trying to repair FRG-7 receiver
hsieh, Fri Apr 06 2012, 03:46PM
I bought this several days ago.When it arrived I found it is in bad condition.The case is rusted.
When I turn it on and switch to AM band to test it,it cannot receive anything.Sometimes when I'm turning the dial, the signal meter reached 20dB and it start to make some weird sound(PO-PO-PO....)
manual:
schematic:
I have never repair something like this before so I have no idea how to repair it.Should I undergo the calibration process described in the manual?
Thanks
Proud Mary, Fri Apr 06 2012, 05:01PM
No, don't attempt to recalibrate it! Do not fiddle with any of the dust cores in the IF transformers!
First clean off loose mould and debris with a dry paint brush.
1.) Is the power supply reaching the boards? test with meter. Does the front panel display light up?
2.) If power is reaching the boards, inject a ~20mV audio test tone at pin 7 on Q410. If no tone comes from the loudspeaker, it means that the audio output amplifier circuit has failed. If the audio output circuit is good, inject the test tone at the hot end of VR1, the volume control. If the tone still comes from the loudspeaker, and can be varied by varying VR1, then VR1 is good. If no loudspeaker output, then VR1 has failed.
Work backwards along the signal path in this way, until you find the fault. When you get to the detector, and IF stages, you will need an HF signal generator, or function generator to inject your test signals.
The good news is that your receiver was manufactured in a way that makes fault-finding and repair very easy. There are even test points! (marked "TP" on the board) so you
will be able to make it work again if you don't rush into it in a hurry.
Re: trying to repair FRG-7 receiver
hsieh, Sat Apr 07 2012, 04:18AM
I did what you said and I found that the audio amplifier and VR1 is OK.So now I have to check the detector and RF part of the receiver.But I don't know how to do it.Can you explain this further or are there any websites to reference?
I will borrow a RF signal generator after this weekend.Should I inject a modulated test signal to every stage of the receiver?What amplitude and frequency should I set?
Proud Mary, Sat Apr 07 2012, 10:56AM
hsieh wrote ...
Hi Hsieh, I will study the circuit diagram this evening, and tell you where to inject an AM RF signal to test basic detector operation, and the IF amplifier stages. Stella
Steve Conner, Sat Apr 07 2012, 11:44AM
In the meantime, leave those dust cores alone!
Proud Mary, Sat Apr 07 2012, 09:52PM
Set the signal generator to 455kHz 500mV and AM modulation 500Hz.
With S3 on the receiver set to AM, inject a 500mV signal onto the anode of D402, where it is connected to C428 and L402.
If you hear the audio tone from the loudspeaker, the AM balanced detector and all the circuits after it to the loudspeaker are good.
If NO audio tone comes from the loudpseaker in the AM test, switch S3 to USB/CW and apply the same signal with NO modulation to the junction of D404, D406, and R433. If you can now hear a whistle when you adjust the BFO it means that the demodulator and all the circuits after it are good.
If BOTH of these tests are OK, set S3 back to AM, and inject a 455kHz 50mV AM tone signal onto the hot end of the secondary of T404 where it is joined to C422.
If you can hear the tone in the loudspeaker, Q406 - the final IF amp - is good.
If NO tone comes through, check voltages on Q406 which should be close to Emitter 1.4V, Collector 9.1V and Base 2.0V.
That is enough to be getting along with for now.
Tell me how these tests perform, and we can decide what to do next.
hsieh, Mon Apr 09 2012, 01:11AM
All the test you described are OK.I can hear audio tone come from the speaker in all tests.
My receiver also make a lot of weird sound when I turn it on.Does this mean something?
Proud Mary, Mon Apr 09 2012, 10:22AM
hsieh wrote ...
It means receiver not working properly!
In
triple-conversion superhet like FRG-7, it is best
to work
systematically, and not to work on 'hunches' and guesses about what is wrong.
Next:Set signal generator to 455kHz, with AM audio tone, RF output level 10mV.
With S3 set to AM, inject signal at start of ceramic IF filter - the point where FL-1 is connected to R420 and C417.
If you hear tone from loudspeaker it means IF filter and everything after is good.
hsieh, Tue Apr 10 2012, 07:23AM
OK, I can hear the tone from the speaker when I inject test signal to ceramic filter.
Proud Mary, Tue Apr 10 2012, 09:10PM
That is excellent news, Hsieh!
