a magnetics question
Sulaiman, Fri Feb 15 2019, 11:33PM
Where would most of the magnetic flux be in an air cored solenoid close wound using insulated iron wire,
or in a partially stretched slinky ?
what would the field look like?
A quick google produced nothing but I'm sure I read something in the past,
I'm off to do more searching but I thought that this may be a nice mental puzzle hence this post.
If you already know ... what is the answer ?
Re: a magnetics question
2Spoons, Sat Feb 16 2019, 11:20PM
Download FEMM4.2. Its a freeware 2.5D mag/electro/current/thermal field solver. That will tell you all you need to know
radiotech, Thu Feb 21 2019, 09:43AM
I do not the answer but I feel if you googled
the term Helmholtz Coil it would be know.
I do know I have two Helmholtz coils here.
Sulaiman, Thu Feb 21 2019, 05:24PM
Generally speaking I can imagine field shapes;
bar magnets, short or long solenoids, transformer air-gaps etc
If the wire was copper then I'd just treat it as a solenoidal winding,
if the iron wire is laid along the air cored flux lines then I can imagine it,
or even as an iron helix inside OR outside of the winding,
but when the winding wire itself is iron ?
Proud Mary, Fri Feb 22 2019, 11:55AM
Something like this perhaps:
