Is this worth dooing?
dexter, Tue Feb 21 2017, 01:41PM
For a half bridge i'm building i would like to lay the 1:1:1 GDT flat (due to space issue) on the PCB and wind it like in this sketch:
Is there a problem with this way of winding the GDT?
Re: Is this worth dooing?
Wastrel, Tue Feb 21 2017, 04:15PM
Not that I can see, but is it normal to drive both switches in a half bridge from the same GDT?
hen918, Tue Feb 21 2017, 05:11PM
Wastrel wrote ...
No, not unless you want a fixed 50% duty cycle.
If it was half a full bridge it would be alright, because you could vary the phase angle between the legs, as in a Phase Shifted Full Bridge.
