  • Guests: 52
Conical or cylindrical Secondarys
pauleddy
Thu Dec 23 2010, 04:40AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
Is there some Mathatical optimal shape for the best secondary to best inprove performance of the coil. optimal angle, top and base ratio. i know it will afect the number turns in the secondary, the turns per meter will increace the the diameter drops.
im a math guy so this stuff intrestest me.
if i recall corectly Tesla had bult conical type transformers
Thu Dec 23 2010, 01:17PM
Tesla prefered spiral (flat) primaries and secondaries I think.
Seems a popular shape amongst NE European coilers.
doctor electrons
Thu Dec 23 2010, 02:09PM
doctor electrons Registered Member #2390 Joined: Sat Sept 26 2009, 02:04PM
Steve McConner wrote ...
Conical coils are a beeatch to wind, the wire keeps slipping off.
I have seen somebody make a Tesla coil out of a traffic cone, though, so it can be done.
The solution to the slipping and loosening is a double sided adhesive paper! I use it all the time for my coils.
The stuff i get comes in 12" x 12.5" sheets, pressure sensitive. All i do is cut to the secondary height, wrap it around the form
to match the circumference, cut it, apply it, and wind away!! The paper has no effect on the operation of the coil in the end
and its a dirt cheap solution to an age old pain in the @$#. Also helps bonding when you apply the coating because it absorbs the
poly!
