Outsourcing PCB production
IamSmooth, Tue May 19 2015, 03:05AM
I'm at a point where I'm considering having a company make my circuit board and populate it with components. I would make the housing for it. I know some have done this here. Does anyone have a company they can recommend so I can call and get prices/info?
Thanks
Alex Yuan, Wed May 20 2015, 04:03AM
If you don't mind the wait then go for Seeedstudio. I ordered 10 UD2.5 boards and I got 13 at ~$3.30 each. Takes about 30 days?
If you can't wait then OshPark does 2 layer boards at $5 per square inch and you get 3 boards.
mister_rf, Wed May 20 2015, 07:39AM
My personal experience is related to the ELECROW
I have placed there few orders for the PCB prototype production. Good communication and very good quality IMO.
They promote also different type of services, including PCB Assembly services, to get the full service from components sourcing, soldering and testing, but I have never tested that service for my own small experiments.
Re: Outsourcing PCB production
Dr. Slack, Wed May 20 2015, 09:50AM
If you just want a few bare test PCBs to assemble yourself, prior to outsourcing the complete assembly, then dirtypcbs.com has an interesting business model. You get 'approximately 10' 4x4 DS PTH boards for $25. if you want exactly 10 it costs twice as much, as they leech capacity from the edges of big jobs run by other PCB manufacturers.
Wolfram, Wed May 20 2015, 12:56PM
Dr. Slack wrote ...
If you just want a few bare test PCBs to assemble yourself, prior to outsourcing the complete assembly, then dirtypcs.com has an interesting business model. You get 'approximately 10' 4x4 DS PTH boards for $25. if you want exactly 10 it costs twice as much, as they leech capacity from the edges of big jobs run by other PCB manufacturers.
I've just started using these guys, and the quality is on the same level as my previous supplier, Iteadstudio, surprisingly good considering the price. I've attached a picture showing what a board from dirtypcbs.com looks like. The slightly small via annular ring is my fault, as I managed to send them gerbers without a drill file. They somehow still managed to drill it, so I won't criticise them for using a slightly large drill for the vias. The board is marked as electrically tested, so it should be fine even if it looks a bit tight.
mikeselectricstuff, Thu May 21 2015, 06:51PM
You need to provide a bit more info - volumes, your location, type of board (SM/TH), complexity etc. to get a meaningful answer
Carbon_Rod, Fri May 22 2015, 05:53AM
Oshpark is around 30 days sometimes.
The boards are fine for 0.5mm pitch parts, but they simply fail to mill out areas too small for the route-out bit. Thus, I'd recommend someone else if you have surface mount parts mixed with mechanical though-hole tabbed components.
IamSmooth, Sun May 24 2015, 02:09AM
mikeselectricstuff wrote ...
I would try a run of 25 boards
Two-sided with vias
A mix of surface mount (resistors and caps) and IC sockets and a few other thru-hole components.
Each board is about 1" x 3"
IamSmooth, Tue May 26 2015, 02:20AM
Looks like my PCB Wizard program does not do Gerber files. I'll need that with any of these production facilities. How good is Eagle? It seems pricey for my limited use. I went to the company site and it looks like I have to pay a subscription fee. Is that correct?
Any other programs for PCB design?
..., Tue May 26 2015, 04:12AM
I would recomend KiCad
Make sure you are using one of the more recent releases, it has seen rapid growth over the last few years and the most recent version is really a decent piece of software which IMHO surpasses the paid version of eagle.
hen918, Tue May 26 2015, 05:32PM
... wrote ...
+1
I always use KiCad. A very nice program once you get to know its few quirks.
AndrewM, Tue May 26 2015, 07:59PM
PCBWay.com is the best I've ever used. Chinese prices but with 3 day turn.
mister_rf, Tue May 26 2015, 08:08PM
I’m not sure that I understood correctly your board dimensions, but for the EAGLE Light Edition the part needs to be placed within the 100 mm x 80 mm (4 inches x 3.2 inches).
The area starts at the origin and includes 100 mm to the right on the horizontal and 80 mm up on the vertical.
In my opinion 25 boards in production is personal use for evaluation purposes.
To use the freeware license select the “Run as freeware†button.
IamSmooth, Wed May 27 2015, 02:49AM
So I download the kicad.extras build?
Does this need an internet connection to work or is it stand-alone?
..., Wed May 27 2015, 04:31AM
Currently the KiCAD official windows mirror is at
you will want the most recent 'product' build (r5684 as of may 2015, make sure you get the _x64 version if you are running 64bit windows), if you are running OSX you need the most recent extras build at
It will prompt you (at least under windows) to install wings3d, this will allow you to render your boards in 3d but is not required. There also may be a few errors when you first run it it as it creates its preference files, but these can be ignored.
There are some good tutorials floating around, try to make sure that you are following one of the more recent ones as some are quite outdated and the buttons have moved around since they were written. The official documentation is pretty good
there are also some video tutorials out there which I understand are decent (I personally cannot stand watching video tutorials)
edit: it does not require an internet connection to run
mister_rf, Wed May 27 2015, 08:00AM
AndrewM wrote ...
I did a research on it, and I was disappointed on the shipping charges.
Yes, maybe that’s fast, but that’s too expensive IMO.
Let’s say 10 pcs 100mm x 100 mm, 2 layers, HASL,
PCB Cost: $ 13
Coupon Savings: - $ 2
Shipping Cost: $ 25.00
PayPal Fee: $ 3 ???
Total Amount: $ 39
My similar orders to similar company in China were about $ 24.57 ($14.90 + $9.67 shipping by Registered Airmail) and there was a 5-6 days processing time, and 11-14 days delivery time. And there was options for fast delivery too, Hong Kong DHL/FedEx/EMS but I was not in such a hurry.
Artlav, Wed May 27 2015, 10:46PM
Wow.
So it's now possible to do a custom PCB for under $100?
And at PCBCart it's still $55 for 10 60x40 2 layer boards plus $50 for delivery, and that's for the "prototype" quality.
mister_rf, Thu May 28 2015, 06:30AM
You may compare prices from different PCB manufacturers here:
Dago, Mon Jun 01 2015, 11:56AM
Artlav wrote ...
Wow.
You can get 10pcs 2-layer 50x50mm boards for 9,9$ + shipping (like 7$). 4-layer ones are like 30$. I have personally used Elecrow, itead and seeedstudio.
Justin, Mon Jun 01 2015, 07:51PM
I'd recommend dirtypcbs.com
