Trying to workout the strange behavior of force and current
Plasma, Sat Jan 28 2017, 02:38AM
Hi
The setup I'm using is below, I've consecutively add 250 nF approx to the bank three times, each time the pellet moved less and less.
I thought with more capacitance there would be the same force over a longer time and make the pellet move farther, but it getting less.
Any suggestions on how to fix the problem.
Img 20170121 131321233310771
Re: Trying to workout the strange behavior of force and current
Patrick, Sat Jan 28 2017, 03:17AM
we need more info. is the particle moving more with each increase, but not at the same expected rate ? this is likely not linear a situation, and calculus has to be used in time, position and acceleration type stuff. just adding more may not mean a better result.
Plasma, Sat Jan 28 2017, 03:28AM
The pellet at the start was moving about 5mm every arc, I normally let it arc about five times.
The second time with 250nF increase it moved about 3 mm per arc, third 1 mm.
The distance fluctuate based on whether it twist the arc before, but on average the distances workout around the values above.
Cheers
