Lookin' for some high current Low voltage diodes
EDY19, Thu Dec 07 2006, 10:36PM
Im trying to find a couple high current diodes with no need for any high voltage requirements. Im planning on trying some electrolysis to get some small quantities of Na metal. Just as a proof of concept type project. Voltage ratings don't NEED to be over 30V, but they can be. Current ratings- im looking for over 50A just to be safe, or multiple diodes, using a rewound MOT for about 10V or so. I really have no idea how much current I will be pushing yet. It seems as if i saw someone else here doing a similar large scale project, which is where i got the idea from.
..., Thu Dec 07 2006, 11:59PM
50a isn't all that much current, and if you are not worried about voltage drop across the diodes just about any stud or to-247 diode should do the job no problem...
these should do the trick abit being way overkill for voltage...
Re: Lookin' for some high current Low voltage diodes
EDY19, Fri Dec 08 2006, 12:23AM
Thats just the thing, im not sure how much current to expect, and diodes really aren't all that expensive, so i can overrate it and decrease the Vdrop with a higher current diode.
Marko, Fri Dec 08 2006, 12:35AM
You have some great schottky diodes in PC SMPS's.
They are usually rated 40A or more and there are two in each package; since thermal coupling is good they are also paralellable.
You are building a down's cell?
ReddyK, Fri Dec 08 2006, 01:51AM
I have a hand full of skr 46/12 if your interested.
Thanks,
Steve
