Coil gun back EMF diode question
Alex M, Thu Jan 05 2012, 09:27PM
Its been a while since I last played around with coil guns and now I know a little more about what back-emf is I am wondering what sort of protective diode should I use on my capacitor back?
Like what sort of specs should it have (high current, high voltage ect). Would a single UF4007 work?
Thanks.
Re: Coil gun back EMF diode question
Inducktion, Thu Jan 05 2012, 09:42PM
Generally a flyback diode should be as well rated as the switch is...
Alex M, Thu Jan 05 2012, 10:06PM
Dr. Duck wrote ...
What do you mean by switch? I am just using a chicken stick to make the connection (it sparks loudly).
Turkey9, Fri Jan 06 2012, 12:13AM
You should rate the current and voltage to about 20% above what flows through the coil. You can estimate this using the famous barry simulators.
