Re: gate drive transformer of Richie Burnett's schematic
rajheman, Fri Jul 31 2015, 05:37PM
Is this attached schematic by me is right or wrong ??
About gate drive transformer winding and its connection to MOSFET pins for Richie Burnett's schematic
Plz help
Thanks
Regards
Rajheman
Re: Re: gate drive transformer of Richie Burnett's schematic
zzz_julian_zzz, Mon Aug 03 2015, 07:53AM
correct. You need to have an ocilloscope to see what's happening actually on the gates.
dexter, Mon Aug 03 2015, 07:59AM
zzz_julian_zzz wrote ...
not 100% required... it can be done with simple labeling of the wires
rajheman, Tue Aug 04 2015, 12:07PM
Thanks for reply Julian :)
I don't have oscilloscope with me right now .in this week I'm trying to buy one .then after I will check it .
One more question. As my guess I think I need supply small voltage like 12v to check MOSFET on oscilloscope right ??
rajheman, Tue Aug 04 2015, 12:15PM
Is anlog oscilloscope or digital storage oscilloscope is best for my circuit ??
In India digital oscilloscope are soo high in price compared to anlog. As I enquired one electronic store they quote 8000 rupees (126$ ) for 10MHz anlog oscilloscope.
dexter, Tue Aug 04 2015, 08:08PM
i made my first STTC without an osciloscope and it worked
all you need to do is attach labels to the GDT leads before twisting them together
zzz_julian_zzz, Wed Aug 05 2015, 01:18AM
@rajheman,
If you mean powering the bridge i.e. (+12 to top most drain and - to the lower most source), it's not necessary to check phasing.
You just have to check the waveform of GDT secondary(gate-source) to make sure that the "correct" MOSFETs are turning ON at the right timing. Digital or Analog will do 50-100Mhz would be fine. If you have plans on making your coil high powered/ make another one, (just make sure the Oscilloscope speed can accommodate your playing bandwidth)
@dexter,
Yup, I made 1 SSTC and 2 DRSSTCs without using an oscilloscope. But building a qcwdrsstc made me realize that I could use one, and If I could have invested earlier time, I could have saved precious transistors.
before, I even used my laptop as my oscilloscope (just to check the phasing of the logic and not to observe the actual operating frequency waveform as laptops can range up to 20khz only vs my sstc with 350khz. What I did is to lower first the clocking frequency from the TL494 / (or in UD, feeding the feedback circuit with a 18khz 555 timer square signal) luckily the bandwidth of my GDT can still play within these low frequencies. I don't know the core material/content.
rajheman, Wed Aug 05 2015, 09:30AM
Thanks for your valuable suggestions Julian and dexter.
I just saw video link posted by you dexter. I already labeled the wire's of GDT as u mentioned in video.
Even I checked the out put of gdt transformer with 4 led lights insted of MOSFET and they turned on and off as suggest by Julian .
As per Richie schematic left and right upper LED lights / MOSFET are on and lower left and right LEDs lights/MOSFET getting offed. Every thing is perfect.
But the problem is when I disconnected LEDs from gdt and connected the wire's to MOSFET pins as per my above mentioned schematic.there is nothing out put .no spark nothing from secondary of ssct
rajheman, Wed Aug 05 2015, 10:44AM
This is schematic what I did exactly as per Richie Burnett's schematic
Please check it
Ash Small, Wed Aug 05 2015, 12:18PM
I think you've made a mistake. It looks to me like you have both high side switches open together, and both low side switches opening together.
I think the mistake is because you've switched both the primary and secondary connections on the right hand side. You only need to switch the secondary connections, I think.
EDIT: I'm assuming switches 1 and 3 are high side and 2 and 4 are low side. 1 and 4 should be 'on' together, and 2 and 3 should be 'on' together, if I'm interpreting it correctly.
rajheman, Wed Aug 05 2015, 12:54PM
The windings for the two gate drive transformers are 16 turns, and each transformer has 3 winding, one primary and two secondaries. The secondaries are connected in anti phase, and the primaries of the two gate drive transformers are also connected in anti phase too
Ash Small, Wed Aug 05 2015, 01:21PM
rajheman wrote ...
I think you only need the secondaries wired in anti-phase. Wiring both primary and secondaries in anti-phase means you are back where you started.
rajheman, Wed Aug 05 2015, 01:46PM
Ash Small wrote ...
Yes your right ash. Just now I have read about H bridge circuit on wikipedia
Actually I made GDT connection on the suggestions of Mr. Julian
I have confused at point 7 on Julian suggestions.
Any how thanks a lot Mr. Ash for helping me on pointing out my mistake
Thanks a lot to Mr.Julian too :)
rajheman, Wed Aug 05 2015, 01:55PM
Ash Small wrote ...
rajheman wrote ...
You mean I just need to keep only secondary of gdt are in anti phase. But in Richie Burnett's schematic he connected left side gdt in parallel with points A and point B
But in second gdt (right side in schematic) point D and point C are crossly connected.
Plz check his schematic
Schematic 1
Schematic 2
Ash Small, Wed Aug 05 2015, 03:07PM
At first glance, I think he has inverted the primary only. The secondaries look to be wired the same.
rajheman, Thu Aug 06 2015, 08:22AM
One more last question.
In above image Richie mentioned that . adjust for 50:50 square wave out put at 10k pot .
Did he mean to adjust 10k pot to its center position ??
(I don't have oscilloscope)
Plz help this is last doubt to make my coil resonate
Thanks in advance
Regards
Rajheman
Ash Small, Thu Aug 06 2015, 11:51AM
rajheman wrote ...
Thanks in advance
Regards
Rajheman
I've not checked, but I assume the 10k pot adjusts the duty cycle. 50% is unlikely to be the mid point of the pot.
I can't think offhand of an accurate alternative to a 'scope. Maybe others who have built this without a 'scope can help here?
(EDIT: Maybe it's possible to charge/discharge a capacitor through a resistor, and measure where the average voltage remains constant, or some similar method?)
