I have 80ft of 0.625" and 50+ft of 0.875" 75 ohm coaxial cable. I can get far more in somewhat longer lengths too if anyone is interested. These measurements are the diameter of the outer conductor which is solid aluminum tube, no braid. The total outer diameter with PVC jacket is 0.695" and 0.950" respectively. The inner conductor is copper clad aluminum with foamy PE insulation. Manufactured by Commscope, model unknown. It just reads "COMMSCOPE ACT" and has the feet labelled off continually. It is also dated 2005. I can also get some with just an aluminum jacket and no outer PVC. I don't know if there is any 50 ohm stuff around but I highly doubt it.
Contact me with any offers if you're interested, I will accept check or money order.
