Long USB Extenders (Active kind).
Patrick, Fri Dec 28 2018, 09:06PM
do any of you have experience with long USB cables ?
i dont want to depend on normal 16 ft (5m) passive cables that seems long even though they make them, i still need to plug in the original device cord of 3 more feet (1m). so I bought both (the active repeater one). im just wondering if anyone has had issues or knows of any quirks that pop up.
Re: Long USB Extenders (Active kind).
2Spoons, Sat Dec 29 2018, 05:57AM
I've used them and not had any issues
the_anomaly, Sat Dec 29 2018, 01:48PM
I've also used them. The cable with integrated hubs worked fine for me. I bought an extender consisting of two ends that the user was meant to plug an RJ45 cable into (up to 100ft?) and it was DOA.. though I suppose that is just rotten luck. My communication is slow, USB 2.0, 9.6kbaud.
Avalanche, Sat Dec 29 2018, 07:41PM
Unless you're willing to pay a premium, the USB over ethernet adapters are typically limited to USB 1.1 speeds so will rarely work with anything nowadays.
I spotted this when I was going to use cheap webcams as security cameras, ended up buying ethernet cameras instead.
