Has anyone else experienced strange events when testing a new build?
Included: equipment malfunctions, unexplained lights appearing near the coil(s), etc. Ideally post pictures or schematics of the setup.
Thanks, -A
Re: Add your strangest TC phenomenon here dexter, Mon Aug 21 2017, 08:43AM
Does the test has to be performed in an old castle, in an abandoned mental hospital or in old houses where unsolved murder/s happened?
Re: Add your strangest TC phenomenon here Finn Hammer, Mon Aug 21 2017, 07:08PM
Andre,
During the initial tests of the Musical Tesla Coils, I saw "magic smoke" emanating from the base of the coil, followed by an apparent malfunction.....
sorry, just couldn't resist...
Cheers, Finn Hammer
Re: Add your strangest TC phenomenon here Mads Barnkob, Tue Aug 22 2017, 06:44AM
Dimming lights and destroyed voltmeter when shorting mains directly into a high impedance inverter with current draw way out of phase.
But no, never anything strange, just stupid :)
Re: Add your strangest TC phenomenon here Hydron, Tue Aug 22 2017, 11:24AM
I managed "half" blow-up one port of my router.
It was completely unconnected to anything the coil was other than the mains (via plugpack), but one of the ports (the WAN port) stopped working with certain devices (e.g. the modem I was using). When I remapped the WAN port using custom router firmware to another port of the router, the "broken" port turned out to be happy talking to certain other devices, but not the modem or a couple of other things.
The other thing I managed to blow up was a plant - despite never being hit by a streamer (it was opposite to the breakout point) it was reasonably close to the coil, and clearly some high frequency current was flowing to ground through it. The top was juicy leaves (plant was a succulent) but the long thin woody stem was obviously high resistance - it started charring and then burnt right through from the I2R heating!
If you want you can maybe concoct some router port conspiracy theory, but unfortunately the plant death is pretty explainable!
Re: Add your strangest TC phenomenon here Hazmatt_(The Underdog), Thu Aug 24 2017, 12:57AM
While I was testing, I managed to have my keys and a pocket knife in one of my pockets, and I was getting shocked by it, or my keys, or a combination of the two, not sure why.
That's not really all that strange, but it was a surprise!
Re: Add your strangest TC phenomenon here Nik, Fri Aug 25 2017, 02:16AM
About 10 years ago I was running my SGTC in the back yard and it set off the neighbor's backyard/outdoor doorbell. I didn't think much of it until it continued to ring after I turned off the coil and the whole time I was packing up my gear. Didn't hear it again after that day...
Re: Add your strangest TC phenomenon here orac12, Wed Dec 12 2018, 02:40AM
Computer screens would turn off and go into sleep mode when coil was running, and computer would beep as if a USB device was being plugged and unplugged.
Also someone who was with me while operating it that has a few metal rods in their body due to broken bones etc could feel some sort of tingling or burning sensation inside where the rods are.
Re: Add your strangest TC phenomenon here nabzim, Wed Dec 12 2018, 06:10AM
When I play with my SSTC I usually feel small shock/burns on my nose from my glasses frames' nose-pads. (because my face is usually like 1-2 feet from the topload).
I also used to get the USB sound, but I stopped running my coil in my bedroom where my pc is. (better safe than sorry)
ALSO..... I used to run a Bitcoin miner (Bitmain S9) in the same room where I run my SSTC now... I turned it off and unplugged it before turning on the coil, but when I turned the miner back on, there was an error in the firmware startup sequence (something about "PIC need restore") and the miner was pretty much a goner, no matter how many firmware re-flashes I tried. So luckily, I live in California where the only Bitmain warranty-center outside of China happened to be located, so it didn't take long for shipping... Needless to say everything checked-out OK on their end (they obviously didn't find any signs of user-damage), so they repaired it under warranty... ;p
Based on the OP of this thread, I was hoping to read something along the lines of: "One night I was running my coil out back, and all of a sudden colorful lights appeared in the sky, and little green men materialized out of thin air, taking me aboard their flying saucer!" Thankfully, nobody here is THAT crazy..... Hahaha
Re: Add your strangest TC phenomenon here Sulaiman, Wed Dec 12 2018, 10:32AM
Some years ago I made a fairly large sgtc that when operating caused humans to walk backwards and scrunch up their faces, that particular tc also had a profound effect on the weather, almost every time that I assembled it in the garden then operated it, it would start to rain.
Re: Add your strangest TC phenomenon here Benjamin, Sun Dec 23 2018, 07:07AM
A few years ago when I was running my dual MOT magnifier, a 5 foot streamer hit the edge of a window and the whole window shattered but stayed in place completely full of cracks. I've never heard of a tesla coil shattering windows before. Has anyone ever had this happen before?
Benjamin
Re: Add your strangest TC phenomenon here tuopeek, Wed Feb 13 2019, 08:24PM
I suspect some VTTC testing in CW mode may have caused false alarms on a security system nearby..
Re: Add your strangest TC phenomenon here paulj, Wed Feb 13 2019, 10:26PM
Hi, a gopro placed at the level of the rotating spark gap goes off when the Tesla coil was work.
Re: Add your strangest TC phenomenon here E.TexasTesla, Mon Mar 11 2019, 02:48AM
One night I was running a version of Steve Wards Mini sstc. I had an old laser pointer (the cheap ones you buy to play with cats) Just for fun i placed it on top of the toroid them turned on the coil. It fired right up and had a visible red dot on the wall. No batteries were in it. I have seen LEDs glow bright while near the coil but they had to be held so as to provide a path for the RF.
Would be a cool disco ball effect if you glued 100s of cheap laser diodes to the toroid.
Re: Add your strangest TC phenomenon here Conundrum, Tue Sept 03 2019, 06:06AM
Interesting! Wonder if "Dead!" laser diodes will work again if put on a coil?
Re: Add your strangest TC phenomenon here nzoomed, Sat Dec 21 2019, 01:22AM
My computer still freezes quite often with my tesla coil running, have no idea how to shield the USB properly. I wound a few turns around a toroid on the usb cable to the midi controller, and helped a little.
Not helpful when im trying to play tunes through it!
Re: Add your strangest TC phenomenon here Conundrum, Sat Mar 07 2020, 09:17AM
Force beam effect. Still never explained that one!
Re: Add your strangest TC phenomenon here E.TexasTesla, Tue Jan 11 2022, 02:48AM
Older topic but I found another strange effect while operating a medium sized SSTC. I was curious about voltages at the base of a secondary coil to ground. I placed a 1157 bulb in series with the base to the mains ground lug. The bulb lights up nice and bright. I would estimate 550Ma of current on base to ground.
Current and voltage change in an active secondary coil but resistance stays the same ? So high voltage low current at the breakout and low voltage high current at the base ? Do bipolar coils overheat the center secondary windings ? Hmmm..
Re: Add your strangest TC phenomenon here klugesmith, Fri Jan 21 2022, 06:00PM
Applause for the experiment. Your opto coupled ammeter, responsive to RMS value of AC or DC current. :) Any current at that point, which does not make it to the top of secondary coil, needs to go somewhere else -- I guess into capacitance between coil and the rest of the world.
