On the reproducibility of scientific results
Conundrum, Sat Feb 25 2017, 07:51PM
Hi all.
It seems that someone has asked a relevant question about the earlier report(s) of metallic hydrogen.
If the original sample no longer exists so therefore no further measurements can be done but it was stable
for a month or more between those diamonds, is it still scientifically valid?
It is unfortunate that the act of measuring caused a failure, but as the original author said it just encourages
other teams to replicate in order that the original data can be confirmed or refuted.
Can people add any other examples, a good discussion can therefore be had.
-A
Re: On the reproducibility of scientific results
..., Sat Feb 25 2017, 10:38PM
In the 'metalic hydrogen' case the fact that the sample was destroyed does not really affect the validity of the results, the concerns are more about the fact that their results are not really all that convincing (especially considering that they are quick to point out that there have been many claims in the past of MH detection, but that they were all wrong and this result is 'the first sample of MH on earth').
Their results would be much more convincing if they compared their measurements to an empty (or filled with another non-hydrogen material) DAC, or at least showed their measured spectra at the intermediate pressures so that one could at least refute their claims by finding an alternative theory (as was done for the previous refuted claims) which better matches the measurements.
Being able to reproduce their measurements would also of course be nice, and add a lot more weight to them. The good news is that their experimental setup is trivial as far as physics experiments go--they have processed the diamonds using specialized techniques, but did so using tools which should be readily available to other universities. The rest of experimental setup appears to be mostly off-the-shelf components which could be reproduced for under a hundred thousand dollars.
That said, their experiments will almost certainly be revisited in the next year or so by other groups, and the real science can start. In my opinion this is a relatively clean cut case, where they at least present some conclusive measurements (measured optical reflection of the sample consistent with a metallic transition), whereas there have been plenty of other results (like the EM drive) which base their claims off measurements that are barely more than noise and without any solid theoretical backing. Plus plenty of high-profile papers in other fields *cough*biology*cough* which are based on questionable statistics where no efforts were made to reproduce the results, or attempts to reproduce them were inconsistent with the original results.
Conundrum, Sun Feb 26 2017, 08:02AM
And psychology. If there is anything to be learned from this experience it is that being first at any cost is not always wise.
I read somewhere that between 50 and 90% of papers have suspect data, in many cases folks publish first but later find that their data was flawed. Do they admit it, ever? Nope!!!!
Carbon_Rod, Sun Feb 26 2017, 10:57AM
Conundrum wrote ...
Your influence-rating/budget as an academic is weighted by the number of published citations of your papers. No one who designs air-planes cites the story of Icarus. Thus, I would suggest that 50% number is optimistically low even if you exclude those that exploit a Simpson's paradox for fake medical advice, or shilling circles to sound relevant. While it is not really a lie to intentionally feign ignorance for attention, it certainly is unethical to reallocate budgets from real scientific work.
Also, there are around 174 fake journals designed to make silly people sound credible for political reasons. As people rarely question premium grade rhetoric, the political influence is surprisingly effective on the general public when cited by the gullible.
Some warning language from real papers for those who forget their statistics:
“a considerable trend toward significance†listing (
A warning about propaganda: it is usually a mix of truth and untruths to re-define a narrative, and thus debunking specific assertions with facts has proven ineffective. Thus, loud charismatic socio-paths will likely inherit the earth... have you not seen the prophetic works of “Idiocracy†(2006).
hen918, Sun Feb 26 2017, 11:57AM
Carbon_Rod wrote ...
Or the result of the US election?
DerAlbi, Sun Feb 26 2017, 01:40PM
I work at my university and in my buro we are proud of the fact that despite working well over 1.5years there we have not published a stupid paper at all ^_^
We are fully aware that the stupid system is extremely broken. Being ee-ing we use mainly ieeexplore as source for "information" but the bulk of shitty papers copies of copies and irrelevant information when doing keyword search is pathetic because people put keywords in their papers just to get higher rankings.
The most amusing part is how the professor pushes us all to finally get something out. We always try to point out that we do nothing worth publishing because there is a difference between normal engineering work and actual scientific progress which is extremely hard to achieve in circuit design.
