GK71 HFVTTC 30cm Flames
RateReducer, Sun May 27 2012, 08:21PM
Today i was bored. So i rebuild my GK71 tweeter.
New secondary has 14 turns of 2mm enameled wire on a 55mm cardboard pipe. Somewhere between 20 and 30Mhz. The choke has the same dimensions.
I used flat copper for the Anode, the ground connection an the feedback.
Power supply is a MOT with bridge rectifier + some microwave caps.
Dsc0282h
Dsc0284s
I am quite satisfied with this result smile
Greetings
Re: GK71 HFVTTC 30cm Flames
Thomas W, Sun May 27 2012, 10:16PM
wow, thats awsome, i want one so bad D:
RateReducer, Mon May 28 2012, 04:15PM
Thanks, Tom Williamson!
It is not that hard to build one. wink
Here is a new video getting 30cm flames!
I just increased the topload capacitance and added some chemicals on the breakoutpoint.
The ruler is 30cm in lenght...
I like that tube so much! amazed
Weston, Mon May 28 2012, 11:27PM
So the choke is wound on the same form as the resonator? Does the coupling between them have any effect?
Pinkamena, Tue May 29 2012, 12:41AM
Looks like an expensive and dangerous candle XD
Mads Barnkob, Tue May 29 2012, 05:02AM
Looks good and its a massive output for a tube running with cold plates. I got a good deal of tubes that size, maybe its time for a quick hfvttc as you did :)
RateReducer, Tue May 29 2012, 10:30AM
@Weston: Yes. I don´t know, i never tried to vary the distance between the 2 coils. But i think it does not matter.
@Pinkamena: That is true! xD
@Mads Barnkob: Thanks! :) It stays cold for about 30 seconds or so, than it gets slightly dark red.
"maybe its time for a quick hfvttc as you did :)" Try it! It is very simple and fun!
Greetings
TwirlyWhirly555, Tue May 29 2012, 03:27PM
Very Nice ,as its a pentiode are you running both grids togethere ( G1 / G2 ) ?
RateReducer, Tue May 29 2012, 05:06PM
Thanks.
Grid 1 is for the feedback.
Grid 2 is on supply +. (11,7k)
Grid 3 is on ground.
I could try to connect G1 and G2...
Greetings
zrg, Sun Jun 03 2012, 02:49PM
Well, that's a really well tuned flame discharge generator, I must say.
Being inspired by OP, remade my old GK-71 tweeter. Parameters are quite similar to OP's: ~30 MHz frequency, MOT with full-bridge rectifier and 2uf capacitance, 11k from + to grid 2, 10k from grid 1 to cathode, three power ceramic doorknob USSR caps (K15Y-1) 15 pf each in series, from secondary end to grid 1, as a capacitive feedback.
Plate becomes red-orange after ~20-30 sec run, probably because of no tuning at all tongue
Tetris, Sun Jun 03 2012, 03:19PM
Did you put salt on the electrode? Why is the arc orange? heh. first thing that came to mind was: oh wow this is high current. second thing: if you are amish that inherited a lot of money, and wants to sort of become more with the world, you'd make this. looks like a candle, but much more dangerous and made of plasma.
but that is one badass coil! there is no other way to say it!
RateReducer, Sun Jun 03 2012, 05:53PM
Thanks, zrg! :)
Nice coil. I would like to have ceramic pipes like you use them... The cardboard pipes i use get deformed because of the heat.
Thanks, HighVoltageChick!
No, i do not use salt. It is potassium sodium tartrate. (Stuff to breed crystals xD)
Greetings
zilipoper, Mon Jun 04 2012, 11:20PM
hell fire shades
RateReducer, Tue Jun 05 2012, 03:51PM
That´s a good comparison!
Even more realistic with sulfur on the breakout point! shades
Nice bluish flames + smell .
Marko, Sat Jun 16 2012, 02:18PM
Wow, that has to be one insane plasma tweeter. Any attempts at audiomodulation yet?
I'm wondering if this tube is just right for such a tweeter because it's rated for such a low frequency (20Mhz), which probably means it has quite significant output capacitance which helps loading the coil.
Also, how long are the flames without any dopings on the breakout point?
Marko
PhilGood, Sat Jun 16 2012, 05:34PM
Really amazing, congrats !
I gotta build one of these smile
Could you please share schematics ?
RateReducer, Tue Jun 19 2012, 05:09AM
@Marko: Thanks. Yes i tried to modulate it with a transformer + amplifier... It worked but not very loud. You can find a video on my YT channel.
I am currently working on another tweeter with audio modulation. The flames are about 20cm max. without dopings.
@PhilGood: Thanks. It is just the basic tweeter circuit. You can find many of the in the net. I already posted the grid configuration.
If you have any questions - message ;)
Greetings
Thomas W, Tue Jun 19 2012, 06:16AM
ive ordered my first tube :D
RateReducer, Tue Jun 19 2012, 09:35AM
GK71? wink
Dr. Dark Current, Tue Jun 19 2012, 09:52AM
Sorry to jump in, I've done some measurements on the GK 71 in the past and it absolutely needs forced air cooling at full plate dissipation, and the plate is not supposed to get red. So if you want your tube to last, direct some air flow onto it and don't let the plate get red.
Thomas W, Tue Jun 19 2012, 03:17PM
indeed it is the GK71, this is my first valve project and i have no clue what values i should use for resistors, capacitors and types ect D:
i have heard that valves are rather forgiving so.... c:
RateReducer, Tue Jun 19 2012, 05:46PM
Thanks for the info Dr. Dark Current!
My tube does not get red smile
