personnal X Ray machine
paulj, Mon Feb 04 2019, 08:17AM
Hello,
for create film photography, I'm going to build an x-ray machine.
the tube: 2BDM4-75
-75 kv
-2kw
-air cooling
I am aware of the risk with radiation,
For the safety, I have an industrial power supply 9 kw + two Variac 0-230v with emergency stop, circuit breakers and protections against electrocutions.
Â
I haven't yet designed the electrical scheme high voltage
I take any advice to improve the performance without using the already old tube (1961).
Who has experience on these constructions here ?
Paul
Re: personnal X Ray machine
paulj, Thu Feb 07 2019, 07:33AM
My first question:
for the high voltage power supply, I've to use 75 kv for 30 ma, starting from an alternative source 230v 50hz
what power supply do you recommend?
-the classic transformer with rectifier (very expensive)
-the voltage multiplier (cockcroft walton multiplier for example)
Paul
Sulaiman, Thu Feb 07 2019, 10:02AM
I know only a little in this area, but 30mA seems to me to be unnecessarily high?
Lower current would require longer exposure times
but would be 'safer' in terms of x-ray exposure rate
and reduce the cost (and possibly the hazard also) of the power supply,
and cooling of the x-ray tube would be much easier.
(75kV @ 30mA = 2250 Watts ... a lot of heat ! )
A voltage multiplier fed from a fairly high voltage ac source sounds do-able if currents are low,
75kV @ 30mA sounds expensive.
I would not try to diy a 75kV transformer as failure is likely,
the obvious choice is an x-ray transformer ;)
Conundrum, Fri Feb 08 2019, 07:11AM
Same here: you do need to limit the current ideally with a dropper in the 1G ohm range.
paulj, Sat Feb 09 2019, 06:59PM
hello,
thank you for your answers:
I can't find a transformer, they are very expensive and big.
The tube is old, I will not take any risk and limit the current.
So
I'm thinking of using a voltage Steve Ward multiplier :
the old design seems solid in time.
the only constraint, I want to stay on a frequency of 50 hz to adapt it to my safety system.
Proud Mary, Mon Feb 11 2019, 08:39PM
(a) I think you will find this is an oil-cooled tube - not air-cooled.
(b) 75kV/30mA is the maximum rating.
(c) The anode current should be controlled by varying the heater current.
(d) I would suggest you set it up for operation at 35kV/1mA. Shielding costs will be much lower, and you will not have to worry too much about the anode heat capacity. Exposures will of course be much longer, but this is not usually a problem with inanimate, unmoving targets.
paulj, Tue Feb 12 2019, 05:52AM
A) yes I know it is oil cooled, but the message refuses to be edited when I valid
b) ok
c) for the heating of the filament, to associate a cockroft walton (high voltage) and a conventional transformer without rectifier (heating filament), there is no risk to connect the common terminals of the two dipoles (destruction of the filament)?
d) Indeed, the objects will be inanimate, this power seems reasonable to me
Proud Mary, Tue Feb 12 2019, 08:41PM
Setting the anode current needs accurate, incremental, control of the cathode heater current.
I have found that the most reliable way of controlling the heater current is by using simple old-fashioned technology using a 10 ohm 100W wire-wound ceramic variable resistor. I measure both heater voltage and heater current with moving coil meters. Of course, the variable resistor wastes a lot of power, and may get very hot (for which it is designed) but there are no vulnerable semiconductors to be destroyed by the voltage spikes that so often appear in high voltage apparatus.
There is no need for an expensive, giant power supply. Why not start off with 25kV DC from a TV line output transformer (LOPT) often called a 'flyback'.
I also monitor the anode voltage using an electrostatic voltmeter. These are not easy to find at a good price, but I think it essential to know what the actual anode voltage is at any heater current setting.
This is why: home made high voltage power supplies often have very poor voltage regulation, and as the current demand rises, the high tension voltage (HT) (haute puissance) falls, so the anode voltage is very often much less than the experimenter thinks it is.
A good LOPT/flyback will be able to deliver 25kV DC at 1-2 mA without the voltage falling very much. If your power input is 25W - 50W then you will have 250mW - 500mW of X-radiation, which is plenty to start your experiments.
Shielding: ,
the depth of penetration for a given photon energy is dependent upon the material density (atomic structure). The more subatomic particles in a material (higher Z number), the greater the likelihood that interactions will occur and the radiation will lose its energy. Make sure you understand the half-value layer formula, so you can work out how thick your shielding needs to be. With a maximum photon energy of 25keV, you may find that layers of aluminium sheet will be sufficient.
