Vertical primary winding?
Conundrum, Sun Jun 17 2007, 11:30AM
Hi all.
Just wondered about this one. Instead of winding the primary in a flat spiral, how about obtaining a cylinder of larger size than the secondary, cutting regular slots around the top and bottom with a slight offset, then winding the primary on this?
might work well for smaller coils, and allow more primary turns in the same area.
regards, -A
uzzors2k, Sun Jun 17 2007, 12:41PM
Do you mean a helical coil? Those are quite common, especially on SSTCs and DRSSTCs. See
Re: Vertical primary winding?
Nik, Sun Jun 17 2007, 02:45PM
I've used both on my 6in SGTC and the helical coil worked very well but there were flashover issues that I couldn't get under control.
