The Hammertone T-BRISG V-Twin (move over, Orange county)
Finn Hammer, Tue Dec 02 2008, 08:13PM
Hi All,
A couple pics of a new coil I am current building:
Here are a couple key parts:
There are some really cool side covers coming, they are out for CNC engraving at Daniel`s woik.
And ofcourse guts and paint job still missing. Guts will be dual triggered BRISG, as subject sayz.
Put together all I wonder, does it look like a real nice long stroke V_Twin engine or a high voltage transformer, or do you have me figured?
Coz, this is what _I_ see:
Cheers, Finn Hammer
Dr. Drone, Tue Dec 02 2008, 08:42PM
Re: The Hammertone T-BRISG V-Twin (move over, Orange county)
rp181, Tue Dec 02 2008, 11:23PM
Lol dr.spark, every chance you get to show off =)
@finn
Thats awesome. Do those orange things cover the secondary (what are they?) Also, it looks slanted, is the left one shorter?
Andyman, Tue Dec 02 2008, 11:43PM
Well, showing off for Chris is more like him doing us a favor and posting free eye candy :P I'm glad he does
Anyways, from what I can tell, those are actually the secondary formers. You can see at the base of either the ridges are in the process of being sanded down. But you're right, they do look a bit sideways mounted on that hub.
Those things look AWESOME! Where did you get those, or what were they used for???
Dr. Drone, Wed Dec 03 2008, 01:02AM
Finn Hammer, Wed Dec 03 2008, 06:01PM
All,
The material for the orange pipes are "Ultra" sewer pipe. The ribs are removed on the lower half for the sake of looking like cylinders on vintage combustion engines like:
and of course:
It is a concept coil. The secondary coils are fitted inside this shell.
I did not make it a 45 deg V-Twin like harley and others, but stuck with the classic european 90 degree V-Twin.
Not so much to spite the harley, -it sure has it`s moments
but it would make the sparklength too short.
And this is about sparks, after all. And not the ones exiting the tailpipes of a maladjusted chopper. ;.)
The whole structure is rotated slightly around the crankshaft axis to simulate the looks of the Ducati:
But this was a mistake, really.
The "engine mounts" on the one side got flipped, when I welded the plastic bosses into the crankcase, and I didn`t notice it before taking the picture.
They will be reversed in due course.
Arcstarter, Wed Dec 03 2008, 06:08PM
Looks great!
This is a rather unique project, this is one coil you would want to show the.... everybody.
But one thing.. How the heck are you going to wind the coil with it being ribbed?
Tom540, Wed Dec 03 2008, 07:27PM
rp181 wrote ...
@finn
I was going to say the same thing. Haha
Finn,
Looks good what happens if the left coil wants to arc to ground instead of the right coil?
aonomus, Wed Dec 03 2008, 09:03PM
And on a similar note, what happens if the torroid of one coil arcs to the secondary of the other, or the two bases of the secondaries start arcing between each other...
Dr. Drone, Wed Dec 03 2008, 09:15PM
Finn Hammer, Wed Dec 03 2008, 10:05PM
Tom540 wrote ...
Finn,
Take a look at these twins:
It is a twin, viewed in it`s faraday cage half shell, before it is closed, at which point it looks like this:
The distance between spheres is 500mm, distance from anti corona ring to cage is 130mm.
I use these coils to judge the probability of a strike outside the strong field from +xxxxxxV to -xxxxxxV
Well, that probability is a very small one. You should all build a twin coil system, to enjoy the pleasure of having superiour controll of the discharge path.
The coil shown is one in a series of 2 that I built for the Danfoss Universe Theme Park, along with the big one:
The big one, by the way, is equipped with the novel remotely (by the show controller) operated preakout points, enabling a preprogrammed sequence of lightning bolts, each thrown in 1 of 6 directions spaced 30 degrees apart.
Cheers, Finn Hammer
And yes, All that gold _is_ gold, plated on copper.
