Teardown of a Nokia Siemens Networks Flexi WCDMA Power amplifier
Mads Barnkob, Mon May 01 2017, 10:16AM
Nokia Siemens Networks Flexi Multiradio BTS is a GSM/EDGE, WCDMA/(I-)HSPA, and LTE base station for use in mobile telecommunication antenna networks. A network that you use daily on your cellphone.
This is the 4th part of a video series on this system, all high resolution pictures at the website
Part 1: System station Part 2: Power Amplifier Part 3: Antenna
The following 25 minute video shows the part 4 teardown step by step with explanations, high resolution pictures of content can be found on the links above.
Re: Teardown of a Nokia Siemens Networks Flexi WCDMA Power amplifier Mads Barnkob, Thu May 11 2017, 08:04AM
I did a further part on the integrated Doherty amplifier IC itself. Teardown of a NXP BLD6G22L-150 integrated Doherty amplifier from a Nokia Siemens Networks Flexi WCDMA base station.
