  • Guests: 34
Electronic gold mine flybacks
ZakWolf
Tue Dec 14 2010, 04:26AM
I was thinking about getting these capacitors for my tesla coil. I am not running a big one so i think these will work which ones should i get?
quicksilver
Tue Dec 14 2010, 09:34PM
I've put 8A through those copy machine transformers and got pretty impressive performance but it really not made for current higher than 5A@12V. I've tried 24v at 3A and even pushed it a little at 35V dropping back the current. They could be used for a coil I believe. The "fat" Teflon input is coupled with #2 (the leads have numbers). Grd is a light green. My little home made HV probe said 5400v @ 12v input.
Edit:
You put a few amps through them you get those nice fat yellow arcs: not those thin little blue guys smile
ZakWolf
Tue Dec 14 2010, 11:28PM
LittleVenture wrote ...
if i use those transformers can i use these capacitors with them. how many would i need in series and parallel?
ZakWolf
Wed Dec 15 2010, 12:12AM
also how to i rectify that kind of voltage?
do you know what the wattage is ?
Adam Munich
Wed Dec 15 2010, 06:42AM
If Hz < 1000 use a bunch of 1N4007's in series.
If Hz > 1000 use a bunch of UF4007's in series.
william L
Wed Dec 15 2010, 07:21AM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
well, in a perfect, lossless situation, I would say 60 watts.
ZakWolf
Wed Dec 15 2010, 07:22AM
thanks Grenadier.
What about those caps in the previous post? Are they any good.
Adam Munich
Wed Dec 15 2010, 07:38AM
The 7500pF 1800V caps look OK for a MMC. remember, the capacitance needed will be dependent on your transformer and your coil.
ZakWolf
Wed Dec 15 2010, 07:45AM
thanks.
I am thinking about running a 2 or 3 transformer stack of those HV copy transformers or what ever they came from( not the flyback). Will that make a decent coil? i am going to wind a new secondary. I was thinking 1'-1/2" tall and 3 to 4 inches in diameter.
ZakWolf
Wed Dec 15 2010, 08:22AM
how does this look. I am going to make my new secondary a foot and a half tall and 3 inches in diameter with 28 awg wire. As far as the primary capacitance goes for the calculations i put my capacitor value of what i have right now 7.5 nf which is 0.0075uF i no thats wrong but thats as close as i can get. here are my calculations :)
1292401256 3114 FT103208 New Coil
