  • Guests: 38
sbs_2010 (34)
SoundDoc (50)
10/10 Ryan Parle (44)
10/10 paulj (29)
10/10 Golasekk (48)
DIY High voltage probe
Sat Dec 04 2010, 07:52AM
There is no reason that your probe should not work well when measuring a DC voltage, such as is present on a correctly functioning CW multiplier.
From this you can conclude that either your multiplier is not working properly (and it outputting a large AC component), or that you are getting some type of internal corona/sparking loss in your probe.
One experiment to try-connect a capacitor across the output of the CW (if you have access to doorknob caps a few in series would work well, if not you may need to resort to something like a glass parallel plate capacitor of a few nf) and charge it up with the CW. You can then be sure that the output is a pure DC, and your measurements will be correct.
Furthermore, while it is sketchy business connecting a 1Gohm resistor directly in series with a voltmeter, there is no reason that the impedance of your voltmeter should vary significantly from 1Mohm. Most digital voltmeters internally have a very high input impedance (into the Gohm range), and have a resistor in parallel with the output so that stray charge does not cause false readings--and to insure the meter has a constant known input impedance for applications such as this. If you want to be sure, measure the input impedance using your nice voltmeter, you should find it reads quite close to 1Mohm. The neon bulb across the input is a good idea, as is making sure that you have the other side of the bulb well grounded to something that is known to be ground--not simply the negative of a power supply/voltmeter.
Sat Dec 04 2010, 03:31PM
+1, except that DMMs don't have a constant known input impedance. It's not unknown for it to vary with the range. If it does then it's usually extremely high (100M? 1G? Not sure) on the lowest DC voltage range and 11M Ohms on all the higher ones.
So, if your meter is autoranging while it's connected to the divider, the autoranging could go unstable. I would lock the meter to the 10V range and put a 1M resistor across it, to be sure.
Sun Dec 05 2010, 10:30AM
Although wirewound resistors do have inductance I doubt that it will be significant.
i.e. at what frequency will the inductive reactance be 1% of Rdc ?
(L=(r.n)squared/(9r+10h) etc.)
The 100 MOhm resistor in my p6015 is one long helix.
In low-voltage high-current circuits the inductance of wirewound resistors (or even wires) can be very significant.
For a large C-W/Greinacher I would use a moving coil meter with a couple of 1N4148 and a capacitor across it and a string of resistors.
For a small C-W the 50uA may be too much of a load.
Tap off one of the resistors a Gas Discharge Tube of the type used for telephone lines to a reliable 'earth'.
It's quite difficult to be completely safe at the end of a resistor string from eht. and dmms are very susceptible to emi/rfi.
Mon Dec 06 2010, 08:41AM
Sulaiman wrote ...
Agreed.
Sulaiman wrote ...
yes, mine have gone entirely erratic due to rfi and emi, that which is not conductivly connected, ONLY RADIATED across near distances!!
Pinky's Brain
Mon Dec 06 2010, 10:45PM
Patrick wrote ...
yep, thats my plan.
How about using Nichrome wire? The precision of the resistors isn't very important, it's cheap and no need to worry about dielectric strength of the resistor housing.
Tue Dec 07 2010, 12:03AM
Pinky's Brain wrote ...
Patrick wrote ...
yep, thats my plan.
Gasp! cry
If you were to use 34 swg nichrome wire (0.24mm) which has a typical resistance of 24.7Ω/m, you would need 40.485km to make 1MΩ!
Pinky's Brain
Tue Dec 07 2010, 12:24AM
No, I meant for a RC series divider ... here the resistance values are small.
Tue Dec 07 2010, 02:20AM
Pinky please elaborate, I think proud mary is right!?
Pinky's Brain
Tue Dec 07 2010, 03:06AM
Sorry, thought you read that ancient paper I linked.
They put resistors in a capacitive voltage divider to damp the oscillations from self inductance (it's for very high voltages where the voltage gradients along the divider have to be air compatible).
Similar to the Glassman divider, except they tuned it for low bandwidth and put a high resistance resistor across the pair for DC balancing.
Tue Dec 07 2010, 04:00AM
i read that atricle but failed to realise what you meant, but i think the lenth of 50 + miles and TCo would be difficult to work around. but ill look at the math again.