I will look at the diagram of the analogue frequency synthesizer in the morning, so we can move on to a new set of tests.
Proud Mary, Wed Apr 11 2012, 05:37PM
Next test:
Set signal generator to 2.5MHz, AM audio tone, 10mV.
Set the receiver to AM.
Fixing a small capacitor (say 3 - 10pF) to the end of the probe, inject 2.5MHz signal at junction of R445 and the hot end of T401.
Now tune the receiver very slowly across a 1MHz segment.
Stop turning the main tuning dial when - if - you hear the audio tone from the speaker.
What is the frequency reading on the dial when this happens?
Is there any indication on the signal strength meter - "S-Meter" - on the front panel during this process?
Do you have a counter-timer that we can use to measure the frequency of the various oscillators?
hsieh, Thu Apr 12 2012, 01:23AM
When doing this,I can sometimes hear a very faint/unclear tone when the main tuning dial is tune to 500 and the S-meter also reach 20dB.
Yes,I have a frequency counter.
Proud Mary, Thu Apr 12 2012, 10:01AM
hsieh wrote ...
This result strongly suggests that Q401, Q402, Q403, and Q404 are all OK, as the 2.5MHz test signal has appeared where it should at 500 on the main tuning dial - but as you describe the signal as being 'very faint' we must not dismiss the possibility of IF breakthrough.
So we will perform one more test on this 2nD IF/3rd Mixer stage just to be sure.
Set your counter-timer to a range that can detect signals in the range 2.455Mhz - 3.455MHz.
Fix your counter-timer probe to TP404, and observe the counter-timer while tuning the main dial across its full range.
If Q403 and Q404 are working properly, the counter-timer should display 2.455Mhz - 3.455MHz as you turn the main tuning dial across its full range.
hsieh, Mon Apr 16 2012, 01:23AM
I measure TP404 with an oscilloscope.The waveform is unstable,especially when my hand is on the dial.
Proud Mary, Mon Apr 16 2012, 01:58PM
hsieh wrote ...
OK Hsieh. That's because the probe is detuning the circuit. Connect it back to TP404 through a very small capacitance ~2 - 3 pf and try again.
hsieh, Tue Apr 17 2012, 09:45AM
Proud Mary wrote ...
hsieh wrote ...
I did this but the waveform is still unstable and distorted.
Proud Mary, Tue Apr 17 2012, 11:16AM
hsieh wrote ...
hsieh wrote ...
It's difficult to be 100% certain what is going on, without being able to see it myself, but here is what I think:
"waveform is unstable" - this is an
analogue VFO, being operated without the Faraday screen of the equipment case. Moving your hand, for example, near the variable capacitor may alter the frequency.
"distorted" - remember that this is the
switching waveform being applied to 3rd mixer. It is not intended to be a sine wave, but don't expect to see good square waves either!
Were you able to measure the frequency range of the signal at TP404, as I suggested? If you haven't got an instrument to do this, we will put this question on one side for the moment, (as you clearly have a signal of some sort) and move on to the frequency synthesizer.
Synthesizer crystal oscillator test: Measure the frequency of the signal at the junction of L301, L302 and C307. This should be 1 MHz.
Patric, Tue Apr 17 2012, 04:25PM
I do not want to interfere, but it is very stretching and I hope for a good ending!
Nothing wrong with the speaker?
hsieh, Wed Apr 18 2012, 12:58AM
waveform and frequency at junction of L301, L302 and C307:
waveform at TP404(sometimes it is a stabe sine wave):
Proud Mary, Wed Apr 18 2012, 02:46PM
The waveform and frequency of the synthesizer oscillator is excellent.
The VFO signal is within the correct frequency range. The waveform does look a bit sickly, so we will leave it as OK
Probable? and come back to it later if we cannot otherwise eliminate the fault.
Now we will get into the heart of the RF.
This next test will show us if there is a failure in the the elaborate RF pre-selector switching, one of the most common types of fault in older equipment.
Solder a small capacitor of approximately 50 - 100 pf to the end of a piece of insulated wire about 100cm long. This is your new antenna!
Fix the free end of the capacitor to the junction of R101, C101, and Q101 Gate 1. This is the input of the first RF amplifier.
Now tune across each of the receiver frequency bands and tell me what signals - if any - you can hear. If all is good, there should be plenty of signals (though not all in the right place, as we have by passed the pre-selector!
hsieh, Thu Apr 19 2012, 01:18AM
I connect the capacitor and wire to the junction of R101, C101, and Q101,But I still cannot hear any signal.I only can hear some weird sound.