Most sources of improvement are switching to a more suitable technology. So someone using a 90nm process makes better analog circuits that i ever can achieve in 28nm / 45nm. Even if we would develop the same topology.
Yet all improvements are aknowledged to the engineer - not to the fab. Crazy. The level of paper-pollution is ever increasing leading to ever harder information retrieval leading to worse "science" by the minute.
Physikfan, Sun Feb 26 2017, 04:35PM
Hi carbon rod
"Also, there are around 174 fake journals designed to make silly people sound credible for political reasons."
Is a list of these 174 fake journals available?
Uspring, Sun Feb 26 2017, 06:13PM
Worse yet than Simpson's paradox is inferring causation from correlation.
I think, you are a bit pessimistic. While it takes a solid math background to understand the pitfalls of statistics, a political discussion can often be safely dumped into the garbage bin if it is about who said something instead of what was said. Arguing to the point may cause headaches, though, and who wants that?
Carbon_Rod, Sun Feb 26 2017, 10:47PM
Uspring wrote ...
The point was, there are well established and privately funded political contractors that generate entire fake journals to justify complete nonsense, and gullible academics submit their own work (that may/may-not be valid publications deemed low-relevance by credible journals). While the public is so overwhelmed with unsubstantiated claims that real critics also seem to spout complete nonsense.
I guess pessimism is a product of blind optimism, logic, and years of observational data.
Physikfan wrote ...
Note, this list refers to a proven failure to enforce peer-review submission standards, but not every author/paper in a specific journal is necessarily dubious. The number has grown substantially higher over the years, constantly evolves the titles (usually after some bad press), and doesn't imply mainstream publications avoid the same problems.
A M Publishers
Abhinav
Academe Research Journals
Academia Publishing
Academia Research
Academia Scholarly Journals (ASJ)
Academic and Business Research Institute
Academic and Scientific Publishing
Academic Journals
Academic Journals and Research ACJAR
Academic Journals Online (AJO)
Academic Journals, Inc.
Academic Publications, Ltd.
Academic Research Journals
Academic Research Publishers (ARPUB)
Academic Research Publishing Agency
Academic Scholars Publishing House
Academic Sciences
Academic Star Publishing Company
Academic World Education & Research Center
AcademicDirect
Academicians' Research Center (ARC)
Academy Journals
Academy of IRMBR International Research in Management and Business Realities
Academy of Knowledge Process
Academy of Science and Engineering (ASE)
Academy of Science and Social Science (ASSS)
Academy of Scientific and Applied Research (ASAAR)
Academy Publish
Access International Journals
ACT Publishing
Ada Lovelace Publications
Advance Educational Institute & Research Centre (AEIRC)
Advance Research Publications
Advanced Research Journals
Advanced Scholars Journals
Advanced Science and Engineering Technology Institute (ASET)
Advanced Science Research Journals
Advancement and Development in Technology International (Aditi)
AENSI (American-Eurasian Network for Scientific Information)
African Research Review (AFRREV)
AgiAl Publishing House
AIRCC Publishing Corporation
Aizeon Publishers
Akademik Plus Publication
American Academic & Scholarly Research Center (AASRC)
American Association for Science and Technology (AASCIT)
American Research Institute for Policy Development
American Research Publications
American Scientific Research Journals
American Society for Science and Engineering
American Society of Registered Nurses
American V-King Scientific Publishing
Annex Publishers
ANSINetwork
Antarctic Journals
Aperito Publications
Apex Journal
Apex Journals - Apex Journal
Applied Science Innovations
Archers & Elevators Publishing House
ARPN Journals
ASD Publisher
ASDF Journals
Ashdin Publishing
Asian Academic Research Associates
Asian Economic and Social Society (AESS)
Asian Online Journal Publishing Group
Asian Online Journals
Asian Research Consortium
Associated Asia Research Foundation (AARF)
Association of Computer Electronics and Electrical Engineers (ACEEE)
AstonJournals
Athal Press & Media
Atharva Scientific Publications
Athens Institute for Education and Research (ATINER)
Atlas Publishing, LP
Austin Publishing Group
Australian Academy of Business and Social Sciences
Australian International Academic Centre Pty. Ltd.
