  • Guests: 27
Ryan Parle (43)
paulj (28)
Golasekk (47)
10/10 Ryan Parle (43)
10/10 paulj (28)
10/10 Golasekk (47)
Hockey puck SCRs: why they need clamping force?
Kizmo
Thu Apr 10 2008, 01:55PM Print
I just bought few 3.3kA (peak) rated SCRs for coilgun/ring launcher applications. These will need 3.5-4kN axial pressure. Why? I did some googling but i didn't found any good articles about this.
1207835726 599 FT0 Tyristorit
Dr. Shark
Thu Apr 10 2008, 02:15PM
Nice pucks, do you have data on them? Action and risetime are probably the most important parameters to look at.
I am surprised Google did not turn up anything. Anyway, in these puck devices the silicon die is not physically connected to the terminals. The terminals have a thin gold coating which needs to be pressed on the die to give a good low resistance contact.
Kizmo
Thu Apr 10 2008, 02:18PM
It was that simple :)
Maybe i didn't use right search word or something. Is there greater idea behind this structure?
EDIT:
Link2 Here is datasheet. Brand new, never been used, from welding machine factory :)
Dr. Shark
Thu Apr 10 2008, 02:45PM
Wow, impressive German made quality smile
The action integral is given with 50kA²s, which is really not bad. The way to use this figure is to divide the energy in your capacitor bank by the total circuit resistance. For example if you have a 1kJ bank and 50mOhm circuit resistance, the action would come out as 20kA²s which would be safely within spec.
dI/dt at 1600A / us is also quite impressive, I don't think you will ever be able to exceed this figure with an induction launcher.
I am not sure about the pressure thing, but I suppose that for proper heat sinking in continuous duty, you would need the pressure anyway. Maybe the manufacturers can safe some cost by not directly boding the die to metal.
Thu Apr 10 2008, 02:53PM
Dr. Shark wrote ...
Actually, thats not correct Dr. Shark.
The reason is because the die / connections inside are not bonded to each other as in your standard semiconductor. The internal connections are only made when the package itself is compressed. Thus, if you don't compress the part, the part looks like an "open circuit."
[EDIT] - Oops. Actually, i reread your post and i misread it the first time. Yes, that basically does mean the same thing i just said, so you were correct.
rp181
Thu Apr 10 2008, 11:15PM
how would you go about putting 700 pounds of force? If using 2 plates and bolts, it would seem that the threads would come right off.
Dr. Shark
Fri Apr 11 2008, 11:14AM
Think about it this way: If you jack up your car to change a tire, you are putting about 4000 pounds of force on the screw in the jack. Of course they use special ACME screws (I totally don't have a clue why they are called that), but we are only talking about a fraction of the force here. In fact I would be more worried about the plates bending (1/2" Aluminium should do though), than the threads stripping.
Bored Chemist
Sat Apr 12 2008, 12:43AM
Re acme.
from wiki "The company name is ironic since the word acme is derived from Greek (ακμή) meaning the peak, zenith or prime. Generally, products from the fictional Acme Corporation are very generic and tend to fail "
lpfthings
Sat Apr 12 2008, 01:33PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Bored Chemist wrote ...
.....products from the fictional Acme Corporation are very generic and tend to fail "
Hopefully its ONLY the fictional corporation angry cheesey
Quantum Singularity
Mon Apr 14 2008, 04:45PM
I've wondered about the puck thyristors too, at least wondering if there is an easy way to DIY rig em up that isnt costly or too heavy. I've always ended up limiting myself to the brick type thyristors, since they have a nice heavy duty bolt connection. But there does seem to often be some really powerful puck style ones on ebay.
