microwave influence on Manganese(II) intra-shell transition (advanced question inside)
hboy007, Sun Nov 25 2012, 11:57AM
I can't come up with an explanation as to why the luminescence of Mn(II) 4T1 -> 6A1 transitions is enhanced through microwave influence on the 6A1 ground state. This is claimed by Godlewski et al.
It is stated that the spin-flip and parity forbidden transition (only enabled by weak spin-orbit coupling or mixing with 4p states) is enhanced by "a spin flip in the 6A1 groud state". So nearby Manganese ions couple slightly, enabling some sort of cross-relaxation process which depends on the exact spin orientation of the ground state ion.
Either I am lacking some basic understanding or the explanation is incomplete. How can electron spin resonance account for the relaxation of selection rules? As far as I understand, ESR magnetic dipole transitions
should only alter the projection quantum number m_S. Of course, one might also "flip a spin in the ground state", but then the total spin momentum is 3/2, not 5/2. The occupation of orbitals would remain unchanged (this leaves pairing energies and ligand field split terms unchanged) but I can't find a hint anywhere what energy a S=3/2 t_2g^3, e_g^2 (tetrahedral symmetry) state should have.
The only thing I have is the Tanabe-Sugano crystal field splitting diagram
with the 6A1 ground state, neglecting zeeman terms.
Another description of the intra-shell transition is given here:
Please help me!
Re: microwave influence on Manganese(II) intra-shell transition (advanced question inside)
hboy007, Tue Dec 18 2012, 11:08PM
Still haven't figured that one out. However, I am now satisfied with the insight that microwave influence just changes the spin projection quantum number. Induced Δ m_S = +/-1, +/- 3, ... transitions also obey Δ m_I = 0.
High spin resonant system, we shall meet again.
Conundrum, Sun Dec 29 2013, 02:52PM
Very interesting.
Do you have a paper written yet?
EDIT: Some EL sheet uses manganese.
If so then driving it at just below the luminescence threshold might make a very effective MW detector pad.
-A
