Hi all. Have a problem here when installing this dongle.
Problem resolved with new HDD and reimage, however dongle still not working reliably, seems to stall when connecting then USB disconnect sound. Works fine on other laptop, and as the other dongle keeps disconnecting on this machine only I am suspecting that the USB controller is failing due to RF feedback along the cable.
Am also after an external antenna if anyone knows of a source, its the micro connector similar to the ones used on some GPS modules.. Not the same as the ones on wifi cards although very similar diameter..