I also measure TP101 with oscilloscope and get a perfect sine wave.and the frequency range seems correct.
Proud Mary, Thu Apr 19 2012, 09:57AM
OK Hsieh.
First we will go back to the doubtful waveform at the VFO (Q403) and VFO buffer (Q404).
Go to the junction of C410 and T403 and look for a signal between 2.455 - 3.455 MHz. This signal should vary in frequency across this range when you turn the main tuning dial.
Setting the receiver to the conditions given at the bottom of Table 5, measure the voltages at Emitter, Collector and Base of Q403 and Q404 and compare these test results with the figures given in the voltage chart.
hsieh, Fri Apr 20 2012, 01:37AM
I test the junction of C410 and T403 and get a perfect sine wave.The frequency range is correct.I test TP404 again and now I get a stable sine wave too.I didn't do anything.I only clean the circuit board with some sort of cleaner.
I also measure the voltages of Q403 and Q404.They are close to the voltage given in the manual.
Proud Mary, Fri Apr 20 2012, 09:18AM
That's good news about TP404!
Do make sure that your probe contacts and crocodile clips are
sharp enough to penetrate any surface coatings of varnish, oxidation, or dirt.
Now to some more voltage measurements!
Set the reciever to the condition specified at the bottom of Table 5, measure the voltages on C,B, E of Q101, Q102, Q103, Q104, Q105, Q106, Q107, Q108, Q109 and Q201, and compare with the specifications.
Conundrum, Fri Apr 20 2012, 06:22PM
Another thought, view the board on a thermal imager to look for hot spots from bad transistors etc.
-A
Steve Conner, Fri Apr 20 2012, 06:30PM
Don't listen to Conundrum! He'll have you improvising heat sinks from Sugru and metal filings.
Where are you going to get a thermal imager anyway? You could buy another dozen FRG-7s for the cost of even renting one.
If it were me, I'd be poking the board with a chopstick and banging on the chassis, to check for loose connections. Oh, and check for dirt between the tuning capacitor vanes, if it has a tuning capacitor.
hsieh, Sat Apr 21 2012, 02:09PM
I think probably I can use a thermal imager for free.There is one in our school lab and my teacher once said that I can use it.But will this trick work?
I am curious to know if FRG-7 is a well known model or not.
Proud Mary, Sat Apr 21 2012, 03:01PM
hsieh wrote ...
I can't help you with suggestions about fault finding with thermal imaging devices, as I have no experience in this, and will leave it to Conundrum to tell you what would be the best way of repairing your receiver using this technique. I know only the old slow way of doing this, circuit by circuit, until the fault is found.
But I can tell you that FRG-7 was one of the first high quality receivers built for sale to radio amateurs. It offered triple conversion, frequency synthesis, and Wadley loop stabilization, which had previously only been seen in communications receivers for professional use - such as military and maritime.
A Yaesu Musen FRG-7 in good working order and good cosmetic condition will still sell for a good price on ebay.
Conundrum, Sat Apr 21 2012, 03:49PM
Its an accepted technique, industry uses this all the time to locate shorts on multilayer boards.
Its also used for military applications where extreme reliability is essential, when recertifying a repaired board.
I think they compare it with a known good (KG) board and if there are substantial differences then the board gets reworked or scrapped.
-A
hsieh, Mon Apr 23 2012, 01:53AM
Today I measured the voltages and find some transistors that might be bad.
How much error is acceptable?I f the manual says 9V but I get 10V,Is this ok?
Proud Mary, Mon Apr 23 2012, 08:27AM
hsieh wrote ...
That would depend on which transistors they were, Hsieh, but mostly a ~10% deviation will not stop the circuit working.
Very generally, the collector or drain voltage should be a bit less than the supply voltage in normal operation. If the collector or drain voltage is the same as the supply voltage, it usually means that the device has gone open circuit.
hsieh, Tue Apr 24 2012, 01:03AM
I suspect that Q101 is dead.But it seems to be hard to find or expensive(10USD on ebay).Are there any replacements?
Japanese or American transistors are easier to find in Taiwan.
Proud Mary, Tue Apr 24 2012, 09:52AM
hsieh wrote ...
3SK40 has no ESD protective diode so is vulnerable in position of first RF.
3SK40 is obsolete, so NTE454 is a good substitute, which also has ESD protection on gate 1.
