running a tv cascade of a 15kv 30ma nst
Download, Mon Mar 12 2007, 01:24AM
hi all
i was wondering if a tv cascade would die if i ran it off a 15/30ma nst? i have two of them but i dont whant to kill them and what would the output voltage be (aproxmate)
would this work?
Re: running a tv cascade of a 15kv 30ma nst
Nik, Mon Mar 12 2007, 01:29AM
I would think it would not work because TV cascades are meant to run off the HF output of a flyback not a 60hz transformer.
Download, Mon Mar 12 2007, 01:32AM
its 50hz in australia
..., Mon Mar 12 2007, 03:27AM
Like Nik said, the frequency is much too low to get any decent output from a NST.
The flyback runs at 15khz, as opposed to .05khz that your NST runs at, which (due to the design of the cascade) will only get you a tiny fraction of the power you could get using a flyback.
It is possible to make a doubler/tripler/ets for a NST, just get yourself a
bag of 500 in4007's and some doorknob caps (or any string of caps good for 30kv) and start making doubler stages.
see
for more info.
Download, Mon Mar 12 2007, 03:30AM
i have go 10 30kv doorknob caps and i need to get the diodes
nainehctik, Mon Mar 26 2007, 10:25PM
... wrote ...
see
for more info.
wont those diodes fail since you are far exceeding their max voltage rating?
..., Mon Mar 26 2007, 10:53PM
You string a bunch of them in series (input KV * 2 is usually enough, probably best to use 4 for an added safety margin) which raises the max voltage
Hazmatt_(The Underdog), Tue Mar 27 2007, 01:18AM
Don't forget some ballast resistance on the output stage to limit the current.
