DIY high voltage & high power transformer
Kizmo, Fri Jul 20 2007, 08:41PM
Things have changed, look latest posts
Re: DIY high voltage & high power transformer
Sulaiman, Fri Jul 20 2007, 08:48PM
If at all possible you should not introduce an air gap into the magnetic circuit
it will (dramatically) increase the current that the transformer draws with no load connected
and it will give poorer regulation (change in output voltage vs output current.
Can you take a photo' from the side ?
i.e. turn the transformer by 90 degrees.
Unless the laminations are welded together it may be possible to extract them.
Kizmo, Fri Jul 20 2007, 08:57PM
Laminations are just glued together. This transformer has quite thin laminations, about 0.3 or 0.4mm, that makes about 230 layers of metal. Friend told me that heating the core to 250-300 degrees C would make glue so weak that it would be possible to disassemble whole thing into hundreds of U and I shaped metal strips. Im just wondering how on earth that can be assembled backwards :D
EDIT:
Air gap could be minimized by carefully sanding (and then lapping with water sandpaper) both pieces so that rough bandsaw finish disappears?
Finn Hammer, Fri Jul 20 2007, 09:30PM
Kizmo wrote ...
The glue is lacquer, really. It doesn`t penetrate far in between the laminations. It is mostly on the outside. And it cracks easily-
Use a wood chisel to separate the lams, and pull them out with a heavy duty plier. The first 5 or ten will get bent badly. after that, when there is place, with a little care, you can easily get them out. Takes a lot of cleaning, though.
Kizmo wrote ...
EDIT:
Cut like you showed, and you will have to wind the coil directly on the core. A machine shop can surface grind the mating faces, but you cannot do it with the method you described. Being a toolmaker myself, I can assure you, that it takes a skilled metalworker to get the level of accuracy required, to reduce leakage flux to a reasonable level.
Go for it, nothing beats the feeling of winding your own!
Cheers, Finn Hammer
Kizmo, Fri Jul 20 2007, 10:20PM
Its true that nothing beats DIY HV things :)
I just ordered some copper wire for secondary (0.20mm, 2.6km) and some polyester based transformer insulation tape to insulate secondary winding layers (Dielectric strength: 7500 V) Now i just need to start building some sort of rev counter to my lathe :)
Sulaiman, Sat Jul 21 2007, 02:46AM
I really would go with Finn's method,
I've dis-assembled a few laminated steel transformers
the loss of one or two laminations in the extraction process
is far better than introducing an air gap.
Use a solvent to clean the laminations prior to re-assembly
Once re-assembled tap (HIT) the laminations together at the top and bottom
to make the E and I sections of each layer have as small an air gap as possible
to 'discourage' the magnetic flux from 'jumping' sideways from lamination to lamination
this will minimise losses due to eddy currents.
Then apply thin varnish and allow it to seep between laminations to hold them in place
and reduce hum/buzz.
Winding with 0.2mm wire and insulating with tape each layer will be quite tedious
do some research on winding techniques first
and make sure that you do not wind to the ends of the insulation or overall insulation will be difficult.
For the voltage that you are aiming for I would;
- varnish each layer before applying tape
or preferably
- use craft/brown paper instead of tape and immerse the whole transformer in oil.
Just because your transformer insulation seems ok for a few minutes (or days)
doesn't mean it will last for months or years.
If not under oil, the corona at 20 kV + will slowly 'eat' the insulation.
Hazmatt_(The Underdog), Sat Jul 21 2007, 03:57AM
You'll want to insulate for coil to coil breakdown too by placing several layers of an insulating material between the two, Cambric paper or Fish paper are good for this. Then you want to also insulate the HV coil from the core with pieces of the same paper on top and on bottom of the coil. This will reduce the risk of corona from the ends of the coil. I would go a step further and use some kind of silicone insulating material between the paper end cap and the coil as well.
Finn Hammer, Sat Jul 21 2007, 10:40AM
Insulation btwn. layers is one thing, and certainly a factor. with around 50 layers in a 20kV coil, there are 400 volts between layers.
Another, more urgent need, is acheived by the interleaving material: maintaining a winding without overlapping turns. Everytime you make an overlapping turn, you waste radial space for a whole layer!
There is limited space in a transformer, so each layer has to be filled with the maximum possible turns.
You _must_ put it under oil. You will realize this the moment you turn it on. there will be blue corona, buzzing and hissing like a beeswarm.
Hazmat:
If you have corona in an airgap, you gain nothing by adding solid dielectric. The field strength in the remaining (now shorter) airgap will increase.
