Streamer Length Calculations
Terry Fritz, Sat Aug 12 2006, 11:17PM
Hi All,
Part of the reason for the small SISG test coil and then the whole SISG thing was to figure out streamer propagation and distance calculations. Even though I wait eternally for more parts to arrive, "some" data is coming in now
There appear to be "two" factors controlling streamer length.
The first is the top terminal energy (basically much like top terminal voltage) given by (I am just pasting the C-code):
LeaderLength_E = LeaderLengthVsecFactor * sqrt(0.5 * VCsec_max * VCsec_max * (C2 + C3))
LeaderLengthVsecFactor = ~~ 36.0
C2 = secondary capacitance
C3 = streamer capacitance
This is the peak top terminal energy stored in the secondary capacitance and steamer capacitance.
The second is our old friend the Freau equation but based on actual delivered streamer power now:
LeaderLength_P = LeaderLengthPowerFactor * sqrt(Estreamer * BPS)
LeaderLengthPowerFactor = ~~ 2.0
Estreamer = actual joules delivered to the streamer load
These "two" factors give "two" lengths. You "get" the "LOWEST"!!!
If you don't have enough top terminal energy (basically much like top terminal voltage), more power just makes hotter arcs, not longer ones. This is why increasing the BPS only helps a little in most cases even though the delivered power can be very high. If you have a 1000BPS 10kW coil that arcs 1 foot, you need more top voltage.
If you don't have the delivered power, then 50 million volts on the top terminal does not help either. This is why coils made to have very low secondary capacitance to get to super high voltage choke out... A 1 million volt Tesla coil with 2 watts of input power, is not going anywhere...
Hopefully the relationship and why "higher BPS" just does not go as far will be understood soon now... Since BPS is now a factor, it should probably be "scanned" too...
Arcs to ground are pretty simple. You just zero the secondary voltage and dump all that secondary energy into the secondary resistance as a bright arc. They occur in probably "less than" 10nS (!) so just as fast as the program can dump energy...
For arc to ground distance, if the normal air streamers are say 30 inches, the arc to ground is about 40 inches. So there is just a factor of about ~~1.3 there of air arc vs strike distance. How "long" ground strikes last is a bit of an issue... More testing needed there. Basically how "long" the secondary is "connected" to ground... Seems like about 5 cycles in some cases. Probably should be based on energy left in the coil system or something...
Streamer capacitance is also pretty easy based on simple tests as:
C3 = (LeaderLength - TerminalDiameter) / 6.0 * 1.0e-12
The 220K constant streamer resistance seems to be holding rock solid!!!
All the Rprimary, Rsecondary, Coupling, tuning, dwell time, L's and C's are trivial now and ScanTesla can tear through that in a short while... JavaTC knows the rest
The SISG is wonderful since it eliminates so many variables as is perfectly repeatable!! I still need more data from "BIG" SISG systems like I am working on now to solidify the constants... It is sort of cool that we know so much about "lossy" coils that all the rest will just work out when their losses are added into the mess... I am "hoping" the DRSSTC portion will just work out happily too... The DRSSTCs lack of "fixed bang energy" made them "messy" to do these studies with...
ScanTesla is being modified for the new models, forever tweaked, and now has a separate parameter input file so a minor adjustment to a constant just changes an input file rather than the whole base program. It is not available yet and won't be for maybe weeks as it is polished. If anyone "needs" the 'current' version, let me know.
Cheers,
Terry
Terry Fritz, Sat Aug 19 2006, 04:35AM
Hi,
This is kind of a fun out growth of it all:
Conclusions:
1 - Initial small primary currents in an arc typically are spikes at the peaks of the
voltage waveform (might be just "stray" leaders" but they can vary greatly!!)
From a ScanTesla standpoint, they are probably not super significant.
2 - The arc currents are "high" and "bypass" the secondary inductance. A pure
"discharge the 200kV terminal in space to earth function. Inductance in that
path makes it "ring", but who cares...
3 - The arc continues(!!) at much lower current... The energy stored in the
secondary coil needs to dissipate too before the arc really extinguishes.
4- Once the arc goes out, energy left in the primary circuit can re-energize the
secondary system some.
Cheers,
Terry