Australian International Research Consortium (Australian International Journals
Avens Publishing Group
Avestia Publishing
Avicena Publisher
Basic Research Journals
Bell Press
Bentham Open
Best Journals
Better Advances Press
Bio Accent (Bioaccent)
Biohelikon
BioInfo Publications
BioIT international Journals
Biological and Chemical Publishing
BioMed Research
BioMedSciDirect Publications
Bioscience Research & Educational Institute
Blaze Journals
Blue Eyes Intelligence Engineering & Sciences Publication
Blue Ocean Research Journals
BluePen Journals
Bonfring
Bowen Publishing
Bret Research Journals
British Association of Academic Research (BAAR)
British Journal
Business Journalz (BJ)
Business Perspectives
Canadian Center of Science and Education
Canadian Research & Development Center of Sciences and Cultures see CSCanada
Canadian Science and Technology Press Inc.
Cardiology Academic Press
Center for Enhancing Knowledge (CEK), UK
The Center for Innovations in Business & Management Practice
Center for Promoting Ideas
Center for the Development and Dissemination of Knowledge
Central Research Insight
Centre For Info Bio Technology (CIBTech)
Centre of Excellence for Scientific & Research Journalism (COES&RJ)
Centre of Promoting Research Excellence (CPRE)
ClinMed International Library
Cloud Journals
Cloud Publications
The Clute Institute
Coltharp Institute
Columbia International Publishing
Comprehensive Research Journals
Computer Science Journals
CONFAB Journals
Congress Press
Contemporary Research Center (CRC), Australia
Cosmic Journals
Cosmos Scholars Publishing House
Council for Innovative Research
CREST Journals
Crown Journals
CSCanada
CTR Publications
Cyber Journals
Darsgah-e-Ahlebait
David Publishing
Deccan Pharma Journals
DeNovo Scientific Publishing
Design for Scientific Renaissance
Developing Country Think Tank Institute
Direct Research Journals
DISA Publication Group (DP Group)
Discourse Journals
Discovery Publishing Group
Donnish Journals
DRUNPP Sarajevo (Society for Development of Teaching and Business Processes in New Net Environment in B&H)
E-Cronicon
e-journal (shankargargh.org)
e-Science Central
e3Journals
Eagle Publishing Group
Earth Journals
Ebioscholar
eCanadian Journals
Econjournals
The Economics and Social Development Organization (TESDO)
EDUGAIT Press
E-International Journals of Academic & Scientific Research (EIJASR)
E-International Scientific Research Journal Consortium (E-ISRJC)
EISRJC Journals (E-International Scientific Research Journal Consortium
eJournals of Academic Research & Reviews
eLearning Institute
Electronic Center for International Scientific Information
Elewa Bio Sciences
Elite Hall Publishing House
Elite Research Journals
Elmer Press
ELVEDIT.COM
Elyns Publishing Group
Emerging Academy Resources (EAR)
Engineering and Technology Publishing
Engineering Journals (Engg Journals Publications)
Engineering Research Publication
Enhanced Research Publications (ER Publications)
Enliven Archive
Erudite Journals Limited
ESRSA Publication - Engineering and Science Research Support Academy
ESci Journals Publishing
ETA Maths Journals
Ethan Publishing Company
Eurasian Publications
Euro Asia Research and Development Association
EuroJournals
European-American Journals
ExcelingTech Publishing Company, Ltd.
Excellent Publishers
Far East Research Centre
Ficus Publishers
Friends Science Publishers (FSP)
GBS Publishers & Distributors (India)
Genexcellence Publication (G Publications)
German Science and Technology Press
Global Advanced Research Journals
Global Institute for Research and Education
The Global Journals
Global Journals, Inc. (US) also here
Global Open Journals
Global Openaccess
Global Research Journals
Global Research Online
Global Research Publishing (GRP)
Global Researchers Journals
Global Science Research Journals
Global Scientific, Inc.
