Help! Is there anyone knows what kind of transformer this guy is using???
Bull88, Fri Feb 03 2012, 02:30PM
There should be thousands of high Volt....
This is the transformer:
This is the pic shows using this transformer to burn away the foil of the disc:
The video as following link:
Re: Help! Is there anyone knows what kind of transformer this guy is using???
Alex M, Fri Feb 03 2012, 02:44PM
You forgot to post any details.
Bull88, Fri Feb 03 2012, 03:20PM
Alex M, Fri Feb 03 2012, 03:23PM
That is a custom made step up transformer. The guy in the first picture is photoniciduction from youtube (well was, he closed his channel).
It took the 240VAC mains and stepped it up to around 100kV (going by arc striking distance).
You wont be able to buy one of them easily, his was custom made and probably cost quite a bit of money.
Kizmo, Fri Feb 03 2012, 04:08PM
Just get used Xray transformer and put it in fancy metal box with feedthrough insulators.
Not difficult at all. All major components are available on ebay.. or your local scrapyard with some luck.
Thomas W, Fri Feb 03 2012, 05:20PM
i was thinking of making somthing simlar to PI's transformer (he used a xray transformer for it) but i can see any xray heads that arnt over £100
radiotech, Sat Feb 04 2012, 09:16AM
It looks like a potential transformer, for metering.
Thomas W, Sat Feb 04 2012, 10:30AM
he said how he made it at one point:
he drawn up all the case and insulators
got them made then put a XRT inside it
