  • Guests: 57
I have some capacitors...
Sat Dec 04 2010, 09:23AM
ScotchTapeLord wrote ...
... I am filled with envy! Let me know if you ever have one too many capacitors and ~200 dollars too few.
Roll your own. 50 nano, 100KV caps are easy, you don't even need to put them under oil. They cost next to nothing.
(Or get me to make you some $$)
Neuuubeh
Sun Dec 05 2010, 10:45AM
Neuuubeh Registered Member #3411 Joined: Sat Nov 13 2010, 08:25PM
Pump some laser with those and a huge flashlamp :D
Daedronus
Sun Dec 05 2010, 01:44PM
The voltage is all wrong for laser pumping rolleyes
...the discharge time is too short...
...unless we are talking about a Dye or TEA laser....
I also vote for using them to make a Marx and then post movies of it working.
Neuuubeh
Sun Dec 05 2010, 02:14PM
Was thinking of a Dye laser as a matter of fact :).
a large Marx is pretty cool, but dont sparks get boring at some point :D?
ScotchTapeLord
Sun Dec 05 2010, 10:26PM
Neuuubeh wrote ...
Blasphemy!
Dr. ISOTOP
Sun Dec 05 2010, 11:06PM
Hmm...there might not be enough joules per bang for a laser...flashlamps usually don't run at 80KV.
Adam Munich
Sun Dec 05 2010, 11:15PM
80kv through a flash lamp might turn it into a flashbang.
Pinky's Brain
Sun Dec 05 2010, 11:27PM
Jon Singer has done 40 KV.
PS. with pulse duration this short a lot of the light goes into UV, so borosilicate flashtubes don't work so well.
Daedronus
Mon Dec 06 2010, 07:18AM
Most linear flash lamps for lasers are quart...however most of them are also doped to absorb UV (they fluorese under UV light) so they probably don't work well for a Dye laser.
I actually happen to have 2 linear flash lamp that don't fluorese under UV, but all my other flash lamps do.
Neuuubeh
Mon Dec 06 2010, 02:51PM
If you do decide to mess with a few of those caps and see if you can get anything to lase... Link2 . 80Kv should trigger them I hope :D
Again, youd need specs on the caps tho, have to know what your pulse length gonna be like. The Marx would be easier imo :D. Then again, all 16 in a marx? keep some aside :D