Global Technocrats & Intellectual's Association (GTIA)
GlobalSkope Publishing Society
Gnosis Open Access Publishers
Gopalax
Green Earth Research Network
Green Global Foundation (GGF)
Greener Journals
Growing Science Publishing Company
Hans Publishers, Inc. (HansPub, ??)
Herald International Research Journals
Herald Scholarly Open Access
Herbert Open Access Journals
Hikari Ltd.
Hilaris
Horizon Journals
Horizon Research Publishing
Human and Sciences Publications (HumanPub)
Human Resource Management Academic Research Society (HRMARS)
i-Explore International Research Journals Consortium (IIRJC
IAMURE Multidisciplinary Research
IBIMA Publishing
IGM Publication
IJRCM
iMedPub = Internet Medical Publishing
Impact Journals (Tamil Nadu, India)
Imprints Open Access
Indian Society for Education and Environment (ISEE)
IndianResearchJournals.Com
Indus Foundation for Education, Research & Social Welfare
Infinity Press
Infonomics Society
Inforesights Publishing
Information Engineering Research Institute (IERI)
Ingenious Enterprises International (INGENIN)
Innovare Academic Sciences
Innovational Publishers
Innovative Journal
Innovative Publication
Innovative Space of Scientific Research (ISSR Journals)
INPRESSCO (International Press Corporation)
INREWI
Insight Knowledge
The Institute for Business and Finance Research (IBFR)
Institute for Research and Development India (IRD)
Institute of Advanced Scientific Research
Institute of Doctors Engineers and Scientists (IDES)
Institute of Electronic & Information Technology
Institute of Language and Communication Studies
Institute of Research and Journals (IRAJ)
Institute of Research Engineers and Doctors (IRED)
Institute of Strategic and International Studies
InTech Open Access Publisher - Mirror site
Integrated Academic Journals
Integrated Intelligent Research (IIR)
Integrated Publishing Association
Integrated Science Publications
Intellectual Archive
Intercontinental Electronic Journals
Interdisciplinary Publications
Interlink Continental Journals
Intermedcentral
International Academic Journals
International Academy for Science & Technology Education and Research (IASTER)
International Academy of Business & Economics
International Academy of Ecology and Environmental Sciences (IAEES)
International Academy of Science , Engineering and Technology (IASET)
International Academy of Science, Engineering and Technology (International ASET)
The International Academy, Research and Industry Association (IARIA)
International Advances for Research
International Agency for Development of Culture, Education and Science
International Association for Engineering & Technology
International Association for Engineering and Management Education (IAEME)
International Association of Computer Science and Information Technology (IACSIT Press)
International Association of Advances in Engineering and Technology (IAAET)
International Association of Journals & Conferences (IAJC)
International Association of Scientific Innovation and Research (IASIR)
International Association of Technology Education & Industry
International Bauhaus Science Press
International Center for Business Research
International Centre for Integrated Development Research (ICIDR)
International Centre of Culture Inventory
International Conference on Computer Science and Engineering
International Digital Organization for Scientific Information (IDOSI)
International Economics Development and Research Center (IEDRC)
International Education Research Foundation (IERF)
International Educative Research Foundation And Publisher
International Forum of Researchers Students and Academician (IFRSA)
International Foundation for Modern Education and Scientific Research (INFOMESR)
International Foundation for Research and Development
International House for Academic Scientific Research
International Indexed Refereed Research Journal
International Institute for Science, Technology and Education (IISTE) (International Knowledge Sharing Platform)
International Institute of Engineers (IIE)
International Institute of Engineers & Researchers
International Institute of Informatics and Systemics
International Institute of Science & Industry Research (IISIR)
International Invention Journals
International Journal Publishers Group