Coronafix, Wed Dec 03 2008, 10:14PM
Finn: I take it that the coils will be bipolar and therefore arc to each other. Are you installing the primaries inside the secondaries? I assume this is the case otherwise primaries arcing would be a problem, although there seems to be enough distance there for outer primaries perhaps? Nice work.
Chris: Be a duck man and let it wash, you the man! Where would we be without you? No eyecandy that's for sure.
Tom: Triple posts are highly illegal and punishable by death...I think...I could be wrong on that one.
Edit: Wow Finn, that is some really nice work!! More please?
Dr. Drone, Wed Dec 03 2008, 11:42PM
Coronafix, Thu Dec 04 2008, 12:07AM
I wish you would show off some more Finn.
rp181, Thu Dec 04 2008, 12:16AM
O.o Where these made for yourself or institutions? they look great (shiny =p).
Dr. H., Thu Dec 04 2008, 07:45AM
Good day guys
Chris - don't buy what they are saying.
You have been helping HV members for years (including me) - for wich I REALLY THANK YOU
Finn - that thing is AMAZING
Hmmmm - can you implement something to look like a spark plug on the torroids ?
Cheers
Steve Conner, Thu Dec 04 2008, 12:17PM
Ooo, Finn is pimping the Danfoss Universe project! :D
I don't know what drives the twins, but I did the driver circuit and firmware for the big coil: it's very similar to my OLTC2. And the whole thing meets European EMC regulations.
Finn, how are you going to wind the secondaries on your coil? Or to paraphrase Quentin Tarantino, "It's not a Tesla coil baby, it's a chopper"
Dr. Spark, if you really want to impress me, you should mount a DRSSTC in your sidecar and fire it up at a bike show
Tom540, Thu Dec 04 2008, 05:39PM
Finn Hammer wrote ...
Tom540 wrote ...
Finn,
Cheers, Finn Hammer
That's pretty cool looking. I like all the bling.
Actually, now that I think about it you have a good point. The arcs primary goal is to reach the opposite end of the secondary not ground. Found this out by having a coil upside down close to ground. The arc still went towards the base even though it was further away.
Yes I know I just double posted again but the second post was actually on topic. They're better off separate.
Chris Russell, Fri Dec 05 2008, 12:56AM
Okay, I've deleted one post to attempt to keep things civil. Let's keep it on topic. Any further personal discourse can happen in PMs, or better yet, just forget the whole thing and let it be water under the bridge.
LithiumLord, Fri Dec 05 2008, 01:51AM
Chris Russell wrote ...
With a bit of deeper thinking this expression might sound both pretty funny and destructive :D
Nice concept, wonder how the finished version will look like. By the way, how are you going to trigger this one - by the same driver for both coils, via a simultanious firing mode or fire them off independantly?
Finn Hammer, Fri Dec 05 2008, 10:48AM
Steve McConner wrote ...
Pls. accept my apology for not mentioning off hand. This project had never come true without your groundbreaking brick OLTC.
The coils fit inside the tubes you see. The "cylinders" are 220mmØ inside and the coils are 200mmØ outside.
Btw, the primary coils are now finished rolled, and first acid bath. Material 2.5mm by 45mm.
Resonant with 10µF @ 44kHz
Rather low Q in primary, which is good and bad. Good for this coil, because it is going to drive external loads, so easier to tune.
Also notice nifty litle trigger SIDAC board on Brick
Trigger pulse is looped trough transformer of both bricks, for dual bipolar drive.
Cheers, Finn Hammer
Tom540, Fri Dec 05 2008, 05:23PM
I cant stop thinking about the gold toploads you have. I'm thinking of having one of the toroids i got from Daniel gold plated now. No more polishing!
Finn Hammer, Fri Dec 05 2008, 06:09PM
Tom540 wrote ...
Why not? It is not_that_ expensive. I think mine cost around 300US to have gold plated. Pretty cool if there is a budget.
Cheers, Finn Hammer
rp181, Fri Dec 05 2008, 11:37PM
I thought it was just gold color. Does the gold plating actually help alot?
Tom540, Sat Dec 06 2008, 02:48AM
Yes the one place I looked didn't have a listed price. 300 is sort of a lot for a small 8 inch toroid. If they could plate my 20inch aluminum for 300 i would totally go for that.
Finn Hammer, Sun Dec 14 2008, 05:52PM
All,
The primary circuit of the BRISG tends toward the complex, maby that`s why it never caught on.
Here you see the parts before assy`.
And this is what they look like when they are bolted together.
Quite a lot of tin smithin`and plastic weldin`.
Of course, mounting the whole kaboodle inside a cylinder, and aspiring ability to adjust coupling doesn`t simplify things....
And here it is: The primary coil gleefully awaiting the insertion of the secondary....
Cheers, Finn Hammer
Mads Barnkob, Sun Dec 14 2008, 06:30PM
wow... just wow :)
Its looking so proffesionel, really good job on all the parts!
What about the housing, will the metal or bolt not interfer?
Hazmatt_(The Underdog), Sun Dec 14 2008, 09:52PM
I love it! I am concerned about your assembly being held up by Nylon though. I'd probably go for some FRP screws.
Finn Hammer, Mon Dec 15 2008, 10:40AM
MadsKaizer wrote ...
wow... just wow :)
Thanks!.
Housing is PVC, bolts are stainless, so I don`t expect any interference.
What`s wrong with Nylon, what is FRP?
Cheers, Finn Hammer
Tom540, Mon Dec 15 2008, 06:59PM
The nylon is just holding the primary. I think it'll be fine. Looks awesome BTW.
rp181, Mon Dec 15 2008, 09:37PM
hmm, thought i already said this.
FRP is fiberglass reinforced plastic.
Finn Hammer, Mon Dec 15 2008, 11:23PM
rp181 wrote ...
Nylon has a tensile strength of 6Kg/mm^2, and those 10mm bolts have 48 mm^2 cross section, enabling them to carry 288Kg each, or 864 total.
I think that is ample safety factor.
The primary assy weights in at estimated 10kg max.
Sometimes it pays to do the math, although I tend to design according to the TLAR (That Looks About Right) method.
Cheers, Finn Hammer
rp181, Tue Dec 16 2008, 12:02AM
Tensile strength, but not shear strength. You need to see the shear ratings on those threads. Although if it was me, i too would also just try it and see what happens.
Also, Nylon absorbs moisture from the air, changing its dimensions. It probably wont be a problem, although it might matter in the future.
Coronafix, Tue Dec 16 2008, 02:12AM
rp181 wrote ...
So what. The shear stress will be 0.6 the permissible stress, and it's still well within safety region.
ragnar, Tue Dec 16 2008, 05:05AM
rp181 wrote ...
Not all Nylon -- Nylon-12 was hydrophobic last time I checked.
Herr Zapp, Tue Dec 16 2008, 09:10PM
Finn -
As usual, your design and execution are world-class.
A question for you about the attachment of the "cylinder mounting flanges" to the "crankcase". It looks like there is a substantial fillet or weld bead all along the junction of these parts. Are the parts secured to each other with adhesive, and this fillet is an external bead of thick adhesive (like RTV silicone or epoxy)? Or are they hot-air welded with a plastic filler rod? Or secured by some other technique?
Your "weld beads" look somewhat similar to the those seen in the plastic housing of Matthias Kallenberger's amazing HV transformers, which sure look like they were hot-air welded.
If you did hot-air weld the parts with a filler rod, how did you get what appears to be such a perfect color match between the housing and the weld bead/filler rod? Or is the apparent color match an optical illusion?
