  • Guests: 32
sbs_2010 (34)
SoundDoc (50)
10/10 Ryan Parle (44)
10/10 paulj (29)
10/10 Golasekk (48)
DIY High voltage probe
first  4 5 6 7
Fri Dec 10 2010, 07:57PM
no you do it like this:
HV+ <----------/\/\/\/\/\/\--+--/\/\/\-----GND-----/\/ \/\--+--/\/\/\/\/\---------> HV-
+<---------Vmeter--------- >+
it gives you half the error rate, and no corona on the meter, if youhave the meter on the high side you will get bogus data due to unequal e-field division
Fri Dec 10 2010, 08:19PM
ASCII doesnt seem to work in the forum.
1292012344 2431 FT101831 Sam 0228cropped
it gives you half the error rate, and no corona on the meter, if you have the meter on the high side you will get bogus data due to unequal e-field division , and static influence on the A/D semiconductor.
Pinky's Brain
Fri Dec 10 2010, 08:31PM
Pinky&#039;s Brain Registered Member #2901 Joined: Thu Jun 03 2010, 01:25PM
That's not really different than simply using two resistor stacks on either side of the current meter, with the analog current meter he uses there is really no room to play with those two center resistors.
If you have two stacks in the first place though you might as well use 2 meters, more information and nearly the same effort.
Fri Dec 10 2010, 08:33PM
Pinky's Brain wrote ...
if you use two meters or the same meter twice, your doubling your error rate.
radhoo
Sat Dec 11 2010, 06:59PM
Thank you for your comments.
I've decided to keep the 1GO resistor, despite the corona/static charges inside my meter, because I will use it with other HV measurements, not only this bipolar CW multiplier.
All understood, will post pics soon, and update the first post of this thread in case others need the info.
Sun Dec 12 2010, 05:44AM
radhoo wrote ...
there is no reason for corona to be in your meter, unless your doing something wrong.
Sun Dec 12 2010, 09:00AM
Perhaps someone here should have a go at HV measurement with home-made Kerr cells.
It can't be worse than mucking around with all these potential dividers.
Sun Dec 12 2010, 07:13PM
Proud Mary wrote ...
Pockels, Kerr, and Faraday electrophysical measurement is looking better all the time, compared to all of this crap. But from where will i get the precious glass?
Pinky's Brain
Sun Dec 12 2010, 07:29PM
If you want really high voltages a Kerr cell would suffer the same problem as the resistor stack if you're not careful ... if you just shine the light through part of the cell you end up measuring the local electric field gradient caused by stray capacitance, although averaging across the complete stack could solve that.
Sun Dec 12 2010, 07:38PM
Pinky, my brain is a little slow today, please eleaborate.
first  4 5 6 7