The International Journal Research Publications
International Journals.co.in
International Journals of Engineering & Sciences
International Journals of Health and Medical Research (IJMHR)
International Journals of Multidisciplinary Research Academy
International Journals of N&N Global Technology (IJNNGT)
International Journals of Research (INTJR)
International Journals of Research Papers (IJRP)
International Journals of Scientific Knowledge (IJSK)
International Journals of Scientific Research Publications (IJSRPUB)
International Journals of Scientific Research (IJSR)
International Knowledge Sharing Platform SEE International Institute for Science, Technology and Education (IISTE)
International Network for Applied Sciences and Technology
International Network for Natural Sciences (INNSPUB)
International Network for Scientific & Industrial Information
International Online Knowledge Services Provider (IOKSP)
International Organization of Scientific Research (IOSR Journals)
International Publisher & C.O
International Publisher for Advanced Scientific Journals (IPASJ)
International Recognition Multidisciplinary Research Journals, Monthly Publish
International Recognition Research Journals
International Research E-Journals
International Research Journals (Accra, Ghana)
International Research Journals (Lagos, Nigeria)
International Research Organization of Computer Science (IROCS)
International Scholars Journals
International Science & Research Journals (ISRJ)
International Science Congress Association
International Scientific Academic Corporation
International Scientific Engineering and Research Publications
International Scientific Publications
International Society for Zoological Research (ISZR)
International Society of Thesis Publication (ISTP)
International Society of Universal Research in Sciences (EyeSource)
InternationalJournals.co.in
Internet Scientific Publications
Interscience Journals
Interscience Open Access Journals
IOSR Journals SEE International Organization of Scientific Research
iProbe Group
IRED International Journals
IROSSS (International Research Organization of Sciences and Social Sciences)
ISISnet
ISPACS (International Scientific Publications and Consulting Services)
Ivy Union Publishing
Jacobs Publishers
JET Publishing
Journal Dynamics
Journal Issues
Journal of Comprehensive Research
Journal of Harmonized Research Publication
Journal Network
Journals Club & Co.
JournalsBank
JScholar Journals
JSciMed Central
Jyoti Academic Press
Kaleidoscope Journals
Kamla Raj Enterprises (KRE Publishers)
KEJA Publications
Key Research Journals (KRJ)
Kindi Publication
Knowledge Enterprises Journals
Knowledgebase Publishers
KnowledgesPublisher
Knowledgia Scientific (formerly Knowledgia Review)
KY Publications
Landmark Research Journals
Lecolink Research Journals
Leena & Luna International
Lifescience Global
LifeSciFeed Ventures
Lighthouse Journal Publication (Lighthouse Journals)
Literati Scientific and Publishers (Literati Publishers)
Longbridge Publishing Company
Lorem Journals
Macrothink Institute
MacroWorld
Mainspringer
Management Journals
Marsland Press
Mary and Sam Research Academia
Maryland Institute of Research
MASAUM Network
Maxwell Scientific Organization
MDPI (Multidisciplinary Digital Publishing Institute)
MedCrave
Medical Science Journals
Mediterranean Center of Social and Educational Research (MCSER)
Medwell Journals
Meghana Pubilcations
Mehta Press
Merit Research Journals
MNK Publication
Modern Research Publisher
Modern Scientific Press
Moksha Publishing House
Mr. Scholar
Muhammadon Centre for Research and Development (MCRD)
Multidisciplinary Journals
Mustang Journals
Narain Publishers Pvt. Ltd (NPPL)
Natural Sciences Publishing Corporation
Nauk Publication
Net Journals
New Century Science Press
New Ground Research Journals
New World Sciences Academy
Nexus Academic Publishers (NAP)
New Science Series Journals (NSSJ)
Nobel International Journals
NobleResearch Publisher
Non Olympic Times
North Atlantic University Union
Noto-are
Novel Science
Novus Scientia Journals
Nuclei Online
OA Publishing London
Oceanic Journals
OMICS Publishing Group
Ommega Publishers
OneCentral Press
Online Journals Management System (OJMS)
Online Research Journals
Open Academic Press
