  • Guests: 45
Germanium
Kilham
Thu Dec 23 2010, 03:55PM
Kilham Registered Member #2814 Joined: Wed Apr 21 2010, 12:28PM
Would old CO2 laser optic Ge be suitable?.
Adam Munich
Thu Dec 23 2010, 04:28PM
I don't know, I wouldn't imagine the germanium to be too pure in an optic.
Interesting thing with the indium...
quicksilver
Thu Dec 23 2010, 06:54PM
Alfa Asear has perhaps some of the largest and finest selection of elemental metals I could think of that sell in all sizes, configurations, & weights
Thu Dec 23 2010, 07:19PM
I've always fancied having a go at this when I can find the time:
Negative Resistance Oscillator with Homemade Tunnel Diode.
Dr. Shark
Thu Dec 23 2010, 07:32PM
Take this with a pinch of salt as I know next to nothing about semiconductors. Have you considered using the silicon die from a fried MOSFET as your starting point? I imagine with the right device you would get the right bulk doping, and all the features that make it a MOSFET and not a micro-controller live in a very superficial surface layer.
Adam Munich
Thu Dec 23 2010, 08:10PM
"Alfa Asear has perhaps some of the largest and finest selection of elemental metals I could think of that sell in all sizes, configurations, & weights"
Yeah, at $148.00 for 10 grams...
"mosfet..."
It'd be incredibly hard to get it out of the plastic and besides, that would be cheating!
Thu Dec 23 2010, 09:44PM
heh.
what about the silicon window from an old PIR sensor?
alternate idea:- get a surplus germanium diode and homebrew a transistor that way using the existing point contact.
Mattski
Thu Dec 23 2010, 11:06PM
Have you thought about just getting some silicon wafers on ebay? It's not germanium, but there are many varieties readily available at reasonable prices. I think it should work because if I understand how the point contact transistor works it's just two Schottky diodes rather than two PN diodes as in a typical BJT, and you can definitely make a schottky diode on silicon.
"Ash_Small" wrote ...
I can't directly answer your question, but......research 'epitaxy'....it is 'second generation transistors'....I think first gen. was something like 'homeotaxy'....it involves getting some vacuum gear......(at least, I think it does.....I'm interested in this project).....Unless anyone else knows better.........
Homoepitaxy is growing a material epitaxially but with just one material instead of multiple materials as for a heterojunction. It's usually done at ultra-high vacuums which are difficult to do at home. CVD is probably easier since you don't need as much vacuum, though getting the sources is probably hard, as many are toxic or flammable.
Fri Dec 24 2010, 12:20AM
I'm sure you're correct, Mattski. I agree with your points regarding CVD. Next step for Grenadier after doides and transistors will (probably) be photo-electric cells. I did see a website about 'homebrew' photo-electric cells, but can't find the link and they were pretty weak anyway.
If Grenadier continues this avenue of research he will have to embrace vacuum technology at some point. (Unless anyone knows different.)
I've some notes on this somewhere, I'll try and dig them out. I think the site I reffered to above just used vacuum deposition (evaparation, I think) but to get decent results I think you need CVD and Ion Etch (unless anyone knows different?).
Adam Munich
Fri Dec 24 2010, 02:08AM
I emailed a wafer company and they said they have some p-type germanium. Just a question, does anyone know if they used p-type or n-type germanium in the transistor?
"If Grenadier continues this avenue of research he will have to embrace vacuum technology at some point. (Unless anyone knows different.)"
You shall find no research here, I'm just doing this for fun.
