mini (soon portable) ETG !!!
Lomy, Tue Sept 04 2007, 04:10PM
heyho,
here's a little project i build today :))) . A mini mini mini ETG working with ~80j :) its triggered with a mini hf-ignition. ( like a teslacoil with just 10 sec. turns, which ionize the air , bla bla bla ... hope u know wot i mean :)(same as in a wig welding set )).
OK now time4pictures ;
and a little vid shooting with cotton wool :) :
Re: mini (soon portable) ETG !!!
teslaguy, Tue Sept 04 2007, 04:16PM
I googled for etgs and i found nothing...Is it a coil gun or what? Can you post a circuit diagram and better explain its purpose please?
Lomy, Tue Sept 04 2007, 04:41PM
a etg is an electic thermo gun, which use the mechanical energy of an elko to creat a little explosion and accelerate a projectile like a real gun : )
Lomy, Thu Sept 06 2007, 08:25PM
here a new vid shooting with it ;)
its in case, portable, 5 sec charging time, 118j and strong enough to shot through paper ;)
Lomy, Thu Feb 05 2009, 10:49PM
i finally finished the electrothermal gun =) after .. ahm over 1 year xD
total stored energy is 200j
the power level is really high, higher then any coilgun i build with the same energy input. i can shot throuh 2 thick tins and can make 1cm deep holes into houswalls (stone)
here some pictures of the plasma flame coming out of the barrel:
(the thing looking like a coil is pulstransformer for the trigger system)
and finally a demonstration vid:
Ultra7, Thu Feb 05 2009, 11:36PM
Totally cool!
I want to make one now.
I like the sound of it too.
teslacoolguy, Fri Feb 06 2009, 04:17AM
Wow that's cool. Wouldn't mind building one myself
rp181, Fri Feb 06 2009, 04:18AM
what are you using as a fuel?
Lomy, Fri Feb 06 2009, 09:42AM
i use nothing as fuel, its a pur plasma etg. the caps are discharged by a little lightning.
here is a little schematic, which show you the funktion :
rp181, Sat Feb 07 2009, 01:00AM
You mean a triggered spark gap? Or are you vaporizing some sort of metal?
DYI, Sat Feb 07 2009, 03:21AM
I believe that he's using a triggered spark gap switch which is inside the chamber, meaning that all the energy is delivered to the air inside the chamber. With only 200J of (presumably electrolytic) caps, this seems like a good idea.
Lomy, Sat Feb 07 2009, 01:40PM
here is a new pic:
and a new vid, shooting a nail 2 cm deep into wood!
j.azz, Wed Feb 18 2009, 02:52PM
Wow!
Judging from the muzzle flash you could even lengthen your barrel for higher efficiency?!
