  • Guests: 41
Requesting a double check
Firnagzen
Sat Dec 04 2010, 02:33AM Print
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
I'm planning on building scopeboy's 555 flyback driver, and I made up a circuit layout with eaglecad. The thing is, I'd like someone to double check two things for me:
-Did I make any careless mistakes? I have a tendency to. Sigh.
-Is the layout appropriate? I'm not really happy with how the power traces go under a fair number of components, but I'm trying to make it as compact as possible.
Thanks in advance!
1291430021 567 FT0 Scopeboy
ubuntupokemoninc
Sat Dec 04 2010, 02:46AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
what's a scope boy's driver?
Firnagzen
Sat Dec 04 2010, 03:00AM
This Link2 is. I'm building the 555 version near the bottom of the page.
Sat Dec 04 2010, 08:11AM
Your power traces are way too thin.
Firnagzen
Sat Dec 04 2010, 08:16AM
Oh, that I know: I'm not actually going to print this as a PCB, I'm just using it to get the layout right. DOn't have the chemicals and equipment for etching.
Sat Dec 04 2010, 03:23PM
bicarbonate etch (aka salt water etch) to get it mostly done then a dilute solution of persulphate..
should work and is relatively cheap.
-A
ubuntupokemoninc
Sat Dec 04 2010, 03:40PM
this is the easiest way to make pc boards i've made a couple using this method you don't need weird chemicals, the weirdest chemical is liquid tin, but you don't need to use that i just tined it with a soldering gun. its super easy amazed
all you need is 99% isapropal alchohol
ferric chloride (witch is a pool chemical and can be found anywhere hot tubes and other pools and pool supplies are sold)
liquid tin (optional) the replacement for this is to tin the copper on the board with a soldering gun and abuch of solder.
a clothing iron (for taking wrinkles out of clothes)
and acetone
Sat Dec 04 2010, 03:42PM
Wow, rave from the grave. (That's my circuit.)
You're probably going to need some sort of decoupling capacitor between the control voltage input and ground.
Also, put R4 close to the MOSFET's gate pin, and put the track from the 555 to R4 closer to the ground track.
Firnagzen
Sun Dec 05 2010, 01:11AM
Alright, can do. Thanks for the tips.
Also, what difference does it make if the 555-R4 track is closer to the ground trace?
Sun Dec 05 2010, 01:43AM
Firnagzen wrote ...
Smaller loop area, less inductance, more beautiful waveforms smile
