hi coilers:) I present to you indestructible armored tesla coil;DDDDDDDDDDDDD scheme is so simple that almost no details in conventional spools of this type are ballast current limiters here it is not present and the weak transistors without breaker for long duration totally annihilate;D however, this only works reel interrupter;)
just now I'm just starting to build this type of coil, and so I want to get 150-300cm streamer I use a semiconductor FGH60N60SMD
coil while it can operate from 170- 190VAC to do if it breaks above the primary winding
Re: Mega big Russian single transistor tesla coil Thomas W, Mon Jun 17 2013, 10:23PM
You are quite simply amazing when it comes to electronics, all your circuits are original and never really seen before.
I really wish i could get round to building some stuff... just saving up for a func gen and a oscilliscope
Re: Mega big Russian single transistor tesla coil PhilGood, Tue Jun 18 2013, 11:59PM
Another original and great design ! You are amazing, Mr Megavolt Wizard
Could you please post some pics of the assembly showing components and coils ?
Re: Mega big Russian single transistor tesla coil zrg, Wed Jun 19 2013, 02:00PM
Hey, hey, looks like you've forgotten something really important on your schematic a huge bunlde of TVSes for example?
Re: Mega big Russian single transistor tesla coil zilipoper, Fri Jun 21 2013, 09:23PM
hi guys
Re: Mega big Russian single transistor tesla coil Jazzman56, Wed Jun 26 2013, 12:33PM
Hi, zilipoper
Is there any-chance of getting some of the component values that are not present in the schematic?
Regards, Jazzman56
Re: Mega big Russian single transistor tesla coil zilipoper, Wed Jun 26 2013, 09:21PM
scheme with bugs after a complete circuit lay
Re: Mega big Russian single transistor tesla coil Chip Fixes, Fri Jun 28 2013, 05:47AM
This is amazing, I want to build it tomorrow
Re: Mega big Russian single transistor tesla coil zilipoper, Sat Jun 29 2013, 11:04AM
;) Pulse duration to put at least for the weak transistors
Re: Mega big Russian single transistor tesla coil RayeR, Mon Jul 01 2013, 10:46PM
Hi dude, your 1st circuit reminds me what I was trying about 10 years ago! Here's my single FET SSTC http://rayer.g6.cz/teslatr/sstce.htm#FETTC But in my case I used feedback coil and it didn't work well. I would fear about FET and zeneres by this rude base feed but you made it. Results are really impresive! I think this ISSTC is the best with price&simplicity / power radio that I have ever seen :)
BTW what about MOSFET drain-source voltage spikes? Did you tried to attach scope there? It kick ass your MOSFET hard but it behaves like zener diode and clamping it - this clamped energy is dissipated as heat of course. I can see you run very short bursts. I guess if you will keep run it for a minute at full power it blows off... This can be solved by class E topology (just add some capacitor) but it would require MOSFET for about 4x Vds rating of power supply which is hard to get...
Re: Mega big Russian single transistor tesla coil Mads Barnkob, Fri Jul 05 2013, 11:06AM
Another of your projects that I will put in the catagory of "Only in Russia".
Sittiing bare skin on the output wire thats arcs to the primary, please be careful!
You have some good spark growth from using the staccato to fire the halfwave rectified mains at zero crossing, good job.
Re: Mega big Russian single transistor tesla coil zrg, Fri Jul 05 2013, 02:25PM
Guys. This circuit uses about 300W of 1.5KE transient voltage suppressors on D-S of the MOSFET/IGBT. They are eating all the spikes. That is the secret, nothing else :)
Re: Mega big Russian single transistor tesla coil zilipoper, Fri Jul 05 2013, 06:35PM
be precise needle extinguished on the ballast 30 Ohm 100W consistently 1.5KE transient mounted on the radiator ;)