Good luck!
paulj, Wed Feb 13 2019, 06:20PM
thank you fier Mary
for the rheostat:
- Or I pass the 230 v directly in the dipole for limit the current, and therefore the heat.
- or lower the voltage a first time with a first transformer (which replaces the original autotransformer too dangerous) before the rheostat, then use a second transformer before the filament
so I think to manufacture a command deported with a servomotor not to handle it directly the rheostat by hand.
I don't have the money for an electrostatic voltmeter, I think to use a resistance divider between the anode and the ground, or to use a voltmeter class 2.5, the carbon resistances will make the case.
I do not know the mathematical formulas of armoring and my geiger counter is not compensated in energy for the measurement.
So I'm going to exaggerate the security. In addition to the lead, I would be several meters away.
I agree to start with a small TV power supply.
 I don't learned to use power electronics in next situation, that's why I would like to use a voltage multiplier without semiconductors
paulj
Proud Mary, Wed Feb 13 2019, 11:45PM
I would suggest you plan to vary the cathode heater voltage across the range 1V - 5V. I use DC myself, as this means I can connect one side of the heater to Earth/Ground.
I would not feel happy if the heater supply was floating with respect to Earth/Ground.
It does not matter how exactly you monitor the anode voltage, just so long as you can see what voltage you have on the anode as you vary the cathode heater current.
Conundrum, Thu Feb 14 2019, 06:28AM
Yes, this is the same problem I had.
Interesting idea: what about using a linear device like an LED array? Calibrate elsewhere and then measure it using optical fibre eg TOSLINK cable. Known length of cable should be pretty accurate.
Proud Mary, Thu Feb 14 2019, 12:12PM
I don't understand your contribution, Andre - have you by chance posted it in the wrong thread? :)
Conundrum, Fri Feb 15 2019, 04:59AM
This was to do with monitoring voltage and current remotely.
paulj, Fri Feb 15 2019, 06:37AM
the idea of optical fiber is interesting, but for economic reasons, I will be content with vintage analog voltmeter with a simple resistance voltage divider and transmit coaxial cable.
Proud Mary, Fri Feb 15 2019, 02:01PM
paulj wrote ...
Take care that you do not have more current going into your voltage divider than into your tube! When your power supply can supply only a few milliamps this can be a serious issue!
In practice, you may find that the current drawn by the voltage divider has the effect of pulling down the voltage available to the anode, so do your Ohms Law calculations carefully before deciding what to do! :)
paulj, Fri Feb 15 2019, 03:51PM
I take notes:)
paulj, Wed Feb 27 2019, 07:57PM
first test with flyback transformer.
johnf, Thu Feb 28 2019, 05:46AM
Ho boy
I hope you were no where near that
uSv/hr is not the correct range to be on uSv/min or uSv /sec would be much better --read quicker to a determination. I see that the output was still going up as you turned it off
CAREFUL
You do not want a suntan from that!!!
Conundrum, Thu Feb 28 2019, 06:37AM
Indeed. Been there, done that. Also low energy X-rays are even more damaging.
There is a good reason why the window on some commercial tubes is made from beryllium, it is to block the useless X-rays below 9keV and changing the window eg for tungsten changes the pass energy.
paulj, Thu Feb 28 2019, 07:11AM
oh yes, the translation!
I am 5 meters behind a block wall, and the opposite of the radioactive beam.
paulj, Fri Mar 01 2019, 08:29PM
hello,
After reflection, and the first success at 170w, I will increase the power to reduce the exposure time that seems too long.
I will increase the voltage of the cathode, in order to have more penetrating and more energetic rays,
the first test was at 20 kv dc, I go to 40 kv dc.
Because of the high price, I continue to make the dump in order to find the necessary material to build a robust chassis, I hesitate to add a berylium window in order to block the energy "soft" rays and to improve the beam quality for photography.
my priority is safety, so here are the measuring instruments that I want:
- kv meter, and ampermeter for the cathode
-voltmeter and ampermeter for anticathode
- dosimeter (a geiger counter is not reliable)
paulj, Tue Jan 14 2020, 07:44PM
hello, finish after 2 years !!
paulj, Sat Jan 18 2020, 06:17PM
spec of exposition
measure with EPD mkii graded with cs137
voltage working
-40kv 8ma
-filament: 5v 3a
results at 3cm of tube without colimator (10s exposition )
-hp10 1 Sv/h
-hp07 13 Sv/h
measure on the side tube at 6m with berthold lb1210b: 200 cp/S