Regards,
Herr Zapp
Coronafix, Tue Dec 16 2008, 09:27PM
He already mentioned plastic welding.
Herr Zapp, Wed Dec 17 2008, 01:50AM
Coronafix -
Right you are, I missed that one photo caption that mentioned "welding". Still interested in how Finn obtained the color match of the weld bead to the base material .....
Also, you noted that the shear load on the nylon 10mm bolts securing the primary supports was 60% of the permissible stress. Can you provide any details of how you calculated the shear loading on these fasteners? 60% of the permissible load seems high, unless your calcs included some sort of dynamic load factor (e.g. accelerations caused by transportation via truck over a rough road, etc).
Regards,
Herr Zapp
Finn Hammer, Wed Dec 17 2008, 06:21AM
Herr Zapp wrote ...
Finn -
Regards,
Herr Zapp
Scott,
Thank you for your kind words.
Yes, all plastic is hot air welded, with filler rod.
I also noticed Matthias Kallenberger's work, and realised he could only do it, because he had learned hot air welding too.
It`s not at all hard to do, either.
Just keep the heat gun going right, @310deg celcius, and press 1kg on the filler rod, and it comes along nicely by it self.
Colour match is acheived by using a filler rod of the same colour as the base material, in this case RAL 7011.
But this is all going to get covered up, because after first light, the external parts are going to the car body shop for a covering with "as red as possible", like all proper souped racing engines are.
Cheers, Finn Hammer
Coronafix, Wed Dec 17 2008, 08:02AM
Herr Zapp wrote ...
Coronafix -
Regards,
Herr Zapp
You are absolutely right, it should have been 0.25 the permissible stress for shear stress rating.
Finn Hammer, Wed Dec 31 2008, 05:06PM
All,
First light is like giving birth to a dragon, and with the added benefit that it comes out in small pieces at the time.
But here it is:
I had promised it btwn. christmas and new year, so no time for the voltage doubler: With 780 Volts ringdown at 500BPS, it exeeded the spec. with 7 cm @ 147cm discharge.
With this I wish you a Happy New Year.
Cheers, Finn Hammer
Tom540, Wed Dec 31 2008, 07:11PM
WOW and that with just one BRISG module per side? Oh yeah and did you end up changing your primary?
Finn Hammer, Wed Dec 31 2008, 09:37PM
Tom540 wrote ...
No, just as I showed you all.
And don`t forget, just _one_ of these T-BRISG`s alone did 150cm (@4.5kA
Cheers, Finn Hammer
Tom540, Wed Dec 31 2008, 10:14PM
That's it i'm building a BRISG.
rp181, Thu Jan 01 2009, 12:09AM
:-O 'nuff said
Finn Hammer, Sat Jan 03 2009, 10:21PM
All,
V-Twin Popping corn with a limited set of instruments.
Cheers, Finn hammer
Finn Hammer, Sun Jan 04 2009, 08:22AM
All,
Sorry, forgot to reload. Thought I`d forgot to post. Those proxy servers are the damnest things.
Finn hammer
_____________
Myke, Sun Jan 04 2009, 07:46PM
Wow, Really nice job.
Finn Hammer, Sun Jan 25 2009, 09:24PM
All,
The V-Twin is a combustium engine.....
Cheers, Finn Hammer
Dennis Rogers, Sun Jan 25 2009, 09:55PM
Slightly OT but wouldn't it be better to plate topload with Ag (silver). It is the most conductive element and I have to think it would be cheaper to plate with than gold. Maybe you chose gold because it doesn't tarnish? Anyway awesome work, very jealous!
Dennis
Finn Hammer, Mon Jan 26 2009, 06:10AM
Flying Copper wrote ...
Dennis
The gold topload plating was for *looks* only.
The lack of tarnish was the main objective, but the associated exclusivism og **gold!** played a part too.
Cheers, Finn Hammer
Dr. Drone, Mon Jan 26 2009, 04:34PM
Finn Hammer, Mon Jan 26 2009, 08:38PM
Dr. Spark wrote ...
