Micro DRSSTC finally done
ShawnLG, Sun May 20 2007, 06:41AM
I am done building this coil and i had killed enuff fets in the process. I went for the complete DR style because it worked better than the series-C and the series-L matching networks configurations. One of the fets die when a streamer strikes an object with significant capacitance. I think this causes the secondary to go out of tune and causes the "Q" of the primary to go high and draw a lot more current in the LC. I have never attempted a ground strike and would not risk it. Below is a pic of the advanced GDT driver with Duel Drive Technology.(TM) Front and back pics of the inverter power board.
The coil in action!
Re: Micro DRSSTC finally done
ragnar, Sun May 20 2007, 07:13AM
Cool design and boards, Shawn. I like the use of the SMT components in there.
uzzors2k, Sun May 20 2007, 08:15PM
Awesome work once again. That coil just gets better and better! I don't understand how you guys bother with SMT, I just hate them.
ConKbot of Doom, Sun May 20 2007, 08:39PM
Uzzors wrote ...
Once you can make good boards, its easier to do SMT then to bother drilling holes though the board ;)
Tom540, Mon May 21 2007, 06:42AM
I love SMT i just dont use it as much because i have like billions of through hole resistors.
ShawnLG, Mon May 21 2007, 05:31PM
I like to use SMT components for final projects because it is smaller, cheaper and the 7400 series SMT ICs are easier to find the the old through hole ICs. Plus the through hole are harder to desolder. Since the 7400 series through hole IC are rare to find now, I try to save them for prototyping only.
