garndening+ electronic
jameselectric, Wed Jan 23 2008, 10:28PM
okay I am a avid gardener as much as I love electronics. I got this idea out of bionics for the evil genius. The setup is a tesla coil I hacked up and wire to a variac. The voltage is set at 6 volts with a 50 ohm resistor in line for current limiting. Inside is a tomato plant. when the coil is checked with my cell sensor it is over 50 milligaus. I do have control plants. As much as I admire tesla sometimes you just gotta do a edison and try it your self
Re: garndening+ electronic
Shaun, Tue Jan 29 2008, 05:55AM
So this is to find out if a magnetic field affects a plant's growth? Sounds like an admirable experiment to me.
But remember being in that tube the tiny plant will be in the shade much more than control plants...
Myke, Tue Jan 29 2008, 08:13AM
Maybe have 2 plants (ideally more) in front of a wall thing and behind one plant you could put an electromagnet.
Just an idea
Shaun, Tue Jan 29 2008, 11:37AM
Or keep the test plant the same and put control plant in a de-energized tube.
