iPod problems
, Thu Mar 09 2006, 08:47PM
ive been using my moms comp for my i pod music, but there is a problem, her memory is running out, and i have a comp but when i plug my ipod in it says device not recognized. it charges the ipod btw too and i would like to put music on my computer as well and i need to know if i can force install the ipod with the usb? any help is greatly appreciated.
Re: iPod problems
FastMHz, Thu Mar 09 2006, 08:49PM
It sounds like the device drivers are missing. You need to install the software that came on CD with the player so the computer can recognize it.
Re: iPod problems
, Thu Mar 09 2006, 08:52PM
ok will do. but is there anything else i can do because the cd is with my cousin right now...
Re: iPod problems
Michael Witt, Thu Mar 09 2006, 11:00PM
You should be able to go to apple.com and download the drivers. I think it's under the "Support" tab.
Re: iPod problems
, Fri Mar 10 2006, 06:40PM
really? hell ya thank you i will go check, prolly take a while since i got to use a phone line but it is better than nothing
Re: iPod problems
, Sun Mar 12 2006, 05:34AM
i used the disc but it didnt help at all :( all it does is charge the ipod and then i cannot pull it up on a search for the computer
Re: iPod problems
Plasmaniac, Sun Mar 12 2006, 09:31AM
Do you use the USB oder FireWire cable to connect the iPod to your PC? For some reasons, up and downloading music or data doesn't work with FireWire on my desktop PC.
Re: iPod problems
, Sun Mar 12 2006, 09:52PM
no it is a normal usb port and i think its the high speed, but i tried with all of my usb ports and still nothing.
iPod problems
Michael Witt, Mon Mar 13 2006, 10:13PM
Do you use winblows or mac? If you use windows, click Start --> Run, then type in "msconfig" (without quotes). You'll see a tab called "Services", click it. On the bottom, there is a checkbox, just above the buttons, labeled "Hide all Microsoft Services", check it, it will make it easier to find the service you are looking for. Now look for a service named "iPodService" by some company named "Apple Computer, Inc." (who are they?
) If this service is not there, you will not be able to sync files with your iPod.
Re: iPod problems
, Mon Mar 13 2006, 11:05PM
well it is there but it says the status is stopped... also do i have to redo the drivers from the web? do i need to download the whole i tunes again, or is there a thing to just download the drivers? i will be looking but to download i tunes (updated) would take 10 hrs(dial up for my comp) Cable for my mom :( well im going to look for drivers in the apple downloads
