  • Guests: 48
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
looking for origanal rca 811a tubes
Nicko
Wed Dec 29 2010, 06:17PM
Steve McConner wrote ...
Oh man, 13E1s. cheesey Link2 I've got a few 12E1s and S11E12s, but they're not the same thing at all.
We should get together and talk tubes sometime. Is there an audio geek equivalent of a Teslathon in the UK? smile
The 13E1s are for a Morgan Jones-based "Crystal Palace" (him being ex-BBC and all that). Picked up 14 NIB in an estate sale about 20 years ago before they got popular and rare - at the time I just thought that they looked cool and they were as cheap as chips! The iron they need is a) very large and b) very expensive - Sowters made mine - they weigh a ton and I was never brave enough to tell SWMBO how much they cost... even today I break out in a cold sweat at the thought of her finding out...
There are occasional diyaudio UK meets (or there used to be) - there was a Northern one in 2010 - see Link2 - not been to one as I don't do "North" unless taking daughter back to uni. A chat / meet up would be good at some stage, even if it happened to be at a Teslathon! (Derby?) Just noticed that the head-fi lot are trying to arrange one in Manchester Link2 for early(ish) 2011.
Interesting thread but should probably be in "General"...
Mon Jan 03 2011, 10:26PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Also, go to antique radios.c om and search russian and chinnese tubes
Look, I'm not realy into tesla coil, mostly vacuum tube radios of the 30, and 40s. I think I know more about tubes than you if I've spent all this time, not creating sparks or building tesla coils, but repairing and restoring antique radios.
I will admit that the maching part isn't entirely true.....
these people are nice!
Thu Jan 06 2011, 09:44AM
No you don't. Nick and I have probably built about half a dozen tube amps each. tongue Here's one of mine, Link2
If you read this: Link2 it says that tubes have always needed matching, backed up by experimental evidence from testing a batch of 300 GE 6CA7s.
I'm not disputing that Russian and Chinese tubes are poorer quality than NOS originals, but all tubes have always needed matching for critical applications like a push-pull hi-fi amp.
ubuntupokemoninc
Thu Jan 06 2011, 03:50PM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
wow my uncle was wrong thanks amazed
But i've seen people build a dual gu-81m vttc using non matched tubes whats with that?
quicksilver
Thu Jan 06 2011, 07:55PM
Not only am I not disputing what you've said but it seems that buying tubes for a VTTC may be one of the biggest gambles ever.
...Had a tough time getting two to heat evenly; tried everything I could find. Now I am forced to recognize that I got ripped off (2 811's @ $39.) was told as sorts of BS when I asked about matching. Took the coil down as I believe now it's simply not going to function beyond such a minimum capacity.
Nicko
Thu Jan 06 2011, 10:57PM
...I've even recently started repairing valve radios too...
...but only as a present for SWMBO smile
Nah
Fri Jan 07 2011, 02:12AM
say, I repair and collect tube radios!
Just this week, I won a bid for one of my grails, a grandfather clock radio
I wish I could get a Strat for free.......
Also, did you use a tube portable for that amp! Thats horrible! You just ruined history! mad
Fri Jan 07 2011, 09:54AM
The cabinet was actually a modern reproduction of an old Fender tweed amp, made by Mojo Musical Supply. Read the story behind it here. Link2
It's bigger than one of those old portable tube radios: the speaker is 12" and the whole thing weighs nearly 40lbs.
However, I have "ruined history" on many occasions by modding old amps extensively. smile Link2 I wouldn't do it if they were collectable ones with lots of resale value, but I wouldn't buy one like that in the first place.
I also just finished fixing an old Grundig Model 3088 radio. (I ruined history again by grounding the chassis and installing an IEC mains inlet.) Still need to get round to replacing the main smoothing cap and selenium rectifier. They seem to be working fine, but probably a bit of a safety hazard.
You won't get a Strat for free, but you can get a Chinese or Mexican Squier Strat really cheap, especially if you try your local Craigslist etc.
Nick: I'm also a member of the Vintage Radio forum, I signed up looking for some advice on my Grundig. Geek disclosure over. smile
