mixing capacitors
IamSmooth, Wed Oct 18 2006, 07:48PM
I'm slowly collecting and making parts for a Tesla coil in the distant future. Two questions:
I know that is not ideal, but is there anything wrong with mixing different capacitor types like a 65kv/0.01uf cap in parallel with a maxwell 35kv/0.03uf cap if I wanted 0.04uf rating? Or, is this just a bad practice?
I see that many of you use a bank of caps with bleeder resistors. Is anything wrong with using just one maxwell if it meets the spec requirements set by the transformer?
mixing capacitors
J. Aaron Holmes, Wed Oct 18 2006, 08:59PM
Off hand, I can't imagine why it wouldn't be ok to mix two caps which, by themselves, would be considered suitable for coiling at a given voltage. Should be fine, I think, though it does seem a little "funny", I suppose...
MMCs have proven to be cheaper and more durable in TCs (in many cases) than the big pulse caps. Those 35kV Maxwell 37667's, for example, seem be a bit lacking in the voltage reversal department, and aren't generally recommended for TC work over 12kV (AC). The life is shortened substantially by running at higher voltages. I can personally claim to have blown up a 37667 at 14.7kV, though it was seeing particularly brutal break rates at the time >240bps
A friend of mine just blew up two of these caps a few months back
He has since moved to an MMC based on CDE 942C's in his pig-powered coil and all is well.
If you're nice to your Maxwells (the used ones especially), they'll probably treat you well. I ran mine for over a year in my small coil at ~13kV at 120bps. Even after runs lasting a couple of minutes, I couldn't detect any temperature rise in the cap.
Regards,
Aaron, N7OE
Re: mixing capacitors
Self Defenestrate, Wed Oct 18 2006, 10:02PM
Mm, I dont see too much of a problem, but I would warn against using just one cap in your tank. In an MMC, you can replace an individual $2 cap if something goes wrong, but if the tank is just one cap then your out to lunch if it blows.
IamSmooth, Sat Oct 21 2006, 06:10PM
The caps that I have are rated anywhere from 35KV to 65KV. I am hoping these will tolerate the 15kv*1.4 peak voltage from my neon.
With MMCs, strings of 10Mohm resistors seem to work well since the individual voltages are small. Any suggestions for a bleeder resistor setup for +20KV other than a discharge stick?