Henry called me this morning as stated “Have you seen Finn’s killer coil?†It is the talk in Arizona for sure; can you put in suit case and bring to the Thon? Hee hee
Great work sir, your work is always Top Dog!
Dr. Spark wrote ...
Only issue is you need RED LEDs under topload flashing with pulses, and a little smoke machine puffing smoke, hee hee.
Rgs,
Ch
You are right, of course. How can I argue against the master of the LED's. And so many other things.
Only problem getting power @ low voltage up there. Perhaps a couple of turns up there, and a led would do the trick?
On second thought, with 600V/turn, perhaps just make a necklace of plenty many leds around the coil up under the topload....
Damn, the coil is dismantled again already....But I'l have to try that sometime.
Cheers, Finn Hammer
Finn Hammer, Mon Feb 09 2009, 07:26PM
Just back from Paris, where I mounted the V-Twin into an installation by Swiss artist Roman Signer.
This is art to those that think so.
Thank you to Kurt Schraner for referring Roman and Jurg to me for this job.
I`l just give you'all some eye candy of the coil, at the moment drawing a pesky waveform, for 7.5 seconds at 2minute intervals, 12 hours per day for the next 70 days, starting 12-02-09, for 52.5 hours of total run time during the exhibition.
The guards are already getting nervous ticks just before each burst, so I fear vandalism more than dielectric breakdown or bonding wire fatigue (those CM600's are pulsed @ 2660Apeak).
This 1st. picture captures the impression that is available to the average joe, viewing the exhibition.
The rest are for you all, the invited l33t. =:-)
If all goes well, there will be a nice list of usefull performance parameters for the next generation of BRISG coils.
Cheers, Finn Hammer
Tom540, Mon Feb 09 2009, 07:33PM
Wow that looks great! I can't help but wonder what's with the umbrellas some sort of metaphor? I noticed the whole thing now site with the two secondaries symmetrical.
Keep it up!
-Tom
Finn Hammer, Mon Feb 09 2009, 07:36PM
Tom540 wrote ...
-Tom
Beats me. But with modern art, It is what it does to you.
Cheers, Finn Hammer
Tom540, Mon Feb 09 2009, 07:50PM
The coil is definitely an art piece on its own, no need for fancy umbrellas.
Finn Hammer, Mon Feb 09 2009, 08:05PM
Tom540 wrote ...
You may say so, but let's not forget that it is Roman Signer and the umbrella's that got the coils into the Palais de Tokio, not the other way round.
Cheers, Finn Hammer
GeordieBoy, Mon Feb 09 2009, 10:46PM
I like it. I think it looks really sinister with the sparks in the space between two hovering black umbrellas! I'm not surprised that is spooks the security staff!
From a scientific point of view it's cool how the toroids and the feed wires don't break out, only the tips of the two umbrellas. It's also good that the HV doesn't track over the surface of the cords up to the roof that the umbrellas are hanging from.
-Richie,
Finn Hammer, Tue Feb 10 2009, 07:15AM
GeordieBoy wrote ...
They were able to handle the looks allright. But the sound @100dB....
This is a function of pouring excessive amounts of power into the arc. During inithial tests, the nylon fishing line would melt due to corona tracking.
When power was increased, resistance of the arc channel dropped, so that it became the preferred path of discharge.
At least that`s how I see it.
The museum staff requested that I find out how to make the display quieter, but no matter what I did: pulse the arc with short pulses, but still connecting: Tracking was the immediate result, and umbrella was hanging in one cord.
Cheers, Finnn Hammer
Mathias, Tue Feb 10 2009, 08:40AM
Why not make some large plexi sealed tube with electrodes on both ends if "filled" with some low pressure gas (or mix)
that can greatly supress the sound of the discharge also the spark length could be way longer
Btw: beautiful work!