Open Access Library
Open Access Science Research Publisher (OASRP)
Open Access Text (OAT)
Open Research and Science Library (ORSlib)
Open Research Network
Open Research Society
Open Science
OpenAccessPub
Openventio Publishsers
ORB Academic Publisher
ORIC Publications
Ozean Publications
Pacesetter Online Publishers
Pacific Group of e-Journals (PaGe)
Pak Publishing Group
Panacea Research Library
PaperSciences Research Publisher
PBS Journals
Peak Journals
Peertechz (Peer Teechz)
Pelagia Research Library
Pencil Academic Press
Pharma Intelligence
Pharma Publisher
Pharmaceutical Research Foundation
Pharmacognosy Network Worldwide
PharmaInfo
PharmaInterScience Publishers
Pharmascope.org (JK Welfare & Pharmascope Foundation)
Photon Foundation
Pinnacle Journal Publication
Pioneer Scientific Publisher
Platinum Global Journals
Premier Publishers
Prime Journals
Pristine Research Journal Publications (PRJP)
Priyanka Research Journal Publication
Progressive Academic Publishing, UK
Progressive Science Publications
ProJournals (Professional Journals)
Prudence Journals
Purple Journals
Pyrex Journals
Quazzy Journals
Quest Journals
R & S Publications
Recent Science
RedFame Publishing
Research Academy of Social Sciences (RASS)
Research Alert Journals
Research and Educational Society
Research and Knowledge Publication
Research and Reviews (International Journals)
Research Institute for Progression of Knowledge (RIPK)
Research Media Ltd.
Research Publish Journals
Research Publisher
Research Script
Research Trend
Research WebPub
Researchjournali
Revistas Academicas
RG Education Society (RG Journals of Scientific Research)
Rising Vision (RV)
Ross Science Publishers
RS Publication
Sacha International Academic Journals
Sai Om Publications
SAMANM Group of Research Publications (SGRP)
Sapient Press
SAVAP International
Savvy Science Publisher
Scholar Journals
Scholar People
Scholar Science Journals
ScholArena
Scholarlink Resource Centre Limited
Scholarly and Academic Research Journals (SARJ)
Scholarly Journals
Scholarly Research Journal's
Scholars Academic and Scientific Publishers (SAS Publishers)
Scholars Research Library
ScholarsHub.net
Scholink
Scholoxy Publications
Sci Edit Publications
Sci Forschen
SciDoc Publishers
Sciedu Press
Science & Knowledge Publishing Corporation Limited
Science Academy Publisher
Science Alert
Science and Education Centre of North America
Science and Education Publishing
Science and Engineering Publishing Company
Science and Technology Publishing
Science Asia Journals
Science Education Foundation
Science Explorer Publications (explorerpub.com)
Science Fair Open Library (SFOL)
Science-Fellows ElmCore Journals
Science Instinct Publications
Science Journal Publication (SJP)
Science Park Journals
Science Publishing Corporation
Science Publishing Group
Science Q Publishing Group
Science Record Journals
Science Target
Science Web Publishing (Scienceweb Publishing)
ScienceDomain International
ScienceHu?
Sciences & Engineering Research Publication
ScienceScript
Scienpress Ltd.
Scientific & Academic Publishing
Scientific Advances Publishers
Scientific and Academic Publication
The Science and Information Organization (SAI)
Scientific Journals
Scientific Journals International
Scientific Online Publishing
Scientific Perspectives Publishing (Scipers)
Scientific Planet
Scientific Research Publishing (SCIRP)
Scientific Viewers
Scigmoid
Sciknow
SciTechnol
ScottishGroup Education and Testing Services
Scribes Guild
Segment Journals
SETScholars
Seventh Sense Research Group Journals
Signpost e Journals
Silicon Valley Publishers
Singaporean Journals
SJournals
Sky Journals
Smart Science & Technology
SmartPub (International Academy of Energy, Minerals and Materials)
Smith & Franklin Academic Publishing Corporation
Society for Science and Education United Kingdom (SSE-UK) also called Society for Science and Education
Society for Science and Nature
Society of Business Research
Society of Education
Society of Engineering Science and Technology (SEST India)
Society of Interdisciplinary Business Research
Source Research Journals
South Asian Academic Research Journals
Southern Cross Publishing Group
Sphinx Knowledge House
SPIRI The Global Research
Spring City Culture International Group Pte Ltd. Also: here.