The voltage drop across individual layes, in a sandwich of dielectric materials, is determined by the dielectric constant of the individual material.
Higher dielectric constant means lower drop.
Let`s say we have a 10mm air gap between 100mm balls. Breakdown voltage is 29kV in air.
So with 25kV across this gap there is no corona.
Now we introduce a 9mm thich slab of dielectric with a dielectric constant of 2,2.
The voltage drop across the solid dielectric becomes ~20kV leaving 5kV across the remaining millimeter of air.
50kV/cm in air is way into corona territory.
You cannot insulate your way out of a corona problem, unless you exclude the air completely. Oil is the easiest way, solid potting cured under heavy vacuum is another method
Cheers, Finn Hammer
Dr. Dark Current, Sat Jul 21 2007, 11:10AM
Finn Hammer wrote ...
Actually, for 20kv ac and 50 layers, there are 800 volts ac (or 1130 vpeak) between the two "ends" of 2 layers.
Finn Hammer, Sat Jul 21 2007, 01:50PM
jmartis wrote ...
Whoops, my bad.
Forgot the back and forth.
Thanks for reminding.
Cheers, Finn hammer
Kizmo, Sat Jul 21 2007, 05:21PM
I decided to take laminations apart, it was a lot easier than i first thought:
Sulaiman, Sat Jul 21 2007, 05:55PM
GOOD !
Now is the tine to look for a suitable container for the transformer and oil.
To save on oil and weight the container should be as small as possible.
That's a fantastic core and primary you've got there
worth making a good transformer.
Kizmo, Sun Jul 22 2007, 08:55AM
Transformer is now fully disassembled and it was success, all laminations are ok. Now i need to scrap all loose lacquer away.
Lets talk about transformer design, i know that there is a lot of math involved.
Specs of this core are following:
- 30.5cm^2
- 50Hz
- transformer was rated at 1200VA
I have lots of 0.20mm copper wire and im planning to make secondary HV winding with that stuff. What i need to know (or calculate) to get values for primary winding? Good www-site about transformer design for dummies would be great :)
Dr. Dark Current, Sun Jul 22 2007, 09:16AM
Kizmo wrote ...
(edit, I probably got something wrong)
Wrap 10 turns around the core, turn the transformer on, measure voltage across these 10 turns, divide by 10 and you have the volts/turn for your core.
Finn Hammer, Sun Jul 22 2007, 10:23AM
I am wondering about 2 things you wrote in the first post:
You write that there are 90 turns on the primary and that you intend to use half of it.
90 turns sounds unreal, a core like this will support around 0.9 volts per turn, so for 240 volts in, there should be 270 turns.
How to determine the total voltage sec. out:
You have 0.2mm wire, which probably measures 0.24 with lacquer?
Get some 0.05 mylar sheets to insulate each layer.
Each layer will fill 0,3mm
Measure how thick the total coil can be and divide with 0.3, you have number of layers.
Amount of turns per layer:
You cannot wind all the way to the end, but need to make some space for insulation. so the bottom layer will be like 10mm shorter than the core window, and the top winding will be like 40mm shorter.
________ooooooooooooo_________
_______oo
______ooooooooooooooooo_____
__
_____ooooooooooooooooooo______
____oooooooooooo
ooooooooo_____
___ooooooooooooooooooooooo____
In average, the windings will be 25mm shorter than the window length.
Subtract 25mm from window length, and divide by 0.25 to give windings per layer. now multiply by total layers, to give total amount of turns.
Multiply by 0.9 to give RMS winding voltage, and 1.41 to give peak voltage.
Hope this helps.
Cheers, Finn Hammer
Kizmo, Sun Jul 22 2007, 01:02PM
I was wrong with that, i thought first that there were only 1½ layer of primary winding but there was 3½ layers. So target should be around 0.9V/turn.
I haven't fully understand how important that Volts/turn ratio is. Im guessing it has something to do with efficiency/iron losses?
Sulaiman, Sun Jul 22 2007, 01:56PM
A couple of thoughts;
1)
Do you really need 20 kV rms
less voltage = much easier insulation.
Consider the final design of whatever it is that this transformer is going to power.
2)
No matter what voltage you decide on
it would be much easier to insulate/protect from corona
if you split the secondary in two.
e.g. Instead of one 20 kV winding (0V and 20kVrms)
use two windings, with a center-tap to ground/earth/0V (10-0-10 kVrms)
Kizmo, Sun Jul 22 2007, 02:03PM
Well, as you can see, this is my 1st DIY transformer project so please be patient - and im open for ideas - how you would do this :)
Finn Hammer, Sun Jul 22 2007, 02:39PM
Kizmo wrote ...
