Coil not working after replacing dead IGBT
nzoomed, Sun Jul 30 2017, 10:19PM
Hi everyone, just getting back to my project after many months.
I ended up buying another IGBT off ebay and reassembled my coil again today.
No idea what's wrong, but my coil is no longer working since one of the IGBT's died.
Is there anything else i should be checking after an IGBT failure?
I believe the failure was caused on a floating gate, as i discovered that one of the cat 5 wires from the GDT had broken off the failed IGBT.
Im still getting a signal on the scope on the GDT outputs and on the bridge output itself also.
The scope shot below is taken from across the bridge, and the odd thing is i get the same waveform even if i remove the power from the bus!
Dont know whats going on here, but i think i might try and inject a signal from the signal generator into the UD board and see if that makes any difference. Right now my MIDI interrupter is simply emulating a spark gap coil in this screenshot.
Either way, i can hear the GDT making the usual buzzing noise when its being driven, so the feedback driver must be doing something right.
Any ideas?
Do TVS diodes usually short circuit if they fail? Thats the only thing i did not check when reassembling.
TIA
Re: Coil not working after replacing dead IGBT
Pac85hv, Sun Jul 30 2017, 10:27PM
What kind of signal do you get between the gate and the emitters? Are you sure you got the gdt phasing right?
nzoomed, Sun Jul 30 2017, 11:21PM
Pac85hv wrote ...
I was getting an almost identical signal to this on the scope across the gates.
I thought about the phasing, but ive never changed any of that, its all back 100% the same as it was.
I even compared it to the photos i took during construction.
Mads Barnkob, Mon Jul 31 2017, 08:36AM
When IGBTs explode in a Tesla coil, the GDT provides excelent protection to the driver, so this is not the first place to look for faulty components.
Start by taking the bridge completely apart and measure each component individually.
Gate resistors, zener diodes, diodes, IGBTs, everything. I have often seen gate resistors either go open circuit or very high resistance after a IGBT failure.
nzoomed, Mon Jul 31 2017, 11:53AM
Mads Barnkob wrote ...
OK, good point, I did not even think that those may have failed, i will test them tomorrow if i get a chance :)
Pac85hv, Mon Jul 31 2017, 02:01PM
That waveform is absolutely unacceptable, there must be something wrong with wither the gdt, the gate resistors and diodes ecc. or maybe your driver is outputting a very low frequency signal because it as no feedback(there can't be any feedback if the bridge is not powered and if the primary circuit is disconnected), you should try attaching a signal generator to the signal input of your driver.
That kind of wave is dangerous for the IGBTs during operation, they will dissipate too much power and explode.
nzoomed, Tue Aug 01 2017, 10:03PM
Pac85hv wrote ...
I was testing on low voltage, but yes i will check it this week when i have time to see if the gate resistors and are OK
nzoomed, Sat Aug 05 2017, 03:46AM
OK, a quick update, the TVS diodes i had across the gates must have also failed when the IGBT died. I put the meter across them and they are both short circuiting!
It did cross my mind whether or not they would be OK or not after an IGBT failure, but assumed they would have gone open circuit rather than short circuit. Anyway i will try the coil with them removed and hopefully it will be safe enough for a short time running without the TVS clamps.
I do see now that various TVS clamps have different failure modes, so will be interesting to see the datasheet for these ones.
These are the TVS clamps im using.
Just to rule out any possility on future IGBT failures, is it likely that these died as a result of the IGBT failing or could have one of these failed TVS diodes lead to the IGBT failure if it shorted the gates?
futurist, Sat Aug 05 2017, 03:14PM
TVS shorting due to igbt failure is more likely, especially if you found gdt leads detached
If tvs did short one igbt gate the driver couldn't continue to run other igbts normally which could lead to brick failure?
This is gdt output when other secondary is unloaded
Same gdt output when other one is shorted
nzoomed, Sat Aug 05 2017, 10:14PM
OK, well I fired it up at a low bus voltage and it started to work again with the shorted TVS diodes removed from the replaced brick.
Unfortunately, the coil stopped working again moments after turning on.
This time it tripped the circuit breaker, so is now dead shorting across the bus im assuming.
I have no idea what's happened this time, but perhaps the other IGBT that i never replaced was also on the way out perhaps?
Are you saying that those shorted TVS clamps could have caused the original brick to fail?
