Hi, this is my 4th Tesla Coil, but it's the first time that I post on 4HV. What I have built is a small musical Tesla but, if I'm not wrong, containing some innovation. Generation of CW waveform is quite standard, with a MOSFET half bridge and doubly resonant architecture, but modulation scheme is based on a variation of sigma-delta modulation, which is carried on in software inside an ESP32 embedded module, with output on the I2S device. Sigma-delta modulation is used to drop driving cycles and hence get modulation of the output. I have just posted an article here to describe the project: * The ESP32 firmware doing the coding is stored here: *
Here is a video in operation:
Roberto IW3IPD
Re: Sigma-delta fully digital musical Tesla Coil Patrick, Sun Jul 19 2020, 08:30PM
this is amazing. first rate effort. im trying to use that same WiFi module but dont know how.
Re: Sigma-delta fully digital musical Tesla Coil RoV IW3IPD, Sun Jul 19 2020, 09:13PM
Patrick wrote ...
Patrick, the ESP32 is quite easy to use with Arduino IDE and libraries, particularly for Wi-Fi. For this project I had to use the Expressif SDK, which is a bit more complex, because I needed more flexibility for I2S and because there was a demo for Bluetooth to start with.
Roberto
Re: Sigma-delta fully digital musical Tesla Coil Patrick, Tue Jul 21 2020, 08:26PM
Is it possible to use the device as a "pin-to-pin-bridge" between two uC ?
Re: Sigma-delta fully digital musical Tesla Coil RoV IW3IPD, Tue Jul 21 2020, 09:30PM
Patrick, I think this is a bit OT... there are many forums on ESP32. However, if I understand well your question, yes you can use it as a Wi-Fi or Bluetooth extender for another uC: you just need to code an intermediate protocol and drive I/O lines as you want.
Re: Sigma-delta fully digital musical Tesla Coil Patrick, Wed Jul 22 2020, 01:00AM
i have the esp-12 / esp8266. it looks like a 28 pin dip board.
Re: Sigma-delta fully digital musical Tesla Coil Terry Fritz, Wed Jul 22 2020, 05:25AM
In my day, I used a Basic Stamp to control my DRSSTC...
But now, the chips are super powerful!!!
Also had to use fiber optic cables... But Bluetooth is super "noise" immune.
Born too early :D
Great work you are doing there!
Terry
Re: Sigma-delta fully digital musical Tesla Coil Terry Fritz, Thu Nov 12 2020, 04:04AM
You need to turn off the sound from the phone and only play the coil's music...
