EMP Electro Magnetic Pulse
babou, Fri Dec 19 2008, 09:33PM
hello
i dont write good english, so i hope you can understand me.
i make a dream, i post it on other forum but none can help me.
my dream is to make a emp with the lightning, my idea is to make a lighting rod
with a coil. when the lighting touch the lightning rod the coil emit a very short and
power electromagnetic pulse (emp).
can anybody tell me if it can work and how to calculate the coil ?
Re: EMP Electro Magnetic Pulse
rp181, Fri Dec 19 2008, 09:54PM
What makes you think a coil would make a EMP more powerful then the strike its self? From my knowledge, EMP''s are produced with a straight conductor. Plus, theres these obvious issues:
1) safety. Trying to coax lightning to you is a death wish without proper knowledge
2) Lighting has extreme amounts of currents, that means a exploding coil.
3) the safety of a EMP pulse to nearby things.
4) practicality. Is it really practical for a hobbyist to make a lightning powered EMP?
big5824, Sat Dec 20 2008, 12:03AM
off the top of my head, an average lightning strike is about 50KA, which isnt much more than some large hobby railguns, so i doubt the pulse would be very large. Also containing the bolt will be difficult.....I imagine it might just arc through your insulation to short the coil out.
Proud Mary, Sat Dec 20 2008, 12:51AM
You will be killed!
Backyard Skunkworks, Sat Dec 20 2008, 03:16AM
If you want a strong EMP, you'll be much better off with something like
. Of course large EMPs are very dangerous, and you'd need to do this in a very remote area.
rp181, Sat Dec 20 2008, 03:38PM
Or not. Magnetic flux compresion devices require high explosives (NOT gunpowder), Specalized blast deflection shields to control the burn propagation, Highly precise timing of the igniter, and it all has to potted in a large block of concrete or something like that.
Sulaiman, Sat Dec 20 2008, 03:41PM
If you want a large emp fly a kite with a conductive wire/string during a storm.
You won't get much more than that.
P.S. could be hazardous ;)
Dr. H., Sat Dec 20 2008, 06:43PM
Or do what scientist do - fire a rocket with a wire.
Cheers
Backyard Skunkworks, Sat Dec 20 2008, 07:30PM
rp181 wrote ...
Yeah, good point. I guess there really arn't any non-suicidal methods for getting medium size EMPs (in between small marx gen and large nuke).
Shaun, Sat Dec 20 2008, 08:14PM
Read all posts by EastVoltResearch in
this thread. He explains how an amateur would go about building an inefficient but possibly effective EMP device. It's still no easy task.
babou, Wed Dec 24 2008, 09:52PM
rp181 wrote ...
i am newbie in electronic.
the lightning is "a marx generator", it make high voltage, but a marx generator without an antenna don't emit emp.
so the coil is the antenna.
the antenna (coil) transforms energy to electromagnetic.
Shaun, Wed Dec 24 2008, 11:37PM
An electromagnetic pulse is created by a very rapidly changing current (dI/dt). That's all. Having the energy to make it of effective duration and size is an entirely different factor. Lightning has a VERY high dI/dt and a huge amount of energy, so a very large pulse is created.