If NTE454 is also hard to get try BF988.
When substituting 3SK40 with a more modern dual gate FET, make sure you re-organize the pin outs!
If the substitute has a higher gain than 3SK40, I would suggest putting a ferrite bead on the drain lead to stop oscillation.
You will need to go through the RF board alignment procedure once you have replaced Q101.
hsieh, Mon Apr 30 2012, 03:13AM
I replace Q101 already.I replace it with 3SK40I.It cost me about 4USD each.
After I replaced it,the voltage still not don't match and I cannot receive anything.
Do I need some sort of antenna or I can just connect a long wire to the terminal block on the back?
What to do next?My friend is now laugh at me that I spent a lot of time and still cannot fix it.
Proud Mary, Mon Apr 30 2012, 12:31PM
hsieh wrote ...
Antenna: The FRG-7 has a sensitivity of better than 1 μV, so with only 1 meter of wire as an antenna, you will be able to hear
many shortwave broadcast stations when the receiver is working normally. With a really good antenna, FRG-7 can detect very weak, distant stations just as good as any modern receiver.
Ignorant friends: You are restoring a vintage triple conversion analogue communications receiver that has a soul and spirit, and you should thank the fault for teaching you how to think about analogue receiver construction and repair.
How you should proceed: We know that most of the sub-circuits are working correctly, so start the 'maintenance and alignment' process on page 11 of the manual and keep going until you find a procedure that doesn't work. You may need to make alignment tools - like
plastic screw drivers - by filing down a plastic knitting needle, or other hard
plastic rod.
I am going to replace all the electrolytics on the IF/AF board in my own FRG-7 in the next two or three weeks - when I can find the time - and will post up pictures of the work here in case you want to make the same improvements to yours.
Steve Conner, Mon Apr 30 2012, 12:35PM
The Wadley loop synthesizer is a complicated beast. The Pop-pop noises and bad waveforms are kind of what I would expect from a synthesizer that was failing to lock.
Maybe it would be a good idea to replace the electrolytics before starting to twiddle the IF transformer cores.
Also, dual-gate FETs like the 3SK140 can be extremely static sensitive, so take great care when replacing them. The Art Of Electronics recommends winding wire around all 4 leads and the metal can (if it has one) to short everything together, and not removing it until the device is soldered into the board.
Proud Mary, Mon Apr 30 2012, 03:10PM
Hi Hsieh, you may find it helpful to join
Petra's FRG-7 Group on Yahoo
She also runs groups for other makes of classic communication receiver.
hsieh, Tue May 01 2012, 07:25AM
Some suggest that I should measure TP109.I measure it but I cannot get any waveform.So I replaced Q107.Q108.Q109. But I still cannot get any waveform.
I also measures TP107 and didn't get any waveform.
Proud Mary, Wed May 02 2012, 10:27AM
hsieh wrote ...
I am going to take my FRG-7 (pictured below) out of its case next weekend to estimate the work and parts needs to replace all the electrolytics and introduce a narrower CW filter, and a crystal calibrator. If you can wait till then, I'll look at TP107 and TP109 and see what signals and voltages are on them in normal operation. I don't have a signal generator that can output a calibrated 1 μV, but last night I listened to the CW segment of 40 metres (7.000 - 7.040 Mhz) while I was doing the ironing, and could hear stations from east Europe and Russia, which is good performance for the receiver with just an indoor antenna. (I also heard a very loud WT station called GB60VUL, a 'special event' station
celebrating 60 years of the Vulcan nuclear bomber, an airborne horror of the 'Atom Bomb' era.) Anyway, Hsieh, this is the sort of performance you will get from your FRG-7 when you have finished restoring it.
hsieh, Thu May 03 2012, 02:22AM
Today I tried to send 1mV(lowest voltage on my signal generator) amplitude modulated signal to the antenna terminal of my FRG-7.
First I set my signal generator to 1.2MHz and tune my FRG-7 to this frequency.I can hear the sound but the sound is very faint.
Then I tried to send 10.5MHz signal and tune to this signal.Now the sound is very clear.
Did this mean that I need to calibrate my receiver?
Proud Mary, Thu May 03 2012, 09:15AM
hsieh wrote ...
Remember that 1 mV is more than 1000 times larger than minimum sensitivity of receiver, which is 0.7 μV. Such a large signal could bleed through a whole defective stage, and so appear at the audio output.
