Hi folks! Long time no see. During this summer, I read up on LED cubes and decided to design and build one myself. It was an exercise in circuit design and programming, as I had never tried taking on a project as big as this, and I had never worked with microcontrollers or arduinos. I also made a small 4x4x4 prototype to see if it was something I could manage. It was also an exercise in patience! Soldering one layer took about 1.5 hours, and soldering a layer to the cube took about an hour too. I think it was worth it in the end, though. Looks pretty neat in person. the video doesn't do it justice.
I'd love to post the schematics, but I don't have any. It was all in my head, never bothered writing it down! I do have the code however, see the description of the video. It's written in Arduino.
It was fun to make, though. Weeks of "entertainment" ;) It also has the option of plugging a controller to it so I can change the parameters of each effect. Unfortunately I can only have about 7 effects total, since the ET-EASY 168 uses a microcontroller with only 16kB memory.
Re: 8x8x8 LED cube HV Enthusiast, Sun Sept 29 2013, 09:39PM
LED Cubes are really cool. Unfortunately the labor involved in building one can be downright staggering!!! Wish there was a way to mass produce these with something that could be easily pick-n-placed etc....
Anyways, very nice work. I love these things.
I did design one myself awhile back that used a DSP processor to make a very cool 3-D audio spectrum analyzer. That could be another idea you could use.
Re: 8x8x8 LED cube Thomas W, Sun Sept 29 2013, 10:14PM
EasternVoltageResearch wrote ...
Ive got a few ideas on how they could be mass-produced... very interestingly designed machines :)
Re: 8x8x8 LED cube Houdini0118, Sun Sept 29 2013, 11:18PM
If the leads could be spot welded together in a jig that would also make it alot easier to mass produce.
Re: 8x8x8 LED cube Gregory, Mon Sept 30 2013, 04:28PM
Ypu can try bit angle modulation to control the led brighness
Re: 8x8x8 LED cube Pinkamena, Mon Sept 30 2013, 04:51PM
I've been playing with that idea myself. Plugging it to the computer, and letting it do all the computation necessary.
Re: 8x8x8 LED cube HV Enthusiast, Thu Oct 03 2013, 01:34PM
We need a transparent PCB substrate, that way everything can be pick-n-place and just assembled in a modular fashion!
Re: 8x8x8 LED cube Patrick, Sun Oct 06 2013, 04:16PM
there are polyester resins for encapsulation that anrt as exothermic (as much as epoxy) that are totally transparent. this is totally cool and doable with some effort... what are the dimensions of your 8^3 one? (in inches, not communist metric )
some fiberglass is also nearly transparent, though with multi layers im not sure theyed be useful.
Re: 8x8x8 LED cube Pinkamena, Sun Oct 06 2013, 04:22PM
Patrick wrote ...
Each side of the cube is about 4.1 inches.
Re: 8x8x8 LED cube Patrick, Mon Oct 07 2013, 03:37AM
well at 4.1^3 it would be heavy, but totally doable.
