the cage. But the HF components of both the magnetic and the electrical field will not go outside the cage.