Spring International S&T Publishing Media Co. (Spring Media Publishing)
Spring Journals
Sprint Journals
Standard Global Journals
The Standard International Journals
Standard Research Journals
STM Connect
Stringer Open
Suryansh Publications
SV Publication
Swan Open
Swiss Journals
Symbiosis (Symbiosis Online Publishing)
Synergy Publishers
T&S Journal PUblications
Takshila
Taraksh Journals
Technical Journals Online
Technopark Publications
Textroad Journals
Thavan E ACT International Journals
TI Journals
Time Journals
Tomas Publishing
Topclass Global Journals
Trade Science, Inc
Trans Stellar (Transstellar)
Transaction Series on Engineering Sciences and Technologies
Transcontinental Publishers
Transnational Research Journals (formerly Universal Research Journals)
TSPublications
U.S. Science Press
Ulster Press
Unique Research Journals
Universal Association of Computer and Electronics Engineers (UACEE)
Universal Association of Mechanical and Aeronautical Engineers (UAMAE)
Universal Research Group
Universal Research Publications
UniversityPublications.net
Valley International Journals
VBRI Press
Vernon Innovative Publishers (Vernon)
Victorquest Publications
VRJ Publishers
VSRD International Journals
Watch Plus
Webcrawler Journals
We-Together to Save Yourself Society
Whites Science
Wilolud Journals
Wireilla Scientific Publications
WOAR Journals (World Organization of Academic Research)
World Academic Journal of Business & Applied Sciences (WAJBAS Publishing)
World Academic Publishing
World Academic Union
World Academy of Research and Publication
World Academy of Science, Engineering and Technology (WASET)
World Business Institute Also here: wassco.org
World Journal of Publisher (WJP)
World Journals of Academic Advances
World Open Access Journals
World Research Publications
World Scholars
World Science and Research Publishing (WSRP)
World Science Publisher
World Science Research Journals (WSR Journals)
World Scientific and Engineering Academy and Society (WSEAS)
World Standard Organization
Wudpecker Research Journals
Wyno Academic Journals
Zeal Scienza Realm of Erudition
Zia World Press
hen918, Sun Feb 26 2017, 11:50PM
Uspring wrote ...
Every A-Level biologist's mantra "There is correlation but not necessarily causation..." I think seeing a correlation and incorrectly assuming a causation is the number one problem in statistical science. One solution is to ban statistics but that may be too radical :)
Take the infamous Autism / MMR cock up. Many conspiracy theorists slash Daily Mail readers still refuse to vaccinate their children...
Conundrum, Mon Feb 27 2017, 05:46AM
Yup, this one is a good example.
However this really belongs in alt.politics.misc.
Does anyone have any examples of a discovery being lost by sheer administrative incompetence, ie losing the only copy of a paper in some dusty drawer for several decades? Oleg Losev comes to mind (RIP)
Uspring, Mon Feb 27 2017, 10:18AM
A said state of affairs. A mockup, parasitic on journals trying to keep up standards. It emphasizes my point. Quoting an article is an argument by authority. From my point of view, this is not worthwhile. Instead one should argue by content. At this time one might conclude, that there is none in the referenced article.
Sulaiman, Mon Feb 27 2017, 11:09AM
If someone discovers something and publishes their findings;
. if it fits with known theories and violates no known laws of physics then I would accept it at face value as information - to be verified
. if the findings are peer-reviewed then the findings have more validity
. if other INDEPENDANT researchers confirm the findings then I consider the findings to be true
until disproved
Conundrum, Wed Mar 01 2017, 05:46AM
Quite right.
Interestingly there is data (verifiable) which I myself have seen suggesting that sulfur inclusions in palladium from one source could account for at least one case of "unreproducible" results. This is intriguing enough that I published it in the hope someone would one day make the breakthrough and have sealed proof of priority here etc.
Has anyone else here run into this issue? Also someone else dis suggest doing research full-time because much of my work so far is limited by lack of equipment and money.