It has to do with flux density in the core.
A ferromagnetic material has a high permeability, therefore it increases the inductance of the coil that surrounds it. This permeability is linked to the flux density, in a way that is described by the B-H curve.
Initially, the permeability is low, than it increases and stays high untill the flux density reaches typically 1.6 Tesla (typical nos for transformer lams.)
Beyond 1.6 T, the iron saturates, and the permeability starts to drop.
If you apply more volts per turn than the core can handle, the flux density increases beyond the saturation level.
Then the inductance starts to drop, the inductance decreases, and too much current starts to flow.
The volts per turn ratio is the only parameter you need to know, to make a 50Hz transformer work.
The real beauty of a transformer is, that the primary coil has enough inductance to keep the current low, when the load reflected from the secondary is low.
How long is the winding window, and how wide is it from secondary core to primary winding.?
I`d like to teke a shot at a layout.
Are you still determined to put it under oil?
Cheers, Finn Hammer
Sulaiman, Sun Jul 22 2007, 03:03PM
I would;
1) Clean the laminations with a solvent such as petrol (gasoline) rather than scratch them up
2) Clean up and save the secondary wire - thick rectangular copper for winding is very useful
.....Coilgun, ring launcher, Tesla Coil primary ........
3) Decide what I want the final transformer for.
Here are a few suggestions with possible output requirements;
3.1) Jacobs Ladder. 5-0-5 kVrms to 10-0-10 kVrms
3.2) Spark Gap TC. 5-0-5 kVrms to 10-0-10 kVrms
3.3) Isolation Transformer. Dis-assemble a second transformer and use two primaries on one core for 230:230 Vac
3.4) Experiments with inductance; Bolt all the "U" sections together and bolt all the "I" sections together,
Put back the primary and secondary windings on the "U" section
3.4.1) with a 1.5V battery feel how powerful the "I" section is attracted to the "U" section for the two different coils.
3.4.2) put a neon across the 230V winding and briefly apply a 1.5V battery to the 12V winding,
with and without the "I" sections.
3.4.3) measure the current into the coil using 230Vac on the 230Vac winding
with different airgaps between the "U" and "I" sections
Consider how this could be used in series with a second transformer for current-limiting.
Requires current limiting
Anyone else got any good ideas for Kizmo ?
Kizmo, Sun Jul 22 2007, 03:28PM
Sulaiman wrote ...
1. Done
2. Done, got several meters of 8x3mm copper wire
Something like TC powersupply or Jacobs ladder (or both..) are in my mind. 10-0-10 kVrms could be done under oil?
Here are some measures from naked core before disassembly:
I saw somewhere this kind of setup with UI core:
I could use same kind of structure?
EDIT: I just realized that im running out of space here so 5-0-5 is more doable IMO
Sulaiman, Sun Jul 22 2007, 04:22PM
Yes you could do that;
if you re-assemble the cores nicely there's no need to re-do the primary,
just put two 5kV (or 10kV) windings on the other side.
Marko, Sat Jul 28 2007, 06:46PM
Hey, this is a beautiful core.
I would definitely save the primary (it is very nice) and build the secondary completely on the other side. Why you think to use half of the primary? Don't you have 230V available?
If you have the remaining bobbin you could also use it as a base for your secondary, although it will need a lot more insulation to be safe.
Kizmo, Sun Jul 29 2007, 05:57PM
I will use the old primary which has 229 turns to be exact. It is wound with quite thick wire (measures with lacquer slightly over 2mm). New secondary will be done with .20mm wire. How primary winding wire thickness affects to transformer features?
I had little shopping moment and already have these:
- 3.6kms (2.23 miles) .20mm (AVG 32) copper wire
- 0.05mm mylar sheets
- Thin urethane based lacquer for metal/plastic surfaces
My homemade winding machine (old lathe) is also operational, i have cheap step counter as turn counter. I Will take some pictures when things get rolling. (Ill start by making one half of sec winding)
Sulaiman, Sun Jul 29 2007, 06:44PM
The amp.turns for the secondary are usually a tiny bit less for the secondary than the primary,
and the current capacity of a wire is proportional to it's cross-sectional area,
so assuming your 0.2 mm wire is (like mine) actual copper diameter
and the primary is 1.8mm actual copper diameter
Then Ns = Np x (1.8 / 0.2)^2 = Np x 81
So an "ideal" transformer using 0.2mm wire would have 229 x 81 = 18549 turns
and a no-load voltage of 230 x 81 = 18630 Volts rms.
