To us that own a RIGOL
Finn Hammer, Thu Nov 24 2016, 09:02PM
All (happy users of a RIGOL)
Dokumentation is everything, and if it doesn't come with a scopeshot, it didn't happen.
In short, you need to grab the screen, but how to, without blanking the right side row of settings on the screen, when you export to a USB stick?
Here is a nice little screengrabber that operates from your PC via a USB cable.
You need a cable with USB B-type connector in the scope end, and it is the USB outlet on the back of the scope you connect to.
Or you connect via a LAN.
When you get the right WINUSB driver installed (and this is best done with the scope connected, and using this:
little install tool) a screen grab takes no time.
Hope this helps someone.
Cheers, Finn Hammer
Re: To us that own a RIGOL
Antonio, Sun Dec 04 2016, 10:37PM
The Ultrascope software works well for this. Captures the screen, and can control the oscilloscope too.