A problem
often found with old communications receivers is called 'finger trouble' or 'the man with the golden screwdriver' - bad work of previous owner, who interfere with circuit to 'improve' it, without knowing what they are doing. This can result in the position of dust cores, trimmer capacitors, and pre-set potentiometers being far from optimum position.
I would now suggest - as I suggested above - that you start whole re-alignment procedure given in manual, and tell me how the receiver performs at each stage.
hsieh, Thu May 03 2012, 09:38AM
In fact, I am now not very sure how to alignment it.I read page 11 already but cannot understand every step.Especially steps that involve sweep signal generator.
The highest frequency of the signal generator in my school lab is 20MHz.
I also don't know what output voltage should I set my signal generator to.
Proud Mary, Thu May 03 2012, 06:51PM
It is possible to align receiver without sweep generator, by plotting frequency response graph on graph paper like Old Times, but you still need signal generator that can output 55 MHz.
So let us leave that problem, and try procedure number (2) on page 11 "Balanced Mixer" - to give us important information.
hsieh, Fri May 04 2012, 12:29PM
Did the manual means that connect drain of Q102 and Q103 to the antenna input and tune to 910KHz?
I did this but there seems to be no change on the S meter.I can hear s sound if I switch to CW mode.
Proud Mary, Fri May 04 2012, 01:31PM
hsieh wrote ...
Bad translation Japanese to English! It mean you must connect antenna input terminal to Earth.
Look at back of receiver. Connect wire between SW1, BC, and E. (SW1 mean
Short Wave (antenna) 1, and BC mean
Broadcast antenna (Medium Frequency) and E mean
Earth which Americans call 'Ground')
Now there is no RF signal from outside! Only 910 kHz spurious signal receiver make itself!
Now set
BAND to
A, and
MHz to
0 and do procedure with VR101 and TC105 to make this bad, unwanted signal as small as possible. Slowly adjust VR101 a small amount, and then TC105. Then a little more on VR101. Then a little more on TC105 until you find
best combination of R and C to make 910 kHz as small as possible.
hsieh, Mon May 07 2012, 02:35AM
I cannot find TC105.And no matter how I adjust VR101,the volume of 910KHz signal don't change.The S-meter didn't move either.
I also notice that when the main tuning dial is near 0 or 1000,my receiver will make a weird sound.
Now I borrowed a signal generator capable of generating up to 1GHz.But I'm still not sure how to do step 1 on the manual.
Proud Mary, Mon May 07 2012, 03:52PM
hsieh wrote ...
These are harmonics of 1 MHz synthesizer oscillator Q301. This is normal. It show that most of receiver working correctly.
Today is public holiday in England. I will work on your problem tomorrow.
Proud Mary, Tue May 08 2012, 08:04PM
OK.
Band selector position:
B - 1.6 - 4.0
Main tuning dial:
500Pre select: approx
2.5 MHzNow turn slowly
MHz between
2 and
3. Does red
Lock light go
off and then go on again as you turn knob?
LOCK light go
off when frequency locked. When red
LOCK light
on, circuit
NOT locked- like warning! Reverse of what you think!
If LOCK light test OK, try at other frequencies and tell me what you see.
hsieh, Wed May 09 2012, 12:34AM
Yes,The red light go on and off when I slowly turn the MHz dial.I tried different frequencies and it works.
I know that the light go off means the circuit is locked.Why they design it this way?why they didn't add an inverter/not gate?
I also replaced all electrolytic capacitor on the IF-AF unit PCB.
Proud Mary, Wed May 09 2012, 10:32AM
Red is warning light. Synthesizer not locked!
Set receiver to 2.5 MHz exactly as above. Set MODE to USB CW.
Connect long piece of wire to terminal SW1. 3 meters is OK, 5 m is better.
Turn up volume control.
Check LOCK light is off.
Now turn PRESELECT slowly between 2.3 to 2.6 MHz. Does the noise from speaker get louder while you turn PRESELECT, and then become more quiet?
hsieh, Thu May 10 2012, 04:06AM
Yes.When I turn preselect slowly from 2.3Mhz~2.6Mhz,the sound from the speaker first become slightly louder than become quiet again.If I remove the wire on SW1,this sound disappear.
What is the propose of this test?Is this signal come from outside of the receiver?
Proud Mary, Thu May 10 2012, 07:27AM
hsieh wrote ...
It means receiver working!