I'd be tempted to go with TWO secondaries of 10,000 turns each,
with an output voltage of 10-0-10 kVrms.
Under oil this transformer should be ok to 2500 W easily.
Kizmo, Mon Oct 01 2007, 07:03PM
Well, back to the old topic :)
I dont have anymore that core which i planned to use (actually i have it but it works as ballast now)
BUT i got even bigger core and some new ideas. I made one prototype like this:
Primary winding has too much turns still (im aiming to around 0.9V/turn). Each 'loop' has cross-section area of 18cm^2 -> inside the primary winding 36cm^2. MOT secondary represents HV winding and brown 2-turn coil is for measuring volts/turns ratio. Primary is done with AWG12 copper wire mainly because it was very cheap (10eur/200m from flee market).
So, what do you think, is there possibility that this could work, plan is that there will be 4 separate 5kV windings, two per 'loop'
Sulaiman, Mon Oct 01 2007, 08:13PM
I wouldn't split the core like that;
I'd do it like in the drawing that you posted Sun Jul 22 2007, 04:27PM
why?
each secondary winding in your new arrangement would get 1/2 the primary flux
so each secondary would require 2x the number of turns compared to the drawing of Sun Jul 22 2007, 04:27PM
for a given voltage.
You will be using more wire than neccessary hence heavier, costlier and most importantly, less efficient.
AND
the flux coupling between primary and secondary would not be as good
so the output will appear to have some inductance in series with it
reducing the maximum output.
The old true and tried methods are often best!
Shaun, Mon Oct 01 2007, 11:57PM
There's a reason why E-core transformers have both windings on the center part (see MOT). If you trace out the magnetic circuit in the core(s) you will see that half of it is essentially a "short". As Sulaiman said, the secondary only gets half possible flux.
Kizmo, Sat Jan 26 2008, 12:04PM
Now its finally time to actually *do* something, not just speculate :)
Recently i acquired even bigger core, this time it has a lot of space for windings. This will be the final thing:
http://koti.mbnet.fi/kizmo/misc/muhennin/220108/kokovertailu.jpg It measures outer dimensions of 25cm x 25cm x 8cm and has cross-section area of 40cm^2.. and weights like hell for my broken back.
Today i will assemble that core with polyester resin. I haven't decided yet will it be 'dry' or oil insulated thing, it depends which i will get easier; high voltage mylar/kapton plastic or proper transformer oil. I have build several tools for assembling this core, it wont be easy to align laminations exactly when you have only 10 minutes before resin starts to harden. So everything *must* be dead-on planned and built.
Main points of design:
- 240V/400V primaries
- Total secondary voltage 15kV-20kV
- It must be constructed so that if(when) sec. insulation fails, i can disassemble it for repair without jackhammer
- Oil is not problem, but it does make things a bit oily.. eww
Dr. Dark Current, Sat Jan 26 2008, 12:29PM
Kizmo, that's scary, where did you get that core? O_o
And what do you plan to use the xfmr for when it's finished?
Kizmo, Sat Jan 26 2008, 12:41PM
jmartis wrote ...
That was main xfmr from 8kW UPS (3x 380/415V -> 3x 129V @ 7820VA). It was 3-phase transformer but i modified it by cutting center 'leg' away from each lamination to make more space.
http://koti.mbnet.fi/kizmo/misc/muhennin/210108/purettu.jpg http://koti.mbnet.fi/kizmo/misc/muhennin/220108/leikkaus.jpg It will be used as multi-purpose high voltage transformer (arc pulling, jacobs ladders, burning stuff etc) and maybe with spark gap teslacoil. Secondary will be done with .3mm magnet wire. I would be a lot easier to just buy PT or small PIG but they are *really* hard to obtain here and almost impossible to buy because of health and safety regulations.
Logan Kennedy, Sun Jan 27 2008, 12:33AM
Wow, that thing will be a beast when complete. Very dangerous indeed.
Dr. Dark Current, Sun Jan 27 2008, 07:54AM
I've just read this, with 40cm^2 the core is good only to about 1.6KVA continuous on open air. Maybe a little more with active cooling.
Kizmo, Sun Jan 27 2008, 10:42AM
I know the math, but that is weird, i have one 4kVA transformer (200V -> 606V) which has 38cm^2 core
Dr. Dark Current, Sun Jan 27 2008, 12:18PM
Kizmo wrote ...
and is it for continuous use? I have one xfmr from 300W UPS which has ~10cm^2 cross section...
Kizmo, Sun Jan 27 2008, 12:24PM
I have no idea. I will 'overpower' this core heavily because it won't be running for hours.. never
