  • Guests: 26
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
Is there a more robust alternative to IRF3205 MOSFET?
first  2 3 4 5
Tesla Fan
Tue Nov 23 2010, 09:55AM
Tesla Fan Registered Member #3353 Joined: Sat Oct 23 2010, 11:21PM
Hi all,
i also saw some ceramic ones Link2 !But they seem quite thick, and ceramic? Is that a good heat conductor? All i know is that F1 cars (and some porsches) have ceramic brakes, or is that carbon-fiber... confused
Anyway, they are produced and sold, so they should be good for some application. The US seller describes them as "HIGH FREQ".
1290506057 3353 FT100982 Ceramic Insulators
Adam Munich
Tue Nov 23 2010, 11:20AM
It's likey mot a fabulous heat conductor. If you want to use ceramic go for beryllium oxide ceramic. It conducts heat very well.
Steve Hobley
Tue Nov 23 2010, 02:25PM
Steve Hobley Registered Member #1731 Joined: Thu Oct 02 2008, 02:22PM
OK so I salvaged a heatsink, pads and collars from an old TV set (another good source for these is old ATX power supplies).
This seems to have helped enormously - the coil is much more robust, and the heatsink is getting quite warm over the course of each run. That seems to have stabilised the MOSFETS.
The new batch of IRF3205s showed up yesterday, but then I discovered that I'd placed an order for 20 of the wrong type :(
So.... I ordered some from Hong Kong instead for very little money.
Regarding the arcing to the case, yes I have no adequate ground on one of the sockets in the basement, so I connected to a different one, and it turns out that the coil no longer works - worn insulation on the coil ground connector was to blame - this was arcing to the case and producing the "shock" - along with lots of other potential problems. It's all straightened out now.
Tue Nov 23 2010, 03:07PM
Those ceramic insulators might actually be BeO, I wouldn't go smashing them up.
BeO has 10 times the thermal conductivity of alumina, and I believe alumina is a little better than the usual mica or silpads.
Tesla Fan
Tue Nov 23 2010, 03:10PM
Nice, i'm glad to hear you found the problem and i believe that after this little repair the coil will run fine
PS. please check out the ground issue... rolleyes
Electroholic
Tue Nov 23 2010, 03:24PM
Lately, i've been using kapton + silicone compound
i just stick a bit of kapton tape on the heatsink for insulation and then have the compound between the kapton and the FETs. Seems to work quite well.
Steve Hobley
Tue Nov 23 2010, 03:38PM
Yeah me too - although I think I might be redesigning the case - there's not really enough room in the one that I bought, and I want to add a fan.
I have a really cool (pun intended) CPU heatsink and fan that if I can just drill and tap would make an excellent home for the MOSFETs.
So I think this thread has run its course - a big thank you to all those who helped!
If anyone is interested in reproducing the Skori 12 and 24v coils feel free to drop me a line through my website. I think I now know enough about them to be helpful. :)
dingo27
Wed Nov 24 2010, 07:07PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Steve Hobley wrote ...
i would be very careful about getting anything from china, if they are cheap they are more likely to be fake.
Adam Munich
Wed Nov 24 2010, 09:38PM
I see no problem with buying from china.
Steve Hobley
Wed Nov 24 2010, 10:46PM
Wow - what's the story with those?
I've never had a problem with buying from China - but there's always a first time...
first  2 3 4 5