Correct operation of receiver: Example: Set frequency to 9740 kHz
1. Set
BAND to
C - 4.0 - 11
2. Set main dial to 740
3. Set
MHz to 9 so
LOCK light go off.
4. Turn
PRESELECT slowly between 9 - 10 until you get loudest signal, or noise.
Every time you change the main tuning dial, you must re-tune
PRESELECT for loudest signal. This is very important on the lower frequencies, where a small change in frequency on the main dial will need a larger change in
PRESELECT.
hsieh, Thu May 10 2012, 11:30AM
Now I know I have to adjust the preselect dial while tuning and I successfully received one or two local AM station.But seems that the sensitivity of my receiver is very low.With a cheap pocket radio I can receive many AM stations.
Proud Mary, Thu May 10 2012, 12:27PM
hsieh wrote ...
Transistor radio has internal ferrite rod antenna!
To listen on HF (
BAND B,
C, and
D on this receiver) Connect
SW1 (
Short
Wave 1)to a long wire antenna - 20 meters is enough - as high off the ground as you can make it.
Connect
E to a good Earth.
To listen to AM Broadcast stations 0.5 - 1.6 MHz
BAND A connect long wire antenna to
BC.
You will hear very much noise on frequencies below about 10 MHz. This is normal today.
Try to learn about HF radio wave propagation - which frequencies work well during day, and which frequencies are best at night. A band on which no stations can be heard during the day may be full of stations at night. A band full of stations by day may be dead at night. It all depends on
ionosphere. Good Luck!
Proud Mary, Thu May 10 2012, 06:31PM
Hsieh! This is how I made indoor HF horizontal rectangular loop antenna 3.5 m x 4.5 m. for FRG-7
Regular hammer drill not work on my wall! Hard concrete! I use SDS drill - everything shake and crack plaster!
hsieh, Mon May 14 2012, 02:16AM
Today I also replace Q104.I found the one in my receiver is 3SK51 instead of 3SK40 in the manual.I replaced it with 3SK40 because I bought several 3SK40 and someone on another forum says that loss of sensitivity might because 3SK40 is damaged.
But there is no improvement.Probably I need to re-alignment it.If I am going to use signal generator preform alignment procedure in the manual,what output voltage should I set my signal generator to?
And why the schematic says Q104 is 3SK40 but I found 3SK51 in my receiver?Is this because manufacturer changed its design without changing the manual/schematic or because the previous owner repaired or modified it?
Proud Mary, Mon May 14 2012, 09:22PM
Injected RF and AF signal levels from generator must be appropriate for part of circuit under test.
Example: Maximum receiver sensitivity at antenna is 0.7 μV. An RF test voltage of 100 μV injected onto SW1 will be equivalent to a strong signal, but not enough to do damage.
Generally, you must select a signal generator output to be within the normal range of RF/AF voltage for the stage you are testing. You may increase this if you are sure that no damage will be done by a higher voltage applied at that place.
You have changed active parts in the signal path without good reason, and I expect it will be necessary to completely re-align the receiver for it to function correctly.
hsieh, Tue May 15 2012, 03:39PM
Today I tried to do the first step of alignment in the manual.I don't have a sweep signal generator.So I tried to inject different frequencies but I found that no matter what signal I inject,the waveform on TP104 didn't change at all.Even if I disconnect the signal generator.So what should I do now?
Proud Mary, Tue May 15 2012, 06:13PM
OK.
We test operation of First Heterodyne Oscillator Q201.
Connect oscilloscope or frequency counter between TP101 and TP102 (which is Earth/Ground).
What is the frequency on TP101?
What is RF voltage on TP101?
hsieh, Wed May 16 2012, 12:42AM
I measured the waveform at TP101.I get a sine wave and the frequency is around 75MHz.(MHZ dial set at 20MHz,as specified in the manual)
Proud Mary, Wed May 16 2012, 10:35AM
OK.
Now measure accurately frequency across whole tuning range, and post results here, so we can talk about them.
You may also find this FRG-7 restoration project helpful:
caffel, Wed Feb 27 2019, 08:34PM
FRG-7 tuning. Thanks for this exceptional guidance. As I start the tune up of my own FRG-7 I see an ambiguous instruction on page 11 of the manual "Set the band switch to A and the MHz dial to 0. Disconnect the antenna and connect its output to antenna terminal."
If this makes sense to you, could you explain with a few more words ?
Thanks, caffel
Conundrum, Thu Mar 14 2019, 08:48AM
Would a frequency counter be any use?
