I am trying to install service pack 2 on a computer that had a recovery operation using the disc that came with it (a three-year-old Toshiba laptop).
Here I'll paste the text of a query I posted on the microsoft windows update newsgroup:
> HKLM\Software\Microsoft\InternetExplorer\MAIN\Feat
ureControl\FEATURE_DISABLE_MK_PROTOCOL
> is missing under the "...MAIN" folder. There are two files there, and
> Feature Control is not one of them.
So, I'd appreciate any help from windows gurus.
Windows registry problem when installing SP2 on Windows XP
Carbon_Rod, Thu Apr 13 2006, 08:27PM
You did not RTFA in google cache:
Problem:
When you try to install Microsoft Windows XP Service Pack 2 (SP2), you
experience the following issues:
You cannot install the service pack and may receive the following error
message towards the end of the installation process:
"Service Pack setup has failed. Access Denied"
However, if you use the /u switch (no user interaction) to install SP2, you
won't see an error message.
Instead, look in C:\Windows\Svcpack.log to verify this problem exists. Look
for:
"Access is denied.
Service Pack 2 installation did not complete.
Select 'OK' to undo the changes that have been made.
Starting process: C:
\WINDOWS\$NtServicePackUninstall$\spuninst\spunins
t.exe
/~ -u -z
Software Update Rollback has completed with return code 0xbc2. This rollback
requires a reboot.
Windows XP has been partially updated and may not work properly.
Update.exe extended error code = 0x5
Update.exe return code was masked to 0x643 for MSI custom action compliance."
You can also look in C:\Windows\setupapi.log in order to verify this problem.
Look for:
"Setting registry value
HKCR\Interface\{00000500-0000-0010-8000-00AA006D2EA4}\TypeLib\Version
Error 5: Access is denied.
Parsing AddReg section [ado.AddReg] in
"c:
\4d835a34ff0402a27889723cf2ea\i386\update\update.i
nf" failed. Error 5:
Access is denied.
Parsing install section [DataAccessSection] in
"c:
Access is denied."
Cause:
The administrative user's permission on several registry keys are incorrectly
set and SP2 thinks it doesn't have access to modify the values in several
registry keys. In reality, the registry keys can be modified by the
administrative user, even though the registry key permissions are configured
improperly (Administrators is set to READ). I believe the registry key
permission problem is cause by a faulty MDAC 2.8 installation (prior to
installing SP2). As you may know, part of the SP2 installation process
installs MDAC 2.8 which is when the SP2 installation failure occurs.
Solution:
Thus far, we have experienced this issue on 6% of all computers in our
organization. Create a batch file using the code below and run it on a
computer that has experienced this problem. Regperm.exe (part of Windows XP)
is used to set the registry key permissions correctly. Please fix the line
wraps (each line ends with /R).
@echo off
regperm /K HKEY_CLASSES_ROOT\Interface\{00000500-0000-0010-8000-00AA006D2EA4}
/I /S /A:Administrators:F /A:SYSTEM:F /A:"CREATOR OWNER":F /A:"POWER
USERS":WCRD /A:USERS:R /R
regperm /K HKEY_CLASSES_ROOT\Interface\{00000501-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000503-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000504-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000506-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{0000050E-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000512-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000515-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000534-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{0000054C-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{0000054D-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{0000054F-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000550-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000555-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000556-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000564-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000565-0000-0010-8000-00AA006D2EA4}
regperm /K HKEY_CLASSES_ROOT\Interface\{00000569-0000-0010-8000-00AA006D2EA4}
CLS
Now, does anyone know how to use VBScript to check the permissions on one of
these registry keys? I'd like to automate this solution to run the batch file
if necessary. And no, this
px) won't work because the administrative user can change the permissions
even though it appears that they only have READ access.
Wally Beck
Gainesville College
wbeck@xxxxxxxxxxxxxxx
