positive rail input comparator
kell, Wed Jul 05 2006, 09:11PM
I'm looking for dual and quad comparators that will accept a common mode input at the positive rail and a supply voltage of 18 volts.
HV Enthusiast, Thu Jul 06 2006, 12:04AM
kell wrote ...
Some sites to name a few you can check are the following. They have parametric searches.
http://www.ti.comhttp://www.national.comhttp://www.linear.comAlso remember the rules. We aren't going to do your homework for you.
Steve Conner, Thu Jul 06 2006, 03:03PM
*cough* LF412
It's an op-amp, not a comparator, but I know for a fact it works up on the positive rail, because I use it that way in my DRSSTC interrupter. That's all the homework you're getting.
Re: positive rail input comparator
kell, Fri Jul 07 2006, 07:08PM
Looks like no comparators work at the top rail. I'll work around it.
HV Enthusiast, Fri Jul 07 2006, 07:33PM
You shouldn't be using a comparator in that fashion in the first place - hence the reason you don't see comparators designed that way. Use a suitable reference, and divide down your voltage as necessary. I don't know why you would want to trip at the Vcc of the comparator anyways.
kell, Sun Jul 09 2006, 08:27PM
This is for current sensing in the positive rail. I can do it with discretes, or with an op amp like the 412 (see the second diagram).
. + -----+--+-- Rsense --+---->
. Rc | |
. | c\| |
. \e |----'
. PNP |---+--e/| NPN
. /c |
. | R
. Rload |
. + -----+--- Rsense ----+---->
. Rc |
. | __ | |
. c\| / +|--' |
. NPN |---< | |
. e/| \_-|-----'
. Rload
HV Enthusiast, Mon Jul 10 2006, 01:51AM
Why not put the current sense resistor on the (-) side. This will make current measurements much easier.
Also, if you do go for high side sensing like you are doing, use a differential amp, not a comparator.
kell, Mon Jul 10 2006, 02:34AM
EastVoltResearch wrote ...
That one's a no go. Poke around a the wiring diagram for floating field dc generators of the type used in GM trucks and American bikes of the 1950's, you'll see why.
