Cutting pcb
IamSmooth, Sat Sept 13 2014, 04:58AM
I saw a heavy duty cutting machine at circuit specialists for cutting printed circuit boards
Does anyone think a large paper cutter with the large hand-driven blade can cut a circuitboard
Re: Cutting pcb
Patrick, Sat Sept 13 2014, 05:11AM
Are you meaning the hand paper shear type attached to a table? if so i would think only for the 1/32 inch boards. for 1/32 i was able to use aviation snips, but even with micro grain carbide G4 fiberglass seems to dull tools. When i was a professional CNC punch press operator, we could see our punches and dies getting dull and drawing more hydraulic force in a single short run.
Re: Cutting pcb
Sulaiman, Sat Sept 13 2014, 09:34AM
I have used a manual paper shear for cutting circuit boards;
paper (srbp) board almost always splinters,
glass (FR4) is best done with one quick shear.
More reliable (even works for acrylic) is to score both sides with a (safety) knife,
put the board at the edge of a table or counter top with a sharp (not curved) edge
with the line along the edge of the table/top
hold down the board with a something hard (wood, a book etc.)
then with one swift blow of a book on the overhanging board
I usually get a nice clean break.
Cutting pcb
Hazmatt_(The Underdog), Sat Sept 13 2014, 03:29PM
For FR4 you're supposed to use a diamond cut router bit, that's what I use on most boards.
For the really thin boards, metal shears work fine, leaves a nasty edge though, but that can be sanded off.
Re: Cutting pcb
IamSmooth, Mon Sept 15 2014, 12:56AM
Just got a diamond-blade tile cutter for $99. Works very well and makes some clean cuts on the PCB FR4. I thought I would get one for $20 off of craigs list, but the guy never got back to me.
Re: Cutting pcb
Hazmatt_(The Underdog), Mon Sept 15 2014, 04:25AM
When Cutting FR4, try to use a dust mask. You won't die if you don't, but I'm sure your lungs will thank you.
And of course...I should probably wear one more often.
Cutting pcb
Dago, Mon Sept 15 2014, 06:00AM
Paper cutter seems to work fine on circuit boards. Also metal shears.
I personally use this mini circular saw from proxxon with carbide tipped blade:
Cutting pcb
IamSmooth, Mon Sept 15 2014, 10:19PM
Thanks for the advice. I always use a mask and face shield for all cutting. If it's something bad when I'm using malathion I use a respirator.
Re: Cutting pcb
IamSmooth, Mon Sept 15 2014, 10:20PM
I have to say, I've used shears, dremmel and box cutters. This diamond cutter is great. I would have gotten the mega-shear, but it was $330 and $60 to ship. This was $99.
