  • Guests: 35
WarrenR (64)
currentkills91 (32)
09/14 Proud Mary (62)
09/14 omegalabs (39)
09/14 Plasma Lover (32)
Toroid Flame Frequency
Ryan
Mon Jan 03 2011, 02:29AM Print
Ryan Registered Member #1606 Joined: Fri Jul 25 2008, 02:40PM
At what frequency do toroid arcs turn into flames? And what type of rectification/ coil style (sstc, sgtc, etc) can be used to create these flames?
Arc2 Big
Thanks
Mon Jan 03 2011, 03:22AM
Oh my God that flame is beautiful! Im stunned...
Anyway, i have only done it with vacuum tubes, but i have gotten a flame no lower than 10MHz, with smoothed supply, and no topload. I really wish i knew more about the pic that you just posted! Have any more info?
Anyway, Richie Burnett AKA Geordieboy is the only person i have seen make a solid date coil with a flame, and his ran 4MHz (at least the thouroughly documented one), though his was not a flame like a lighter. It was crazier and what i would describe as 'hectic'. Link2 Search plasma tweeter for more arcs like this, though most are smaller and with tubes. My favorite video of one is this: Link2 Very efficient, the tube is only 40w dissipation. Also here is mine: Link2 The flame is not straight up as it is halfwave rectified.
Ryan
Mon Jan 03 2011, 03:48AM
That is where I found the picture. I've seen the 4mhz coil before, pretty cool stuff
Mon Jan 03 2011, 04:14AM
Ryan wrote ...
Oh, ok, that is a ground arc, not simply breakout. That happens at any frequency with a sstc when you draw an arc so long as it has high enough on time, especially CW.
Ryan
Mon Jan 03 2011, 05:05AM
When you say ground arc, do you mean to a grounding rod that is being pulled away from the toroid, drawing the arc length further away from its origin? How does cw affect this? Thanks!
Mon Jan 03 2011, 11:19PM
Ryan wrote ...
Yes, that is what i mean. CW would make it thicker and more stable, it looks roughly like a flyback arc at relatively high power.
Ryan
Fri Jan 07 2011, 09:45PM
If you used a flyback on a sgtc in place of the NST, would you get similar effects to flames as breakouts from a toroid, or would the breakouts look the same as a NST style coil? Does frequency come in to play to alter the flyback's breakout appearance?
Ryan
Dr. ISOTOP
Fri Jan 07 2011, 10:28PM
The breakouts would look the same.
Flyback TC's are charged using DC, so frequency doesn't matter here.
