Electrochemical Stability of Aqueous Electrolytes
Carbon_Rod, Tue Oct 29 2013, 07:13AM
I read this paper,
and was curious if anyone knows of stable (nontoxic/safe-pH) aqueous electrolytes that can withstand over 2.4 V.
Cheers,
Rod
Re: Electrochemical Stability of Aqueous Electrolytes
Ash Small, Tue Oct 29 2013, 09:44AM
I've not read the full paper, and I'm not sure I fully understand the question, but if you're after organic compounds for electrolytes there are two that spring to mind, ethylene glycol (antifreeze) and glycerol (glycerine).
Glycerol is non-toxic, and I've used it as an electrolyte, with about 10% water added (You apparently require some water), along with the acid (the amount of acid added isn't critical, 10% to over 50%, depending on the application).
I'm not sure if this is relevant to your application. Maybe I should read the paper in full?
Andy, Tue Oct 29 2013, 06:41PM
You could try oleic acid, its polar and will work with salts, not sure about the 2.4volts thought, what do you mean?
Ash Small, Tue Oct 29 2013, 08:17PM
Andy wrote ...
I assume that 2.4V is the potential required for electrolysis of water, but I've not checked.
the_anomaly, Wed Oct 30 2013, 01:16AM
According to Wikipedia:
The electrolysis of water requires a minimum of 286 kJ of electrical energy input to dissociate each mole. Since each mole of water requires two moles of electrons, the specific electrical energy required is 143 kJ/mole (8.9×1023 eV/mole). It follows then that a minimum electrical power input per ampere is implied, namely 1.48 W/ampere. In turn, the minimum electrolytic potential for electrolysis of water of 1.48 V (not 1.23 V). Thus, any current (I) at applied voltage (V) greater than 1.48 V is an overvoltage and results in waste heat which can be estimated as I×(V-1.48).
Its 1.48V for electrolysis of water (I believe the paper stated 1.23V but that was besides my point). I believe Carbon_Rod was interested in an electrolyte which does not begin to breakdown or release energy as heat past applying 2.4V to the cell. I can only think of solid electrolytes that are good for higher cell voltage.
Carbon_Rod, Wed Oct 30 2013, 02:39AM
@the_anomaly
Indeed, we are seeking a stable fluid that will not undergo electrolysis, break down, and enter a gaseous phase.
